    MMM-DumpsterDay
    83 Posts 11 Posters 58.4k Views 12 Watching
      DeanoNoire
      Hey guys,
      I finally found some time to review and practically remaster whole module. Now it’s finally working correctly and the console logging is improved and more readable.
      Please let me know if you still encounter some issues.
      Stay safe in these difficult times!
        robertybob @DeanoNoire
        @DeanoNoire The download link isn’t in the original post anymore?
          DeanoNoire @robertybob
          @robertybob originaly there was a github card for the repository, but it seems the card is not supported anymore.
          And as I’m not able to edit the original post, here is the link:
          https://github.com/DeanoNoire/MMM-DumpsterDay
            blackeaglece
            Hello how can i reduce the space between the header and the image? as you can see from the screenshotreduce.jpg Thank you very much
              DeanoNoire @blackeaglece
              Hello @blackeaglece ,
              I do not use the headers, but I presume it’s always on the top of the module wrapper.
              So first thing I’d try is decreasing the height value of trashcan_wrapper.
              This is done in MMM-DumpsterDay.css file in the module folder.
              Please let me know if you managed moving it by these steps.
              Deano
                Bob
                Hi, is there any way to add a option for a 4th icon ? We have 3 different types of recycling (glass, cardboard and plastic), as well as the usual rubbish/trash, and of course, they all come at different times ! :)
                  DeanoNoire @Bob
                  Hey @Bob ,
                  sure thing. Any tips for cardboard and glass bin image and color?
                  This brings me to an idea of making the colors and images parameterizable.
                  Deano
                    Bob
                    @DeanoNoire Our colours are blue (glass), grey (cardboard), green (plastic) and black (trash/rubbish), but I suspect if you compare local areas, they’ll all have different colour schemes. I’ve even seen places where the bins were all the same, they just had different logos on them for the relevant product.
                    As you say, either paramatize them, or even just reference the icons by name/type, and let people change the image behind them to their colour of choice ?
                      Bob
                      Just when I thought there were a standard set of colours, I find this…
                      https://en.wikipedia.org/wiki/Recycling_bin
                      Looks like the most sensible thing is to simply ensure the recycling symbol is on the icon, and then give people the option of different colours.
                        DeanoNoire
                        Cool… I will look into it as soon as I dont have that much work :)
                          blackeaglece
                          Hi all, I’m having trouble getting the exact icon of the garbage collection to display with the chosen day. Example, today there is no collection but it shows me 3 icons that should not display. Also, from us the collection of organic materials occurs 3 times a week how could I put more dates for the same collection? I attach links for my icons and the code of both MMM-Dumpster and config.js
                          img garbage
                          Glass, Paper, Organic, Plastic and Other Garbage
                          config.js file MM
                          MMM-Dumpster file
                          Thank you
                          B D 2 Replies Last reply Reply Quote 0
                            blackeaglece @blackeaglece
                            @blackeaglece does anyone know how to fix date display error in images?
                              @blackeaglece I’m quite certain you have to create functions and instances for every landscape reccuring date. Act like second and third landscape instances are different kind of trash with the same image.
                              B 2 Replies Last reply Reply Quote 0
                                blackeaglece @DeanoNoire
                                @deanonoire said in MMM-DumpsterDay:
                                Hi, but it doesn’t display me landscape but glass or organic. I created a new instance called landscape1 but it still shows me all the images . This is the code of config.js. How can I do?
                                	module:"MMM-DumpsterDay",
                                	position:"top_left",
                                	header: "Raccola Differenziata",
                                		refreshInterval: 18000000, // Default: 18000000 = 5 hours
                                		pulse: false, 			   // Default: true - Makes the module pulsating
                                	enableBasic: true, 				// Abilita indifferenziata trashcan
                                		basicStartDate: "09.04.2021", 		// The first dumpster day (Always use 2 digit dates (01 instead of 1))
                                		basicDateDiff_1: 7,			// Trashday reoccurance - Default: 14 (every 14 days)
                                		basicNotifyDayBefore: true,		//Default: true - If you want the notification to appear also the day before the dumpster day
                                	enablePaper: true,			// Abilita bidoncino carta bianco
                                		paperStartDate: "06.04.2021",
                                		paperDateDiff_1: 7,
                                		paperNotifyDayBefore: true,
                                	enablePlastic: true,			// Same values as basic but for Plastic
                                		plasticStartDate: "13.04.2021",
                                		plasticDateDiff_1: 7,
                                		plasticNotifyDayBefore: true,
                                	enableVetro: true,			// Same values as basic but for Plastic
                                		vetroStartDate: "08.04.2021",
                                		vetroDateDiff_1: 7,
                                		vetroNotifyDayBefore: true,
                                	enableLandscape: true,			// Abilita bidoncino umido
                                		landscapeStartDate: "04.04.2021",
                                		landscapeDateDiff_1: 7,
                                		landscapeNotifyDayBefore: true,
                                	enableLandscape1: true,			// Abilita bidoncino umido
                                		landscape1StartDate: "06.04.2021",
                                		landscape1DateDiff_1: 7,
                                		landscape1NotifyDayBefore: true,
                                and this is how it is displayed
                                  @blackeaglece I see. What is in the log? There should be evaluations if its trashday or not.
                                  Also can you inspect the elements if .non_today class is present on the divs? If yes, check if the css file is loaded properly, as it should be hiding the images when it’s not dumpster day.
                                  https://github.com/DeanoNoire/MMM-DumpsterDay/blob/master/MMM-DumpsterDay.css
                                    @deanonoire Ok now it’s all ok i was wrong, some lines of css code had disappeared
                                    Thank you very much
                                      @blackeaglece Glad I could help ;) stay safe ;)
                                        Thank you :ok_hand:
                                          @deanonoire How do I create instances and functions? Also, to make them work, do I have to create different images even if they serve the same thing? e.g. landscape.png landscape-1.png and landscape-2.png, with relative css code?
                                          thank you very much
                                            Dinschal
                                            Hi Deanonoire,
                                            is it possible to show the can only the day before collecting? In Germany we put our trash cans outside the day before. So the notification on the collection day is not nessesary?
                                            Greetings
                                            • 4 / 5
