    config.js
    14 Posts 5 Posters 4.6k Views 4 Watching
    • G Offline
      geo @bhepler
      @bhepler hi thx for that
      however when i try to copy using cp config.sample config.js i get the message no such file or directory
        sdetweil @geo
        @geo its
        cp config.sample.js config.js
        warning, its will overwrite the file on the right side of that command…
        it will NOT warn you
        u need to learn the linux commands
        so u can find files, copy , edit, create
        do a search on youtube “learn basic linux commands”
        G 2 Replies Last reply Reply Quote 1
        • G Offline
          geo @sdetweil
          @sdetweil i tried yours and that was the message got
            Mykle1 Project Sponsor Module Developer @geo
            @geo
            1. Open a new terminal
            2. type cd MagicMirror/config
            3. Press Enter key
            4. type cp config.sample.js config.js
            5. Press Enter key
            6. type cd ..
            7. Press Enter key
            8. type npm start
            9. Press Enter key
            10. Say thank you. :-)
            • G Offline
              geo @sdetweil
              @sdetweil hi looked looked a linux only recognised 4 commands.,but unless you understand code and know how to write it and what does then it means nothing to someone like me and thats why i have to ask for help.i have loaded another sd card withmm to practice but once the dreaded create a config appears i’m back to square one and have to delete mm and start again,ugh.
              cheers
              S B 2 Replies Last reply Reply Quote 0
              • G Offline
                geo @Mykle1
                @Mykle1 as they say in yorkshire " Ta very much"
                  sdetweil @geo
                  @geo unlike windows, linux is case sensitive on filenames and command names…
                  here are some linux commands compared to windows
                  ls = dir , LS is nothing
                  cd = cd
                  rm = delete
                  cp = copy
                  mv = move
                  almost every command has help built in , using the --help parameter
                  cp --help
                  you can also ‘read the manual’ for commands by using the man command
                  man cp (to get out its the letter q)
                  in graphical mode, gedit is a pretty decent editor
                  in text mode (or over ssh) i hate vi, so I use nano… but it doesn’t support mouse actions like a graphical app.
                    BD0G @geo
                    @geo Dont delete the full Magic Mirror image and start over!
                    Thats a waste of time.
                    Instead
                    change directories to the Magic Mirror directory like this
                    cd MagicMirror (press enter)
                    then run this command
                    npm run config:check (press enter)
                    This will run a build in linter (which is a fancy way of saying a program that checks the entries in a file to determine if there are errors)
                    Then view the results and the errors presented. Typicallly there is one symbol missing right above where the errors are reported. Pay attention to the line numbers that are listed where the errors start and look one or two lines up from that line number and see if you can perceive an issue.
                      @geo
                      Here is some help with creating a working config. It’s a short read but helpful.
                      https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                      • G Offline
                        geo @BD0G
                        @BD0G hi,great thankyou
