    MM not starting after update
    20 Posts 3 Posters 7.7k Views 4 Watching
    • J
      jani.karna
      I updated my MagicMirror to latest version, and now it does not start.
      pm2 logs mm
      shows this:
      0|mm  | A JavaScript error occurred in the main process
      0|mm  | Uncaught Exception:
      0|mm  | Error: Cannot find module 'module-alias/register'
      0|mm  |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
      0|mm  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      0|mm  |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
      0|mm  |     at Module.require (internal/modules/cjs/loader.js:658:17)
      0|mm  |     at require (internal/modules/cjs/helpers.js:20:18)
      0|mm  |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:15:1)
      0|mm  |     at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:283:3)
      0|mm  |     at Module._compile (internal/modules/cjs/loader.js:711:30)
      0|mm  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
      0|mm  |     at Module.load (internal/modules/cjs/loader.js:620:32)
      I had a feeling I shouldn’t do this, but I did anyway. How to fix it?
        sdetweil @jani.karna
        @jani-karna how did u update?
        • D
          dicker182
          same here, I just did an
          git stash
          git pull
          in the Magicmirrir directory
            sdetweil @dicker182
            @dicker182 also need npm install
            • D
              dicker182 @sdetweil
              @sdetweil thats it. Thank you!
              • J
                jani.karna
                npm install helped me also. Thank you!
                  @jani-karna thanks, can u tell me where u got the update instructions?
                  • J
                    jani.karna @sdetweil
                    from here:
                    https://github.com/MichMich/MagicMirror#updating-you-magicmirror
                    and followed the instructions in “updating”-section. I first did the “test” update and then after no problems used the “apply” as instructed there.
                    It didn’t mention “npm install” there.
                      @jani-karna ok, the script WOULD have done the update, but it failed…
                      can u send me the MagicMirror/installers/upgrade.log?
                      same id as here on gmail…
                      thanks
                      J 2 Replies Last reply Reply Quote 0
                      • J
                        @sdetweil should be on its way now.
                        • J
                          @sdetweil is there any easy way of backing up any modified files, configs or .css files. The upgrade messed up a lot and even when I thought I had everything backed up as files there were a lot of changes I had to manually fix afterwards.
                          The upgrade process mentioned custom.css to be saved and restored after but it didn’t.
                            @jani-karna hm… there is only one file saved/restored, cause all the other files aren’t touched…
                            were u on 2.9 before? the log says 2.10, so there was a git put or something before
                            • J
                              @sdetweil no that I remember, I actually used instruction from this forum before and used “git pull” in MagicMirror directory first. After that I found the instructions I told you in the earlier post when my MM wouldn’t start. Then I tried that and when it still didn’t start I posted here.
                                @jani-karna ok, git pull yanked u up to 2.10.0 i expect
                                  @jani-karna said in MM not starting after update:
                                  there were two parts to the command
                                  git pull & npm install
                                  • J
                                    @sdetweil well actually 3 parts, as apparently I didn’t know what I was doing.
                                    1. git pull
                                    2. bash -c “$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/upgrade-script.sh)” apply
                                    3. npm install (after finding out it is needed)
                                      @jani-karna yeh, the initial instructions should have been either of these, but not both
                                      1. git pull & npm install
                                      2. use the update_script (which does all of 1 plus more)
                                      • J
                                        @sdetweil yeah… the instructions should be updated so that others won’t make same mistake as I did.
                                          @jani-karna thanks for your info…
                                            @jani-karna Mich has released new doc now
                                            see
                                            https://forum.magicmirror.builders/topic/11987/dedicated-documentation-site
