    hi, i need your help... tell me, how i do a new modules please
    14 Posts 5 Posters 4.7k Views 5 Watching
      please start using the markdown syntax and code blocks around your content…
      i have edited two posts… for clarity
        sdetweil @bjjsoul
        @bjjsoul said in hi, i need your help... tell me, how i do a new modules please:
        Line 100 col 9 Expected ‘]’ to match ‘[’ from line 28 and instead saw ‘}’.
        so, you have an error, you look to the line PRIOR to the one called out,
        so line 99… and see what is wrong with that… it says some [] group isn’t completed, cause it say } before ]
        all brackets [] and braces {} have to be matched
        • bjjsoulB Offline
          bjjsoul
          mmmm sorry , i dont understand… :( my magic mirror is run perfect , whitout this module0_1570743430371_WhatsApp Image 2019-10-07 at 9.50.47 AM.jpeg
          AND THIS is , file MM-Snow.js
          /* Magic Mirror
           * Module: MMM-Snow
           * MIT Licensed.
           * Comment on terminology: a 'flake' is any moving item being shown on the mirror, while
           * the specific themed items are called 'snow' or 'heart'. This applies to variable names
           * file names and css class names.
          Module.register("MMM-Snow",{
          	defaults: {
          		flakeCount: 100,
          		theme: "winter"                 // pick from themes map below, i.e. winter, love
          	themes: {
          		"winter" : {
          			"flakePrefix"  : "snow",    // prefix of css name, e.g. snow1
          			"imagesCount"  : 3,         // number of images available in this theme, here:  snow1, snow2, snow3
          			"downwards"    : true,      // direction of flake movements, snow goes downwards
          			"sizeFactor"   : 1},        // adapt size of flakes to your liking, use original flake size
          		"love"   : {
          			"flakePrefix" : "heart",    // prefix of css name, e.g. heart1
          			"imagesCount"  : 2,         // number of images in this theme, here:  heart1, heart2
          			"downwards"    : false,     // direction of flake movements, hearts raise upwards
          			"sizeFactor"   : 2},        // adapt size of flakes to your liking, we like bigger hearts
          		"water"   : {
          			"flakePrefix" : "bubble",   // prefix of css name, e.g. bubble1
          			"imagesCount"  : 1,         // number of images in this theme, here:  bubble1
          			"downwards"    : false,     // direction of flake movements, bubbles raise upwards
          			"sizeFactor"   : 2}         // adapt size of flakes to your liking, we like bigger bubbles
          	getStyles: function() {
          		return [ "MMM-Snow.css" ]
          	getDom: function() {
          		var themeSettings = this.themes[this.config.theme];
          		var wrapper = document.createElement("div")
          		wrapper.className = "wrapper"
          		var flake, jiggle, size;
          		for(var i = 0; i < this.config.flakeCount; i++) {
          			size = themeSettings.sizeFactor * (Math.random() * 0.75) + 0.25;
          			flakeImage = document.createElement("div")
          			var flakeSuffix = Math.round(1 + Math.random() * (themeSettings.imagesCount - 1));
          			flakeImage.className = themeSettings.flakePrefix + flakeSuffix;
          			flakeImage.style.transform = "scale(" + size +", " + size + ")";
          			flakeImage.style.opacity = size;
          			flake = document.createElement("div");
          			if(themeSettings.downwards) {
          				flake.className = "flake-downwards";
          			else {
          				flake.className = "flake-upwards"
          			jiggle = document.createElement("div");
          			jiggle.style.animationDelay = (Math.random() * 4) + "s";
          			jiggle.style.animationDuration = ((Math.random() * 30) + 30) + "s";
          			jiggle.appendChild(flakeImage);
          			size = (Math.random() * 0.75) + 0.25;
          			jiggle.style.transform = "scale(" + size +", " + size + ")";
          			jiggle.style.opacity = size;
          			flake.appendChild(jiggle);
          			flake.style.left = ((Math.random() * 100) - 10) + "%";
          			flake.style.animationDelay = (Math.random() * 100) + "s";
          			flake.style.animationDuration = 100 - (Math.random() * 50 * size) + "s";
          			wrapper.appendChild(flake);
          		return wrapper;
            sdetweil @bjjsoul
            @bjjsoul can’t be perfect if you want to add another module
               	{   < --- start module
               		module: "newsfeed",
               		position: "bottom_bar",
               		config: {  < ---  start module config
               			feeds: [  < --- start array of feeds
               				{ < --- start feed
               					title: "New York Times",
               				}  < -- end feed
               			], < --- end array (only one entry)
               			showSourceTitle: true,
               			showPublishDate: true,
               			broadcastNewsFeeds: true,
               			broadcastNewsUpdates: true
               		} < ----  end module config
               	}, < --- end module
               	module: "MMM-Snow",
               	position: "fullscreen_above",
               	config: {   < - start module config
               		flakeCount: 100,
               		theme: "winter",
               } < ---- end module , no comma, no more modules to follow
                   },   < ------ what is this??????? -------------------------------
               ]    < --- no more modules, end module array
            • bjjsoulB Offline
              bjjsoul
              HEY BRO YOU ARE AWESOME … THANK YOU DUDE, I AM VERY HAPPY! IS WORKING … HEY BRO YOU HAVE WHATSAPP THIS MY NUMBER 504 98674031 … I AM GONNA BE NEEDING YOU, IN MY NEXT MODULES INSTALLATIONS… THANKS
              VIDEO
                sdetweil @bjjsoul
                @bjjsoul no whatsapp…
                  Mykle1 Project Sponsor Module Developer @bjjsoul
                  @bjjsoul
                  Adding modules
                  https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners
                  • bjjsoulB Offline
                    bjjsoul
                    hey bro, i need help with mmm.awesomealexa… you know if this module is working
                      ryanroy837
                      thanks all for your responses. i was having similar questions and your answers were helpful to me.
