    MMM-Lunartic not working
    17 Posts 6 Posters 6.4k Views 6 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor
      Hi, I think the website is down…
      Anyone the same Problem
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @Stoffbeuteluwe
        @Stoffbeuteluwe said in MMM-Lunartic not working:
        Yes, the US Naval Obvservatory api that supplies the images is down. This happened once before and I’ve included a temporary fix MMM-Lunartic.js file in the repo for just such an occasion. Rename your current MMM-Lunartic.js file to MMM-Lunartic.bak and copy the file from the temporary fix folder and paste it at the root of the MMM-Lunartic folder. Run your mirror.
        I will notify when the api is up. It might be April before that happens but the module will work as expected.
        StoffbeuteluweS 1 Reply Last reply Reply Quote 1
        • C
          chassain 0
          it’s working for me…
          • Mykle1M
            • StoffbeuteluweS
              Stoffbeuteluwe Project Sponsor @Mykle1
              @Mykle1 Thank you very much :folded_hands_medium_skin_tone:
              • Mykle1M
                Thank you very much
                Can you verify that the fix works for you?
                • StoffbeuteluweS
                  @Mykle1 Works :thumbs_up_medium_skin_tone:
                  • B
                    BD0G
                    Works! April till its operational? Thats ~6 months from now.
                    • Mykle1M
                      Mykle1 Project Sponsor Module Developer @BD0G
                      @BD0G said in MMM-Lunartic not working:
                      The module works with the fix I’ve provided. You won’t notice the difference, but yes, the USNO api is undergoing maintenance and has set that date for its completion.
                      F 1 Reply Last reply Reply Quote 1
                      • F
                        ForeverBrewing @Mykle1
                        @Mykle1 Thank you for the fix! and for the module, its awesome
                        • B
                          BD0G
                          So you just pulled the static images from that USNO site and have them stored locally on the Pi. Then just call each static image as the phases of the moon change. Correct? With this approach it hardly seems like we are missing anything by not connecting to the USNO site and downloading them.
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @ForeverBrewing
                            @ForeverBrewing said in MMM-Lunartic not working:
                            Thank you for your kind words. I’m glad you enjoy it! :thumbsup:
                            • Mykle1M
                              Visually, you’re not missing much. There is not a static image for every percentage of illumination, whether waxing or waning but it will do for now. However, I like knowing that the images are the most recent even though you can’t see a difference. When the API resumes, I’ll switch back. The fix will always be available. You can continue to use it even when the API resumes.
                              • D
                                djarufes
                                This post is deleted!
                                • D
                                  djarufes @Mykle1
                                  @Mykle1 After making the changes mentioned, for some odd reason, I’m just getting “When the Moon hits your eye…”
                                  Not sure how to fix it :/
                                  • Mykle1M
                                    Mykle1 Project Sponsor Module Developer @djarufes
                                    @djarufes
                                    The only change is swapping the MMM-Lunartic.js file with the one that is in the temporary fix folder.
                                    • D
                                      djarufes @Mykle1
                                      @Mykle1 It seems that changing single quotes to double quotes in the lines below made it work:
                                      module: ‘MMM-Lunartic’,
                                      position: ‘bottom_center’ ,
                                      module: “MMM-Lunartic”,
                                      position: “bottom_center” ,
                                      Not sure why, but thanks! The moon looks incredible O_O
                                      • Mykle1M
                                        @djarufes said in MMM-Lunartic not working:
                                        Glad you got it working. The config sample entry in the repo does not have double quotes on those so I don’t know where you got them from. :-)
