    Family Info Board
    Scheduled Pinned Locked Moved Showcase
    40 Posts 19 Posters 59.6k Views 33 Watching
    • P Offline
      Padilla187 @Wedee
      @Wedee don’t want to be a wierdo but I fell in love with this I Just shot you a pm
      • O Offline
        Orca
        @Wedee : How did you the trick with several calendars? Could you please share some infos for me?
        Thx
        lucallmonL 1 Reply Last reply Reply Quote 0
        • lucallmonL Offline
          lucallmon @Orca
          @Orca simply clone the module for the calendar and change the settings for login.
          • O Offline
            Orca
            @lucallmon: Can you give me a hint how to clone this module. I’ve copied the folder into …/modules and named it calendar1, but only black screen.
            Thx
            • W Offline
              Wedee
              No need to duplicate the module, in the config.js just repeat the module config but point to the second calendar settings.
              • yawnsY Offline
                yawns Moderator
                You have two possibilities with the calendar module.
                Option 1:
                This shows one block and mixes both calendars, sorted by date
                		module: 'calendar',
                		header: 'both calendars'
                		position: 'top_left',
                				url: 'http://www.whatever.....xx.ics',
                				symbol: 'calendar',
                				url: 'http://www.justanother....zz.ics',
                				symbol: 'calendar',
                Option 2:
                This show calendar1 sorted by date and then shows calendar2 sorted by date, but in a seperate block with a seperate header
                		module: 'calendar',
                		header: 'calendar1'
                				symbol: 'calendar',
                		module: 'calendar',
                		header: 'calendar2'
                				symbol: 'calendar',
                JohanbaJ 1 Reply Last reply Reply Quote 3
                • O Offline
                  Orca
                  THX, that did the trick.
                    dsegel
                    Another request for you to post your css for calendar_monthly…I’m not having much luck getting it formatted widely enough.
                    • E Offline
                      emos
                      Very clean.
                      Can i ask, how did you manage to create horizontal lines for all the modules?
                      • W Offline
                        Wedee @emos
                        @emos I believe its just a function of my CSS forcing column widths (width: xxxpx;). As the headers of the module are usually set to “float” the forcing of a width makes them span the entire column.
                        I have not touched the mirror in about a year - it just runs.
                        • E Offline
                          emos @Wedee
                          @Wedee Thank you for your reply.
                          Do you mind sharing your main.css and custom.css with us? It looks too damn good ;)
                          W G 2 Replies Last reply Reply Quote 0
                          • W Offline
                            Wedee @emos
                            @emos Shoot me a PM with your email and I will add you to the dropbox share i have of the files.
                            • I Offline
                              IndyMac @Wedee
                              @wedee I like your design. I’m just getting started on my MagicMirror. Do you mind adding me to the Dropbox share? Thanks!
                              • G Offline
                                Galm @emos
                                @Wedee : Hello Wedee -> i send you a PM with my email address. Would it be possible for you to share your main.css and custum.css? thanks a lot
                                • MeatHeadInkM Offline
                                  MeatHeadInk
                                  @Wedee I messaged you with my email address awhile back as well.
                                  • W Offline
                                    Wedee
                                    I edited the main post with more info… sorry it took so long.
                                    • JohanbaJ Offline
                                      Johanba
                                      @Wedee, Thanks for taking my message.
                                      I am crazy about your format, but coping the Custom.css just crash my MM completely.
                                      Will someone please share their Main.css, Custom.css and config.js with me on jbarkhuizen@gmail.com
                                      I will appreciate this
                                      Johan
                                      • JohanbaJ Offline
                                        Johanba @yawns
                                        @yawns
                                        Hi, I copied this to my Config.js
                                        Then I get a syntex error on the position in both scenarios
                                        Appreciate the support
                                          sdetweil @Johanba
                                          @johanba could you post the ‘what you copied’…
                                          back two pages and can’t find it…
                                          • W Offline
                                            Wedee
                                            I imagine the Custom.CSS failure is related to the fact that its calling for an image. I would remove the two lines related to the Background and see if it works then. Other than some colors and of course the forcing of the column widths there is not really much in the custom.css
                                            In the config.js I sent you via email - you will see I changed to using the module MMM-Profilepicture pointing back at localhost to host backgrounds there. It is much cleaner easier to use. I also switched from wunderlist to todoist for the todo list…
                                            I have not done much other than change the background for many years now - Wife is asking for a refresh, and we picked up a Narrow hutch someone was throwing away that with a coat of paint some new handles and a new monitor will make for an excellent info board - so once that is refinished i will start anew again but this time the screen will be in portrait.
                                            Good luck and happy learning
