    MMM-SoccerLiveScore
    Scheduled Pinned Locked Moved Sport
    187 Posts 37 Posters 306.5k Views 35 Watching
    • G Offline
      gashion @baschke
      @baschke
      When adding leagues in your config, dont add “464”. Thats for Champions League.
      • N Offline
        nem1
        I used this module in the past and I was really satisfied. After a complete reset of my mirror, I had to reinstall all modules. Unfortounatly the MMM-SoccerLiveScore is not working correctly anymore :(
                                module: "MMM-SoccerLiveScore",
                                header: "Live-Scores",
                                        leagues: [35,9,1,0],
                                        displayTime: 30 * 1000
        Whats wrong? On the mirror its shown just the header, no error-message.
        Thanks a lot.
        nem1
          Ramez @nem1
          @nem1 where did you get the 0 in leagues config? there is no leagues assigned to zero, remove it and try…
          • N Offline
            nem1 @Ramez
            @ramez
            0 is the ID for the german nationalteam.
            But for now, the module is working. But I dont know why :D
              Ramez @nem1
              @nem1 glad it’s working :) … same happened to me Here that’s because source server sometimes down
                Joeysface
                I have been messing around with this module and it is working really well. I love the way its laid out but I do have a few questions.
                • Is there anyway to not display the table for certain leagues? Someone asked already but the Champions League table only seems to be showing Group A.
                • Is there a way to change the display date format? I would like to change the format to something like MM-DD instead of DD.MM.
                • Is there maybe a way to highlight certain teams on the table and schedule? For example, If I follow a few PL teams and want their games to pop out more so that the text is bolded or highlighted for the team name.
                Thanks again for any help
                • Alex2020A Offline
                  Alex2020
                  Ma per creare un “tavolo” per la classifica di serie “A” Italiana cè un modo ?Grazie.
                  • lavolp3L Offline
                    lavolp3 Module Developer
                    Hi @LukeCodewalker I’d like to use and probably contribute to the module a bit.
                    Do you think it’s possible to show the goals and scorers of a current running game?
                    Is there an endpoint in the api for that?
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    • G Offline
                      Galaras7
                      Hi guys please I need your help …
                      ID Number Greece soccer please.
                      For My magicmirror livescore modul…
                        master117 @Galaras7
                        @Galaras7
                        if you are using my module, you can check ids here:
                        http://api.football-data.org/v2/competitions/
                        Greece ID: 2093
                        Greece sadly is not covered in the APIs free tier. So you would have to pay for it.
                        https://www.football-data.org/coverage
                        • F Offline
                          frankturban
                          Hello,
                          I am viewing the results of the 2nd Bundesliga. Unfortunately I don’t get any icons here. Is this a bug? It works for other leagues … Thank you very much …
                          • StoffbeuteluweS Offline
                            Stoffbeuteluwe Project Sponsor @frankturban
                            @frankturban same problem after MM new start or refresh browser?
                            • F Offline
                              frankturban @Stoffbeuteluwe
                              @Stoffbeuteluwe yes - but DFB-Pokal shows icons
                                dawookie1979
                                i cant find the file to download
                                • Feedy88F Offline
                                  Feedy88
                                  Looks like the Original Creator had removed the repo or his github account. Found this one, looks like it is still working: https://github.com/massi1990/MMM-SoccerLiveScore
                                    dawookie1979 @Feedy88
                                    @Feedy88 hello, i have the files and npm installed them into the module directory, but the module isnt showing up? i have it in the config file too :)
                                    • Feedy88F Offline
                                      Feedy88
                                      @dawookie1979 mh, just tried again and it works for me (takes some time to load though, maybe limit it to one league for now). Nonetheless, I removed it again and moved on with MMM-soccer as this module has the same features and more and is still being maintained by the original creator.
                                      Nonetheless, if you want tot get MMM-SoccerLiveScore running, can you post your config? I just copied the sample and it works fine.
                                        dawookie1979
                                        hello, i will remove soccerlivescore, and try MMM-soccer. Thank you for your help
                                          dave_ @Feedy88
                                          @Feedy88 hey i was wondering if u could help me setup MMM-soccer I’m having a really hard time figuring it out plzzz
                                          Feedy88F 1 Reply Last reply Reply Quote 0
                                          • Feedy88F Offline
                                            Feedy88 @dave_
                                            @dave_ Hey there,
                                            would be happy to help. What is your issue currently? Also would help to post a snippet of the config you are using.+
                                            • 6
                                            • 9
                                            • 10
                                            • 4 / 10
