    config.js
    14 Posts 5 Posters 3.9k Views 4 Watching
    • G Offline
      geo
      hi,in this config i am unable to add a line under position in compliments to insert config.
      i can do this in config.sample and config.file which is a copy.
      can anyone explain this please.
      cheers,
      geo
      S bheplerB 2 Replies Last reply Reply Quote 0
        sdetweil @geo
        @geo sorry, don’t understand the question…
        what editor are you using on the config.js file?
        • bheplerB Offline
          bhepler Module Developer @geo
          @geo said in config.js:
          If you are using the nano editor, you can go to the end of the line above where you want to insert the new line and then press enter. That will give you a new line to play with.
          For starters, the name of the file is config.js. It has to be named exactly that in order for the system to work. So I would recommend that you copy your config.sample to config.js by entering cp config.sample config.js and then start your mirror process.
          Once you have a working config file, we can work on modifying it.
          S G 2 Replies Last reply Reply Quote 0
            sdetweil @bhepler
            @bhepler he has a working system… now wants to add more
            • G Offline
              geo @bhepler
              @bhepler hi thx for that
              however when i try to copy using cp config.sample config.js i get the message no such file or directory
                sdetweil @geo
                @geo its
                cp config.sample.js config.js
                warning, its will overwrite the file on the right side of that command…
                it will NOT warn you
                u need to learn the linux commands
                so u can find files, copy , edit, create
                do a search on youtube “learn basic linux commands”
                G 2 Replies Last reply Reply Quote 1
                • G Offline
                  geo @sdetweil
                  @sdetweil i tried yours and that was the message got
                    Mykle1 Project Sponsor Module Developer @geo
                    @geo
                    1. Open a new terminal
                    2. type cd MagicMirror/config
                    3. Press Enter key
                    4. type cp config.sample.js config.js
                    5. Press Enter key
                    6. type cd ..
                    7. Press Enter key
                    8. type npm start
                    9. Press Enter key
                    10. Say thank you. :-)
                    • G Offline
                      geo @sdetweil
                      @sdetweil hi looked looked a linux only recognised 4 commands.,but unless you understand code and know how to write it and what does then it means nothing to someone like me and thats why i have to ask for help.i have loaded another sd card withmm to practice but once the dreaded create a config appears i’m back to square one and have to delete mm and start again,ugh.
                      cheers
                      S B 2 Replies Last reply Reply Quote 0
                      • G Offline
                        geo @Mykle1
                        @Mykle1 as they say in yorkshire " Ta very much"
