    config
    57 Posts 9 Posters 26.6k Views 7 Watching
      BD0G
      Stick with it! Its a great learning experience. Just take your time and dont rush.
      Here is how you post your config entries.
      Open the MagicMirror/config/config.js file in a text editor. Highlight the entries in the config file. CTRL-C or copy command. Then come back to the forum and start a reply post. When you want to paste your code click on the little </> icon above the post. You will see a notification in the posting then that reads Code Here. Highlight that Code Here and choose CTRL-V or paste command. That will paste the code. Choose Submit! Done.
      • G Offline
        geo
        code_text
        ```/* Magic Mirror Config Sample
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: "en",
        	timeFormat: 24,
        	units: "metric",
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_left"
        			header: "GB Holidays",
        						symbol: "calendar-check",
        						url: "webcal://www.calendar/embed?src=en.uk%23holiday%40group.v.calendar.google.com"					}
        			module: "compliments",
        			position: "lower_third"
        			module: "currentweather",
        			config:
        				locationID: "53.9576",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        				appid: "76b503a29647f3a01dd9ba1055daea6d",
        			module: "weatherforecast",
        			header: "Weather Forecast",
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title:  "BBC",
        						url: "http://WWW.BBC.com/services/xml/rss/bbc/HomePage.xml",
        				showSourceTitle: true,
        				showPublishDate: true,
        				broadcastNewsFeeds: false,
        				broadcastNewsUpdates: true,
        brobergB S 2 Replies Last reply Reply Quote 0
        • brobergB Offline
          broberg Project Sponsor @geo
          you were missing a { after config: under the module currentweather
          and also one to many , under the module weatherforecast
          Corrected code :
            sdetweil @geo
            @geo said in config:
              	config:
            should be
            			config:  {    // < ---- missing open brace
            this
            should be
            				//,   < ---  remove extra comma
            • G Offline
              geo
              hi and thx again.still no joy and i have poated the latest config```
              code_text
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: "en",
              	timeFormat: 24,
              	units: "metric",
              			module: "alert",
              			position: "top_bar"
              			module: "clock",
              			config:  {
              			module: "newsfeed",
              			config:
              				feeds: [
              						title:  "BBC",
              S L 2 Replies Last reply Reply Quote 0
                sdetweil @geo
                @geo missing the /* as the 1st line
                  @geo here is the fixed up config
                  run thru npm run config:check til no errors
                  missing comma and open {
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	language: "en",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "alert",
                  			position: "top_bar"
                  			module: "clock",
                  			config:  {
                  			module: "newsfeed",
                  				feeds: [
                  						title:  "BBC",
                  G 2 Replies Last reply Reply Quote 0
                  • G Offline
                    geo
                    npm ERR!     /home/pi/.npm/_logs/2019-11-16T14_09_4
                    code_text
                      sdetweil @geo
                      @geo needs to be done from inside the MagicMirror folder…
                      • G Offline
                        geo @sdetweil
                        @sdetweil hi after another attempt i find the config is empty all that is available is the sample
                        S G 2 Replies Last reply Reply Quote 0
                        • 6
                        • 4 / 6
