config.js
14 Posts 5 Posters 3.1k Views 4 Watching
    sdetweil @geo
    @geo unlike windows, linux is case sensitive on filenames and command names…
    here are some linux commands compared to windows
    ls = dir , LS is nothing
    cd = cd
    rm = delete
    cp = copy
    mv = move
    almost every command has help built in , using the --help parameter
    cp --help
    you can also ‘read the manual’ for commands by using the man command
    man cp (to get out its the letter q)
    in graphical mode, gedit is a pretty decent editor
    in text mode (or over ssh) i hate vi, so I use nano… but it doesn’t support mouse actions like a graphical app.
      BD0G @geo
      @geo Dont delete the full Magic Mirror image and start over!
      Thats a waste of time.
      Instead
      change directories to the Magic Mirror directory like this
      cd MagicMirror (press enter)
      then run this command
      npm run config:check (press enter)
      This will run a build in linter (which is a fancy way of saying a program that checks the entries in a file to determine if there are errors)
      Then view the results and the errors presented. Typicallly there is one symbol missing right above where the errors are reported. Pay attention to the line numbers that are listed where the errors start and look one or two lines up from that line number and see if you can perceive an issue.
      G 1 Reply Last reply Nov 29, 2019, 3:51 PM Reply Quote 0
        Mykle1 Project Sponsor Module Developer @geo
        @geo
        Here is some help with creating a working config. It’s a short read but helpful.
        https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
        • G Offline
          geo @BD0G
          @BD0G hi,great thankyou
          2 / 2
