    Which modules with Home Assistant currently work?
    39 Posts 7 Posters 19.0k Views 9 Watching
    • I Offline
      iorifly
      Dear,
         I have HA working for many years. I would like to add to MM, however, I’ve tried two modules and I can not configure any … Any charitable soul, could help me in this way ??
      • C Offline
        cyberphox
        MMM-HASS works
        • I Offline
          iorifly
          I am trying to use this:
          but I am having the following problem :(:
          https://forum.magicmirror.builders/topic/11972/mmm-homeassistant-sensors-erro
          • C Offline
            cyberphox
            You are using:
            https://github.com/leinich/MMM-homeassistant-sensors
            I said this one works:
            https://github.com/aserramonner/MMM-HASS
            • I Offline
              iorifly
              I tried it, I was unsuccessful. I have no net at the moment. (Problems with a Supplier) When I return, I will try this module again. Hope it works. I will post here.
              • I Offline
                iorifly
                I am having the following problem with him.
                pi@raspberrypi:~/MagicMirror $ ^C
                > magicmirror@2.10.0 start /home/pi/MagicMirror
                > ./run-start.sh
                [21:26:31.205] [LOG] Starting MagicMirror: v2.10.0
                [21:26:31.239] [LOG] Loading config ...
                [21:26:31.258] [LOG] Loading module helpers ...
                [21:26:31.265] [LOG] No helper found for module: alert.
                [21:26:31.449] [LOG] Initializing new module helper ...
                [21:26:31.452] [LOG] Module helper loaded: updatenotification
                [21:26:31.457] [LOG] No helper found for module: clock.
                [21:26:32.663] [LOG] Initializing new module helper ...
                [21:26:32.665] [LOG] Module helper loaded: MMM-Screencast
                [21:26:34.035] [LOG] Initializing new module helper ...
                [21:26:34.037] [LOG] Module helper loaded: calendar
                [21:26:34.039] [LOG] No helper found for module: compliments.
                [21:26:35.266] [LOG] Initializing new module helper ...
                [21:26:35.268] [LOG] Module helper loaded: MMM-DarkSkyForecast
                [21:26:35.410] [LOG] Initializing new module helper ...
                [21:26:35.412] [LOG] Module helper loaded: newsfeed
                [21:26:35.524] [LOG] Initializing new module helper ...
                [21:26:35.526] [LOG] Module helper loaded: MMM-HASS
                [21:26:35.529] [LOG] All module helpers loaded.
                [21:26:35.534] [LOG] Starting server on port 8080 ...
                [21:26:35.643] [LOG] Server started ...
                [21:26:35.649] [LOG] Connecting socket for: updatenotification
                [21:26:35.654] [LOG] Connecting socket for: MMM-Screencast
                [21:26:35.659] [LOG] Connecting socket for: calendar
                [21:26:35.663] [LOG] Starting node helper for: calendar
                [21:26:35.669] [LOG] Connecting socket for: MMM-DarkSkyForecast
                [21:26:35.675] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                [21:26:35.681] [LOG] Connecting socket for: newsfeed
                [21:26:35.686] [LOG] Starting module: newsfeed
                [21:26:35.689] [LOG] Connecting socket for: MMM-HASS
                [21:26:35.693] [LOG] Sockets connected & modules started ...
                [21:26:35.696] [LOG]
                Ready to go! Please point your browser to: http://localhost:8080
                Starting chromium browser now, have patience, it takes a minute
                 --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
                events.js:174
                      throw er; // Unhandled 'error' event
                Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
                    at doWrite (_stream_writable.js:411:19)
                    at writeOrBuffer (_stream_writable.js:399:5)
                    at Socket.Writable.write (_stream_writable.js:299:11)
                    at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46)
                    at process.<anonymous> (/home/pi/MagicMirror/js/app.js:40:10)
                    at process.emit (events.js:198:13)
                    at process._fatalException (internal/bootstrap/node.js:497:27)
                ^C
                load MM, but all modules have msg of loading …
                NOTE: I was missing. Because I was without internet for 05 days.
                  dvbit @iorifly
                  what prevents you to prepare a dedicated hass lovelace tab and display that with module smartwebdisplay?
                  • I Offline
                    iorifly @dvbit
                    @dvbit said in Which modules with Home Assistant currently work?:
                    smartwebdisplay
                    I don’t know this module (smartwebdisplay). And I already have a lovelace on my tablet.
                    • I Offline
                      iorifly @cyberphox
                      @cyberphox said in Which modules with Home Assistant currently work?:
                      You are using:
                      It’s not working either.
                      https://forum.magicmirror.builders/topic/12014/erro-mmm-hass/4
                      • C Offline
                        cyberphox @iorifly
                        @iorifly What is not working? Your MagicMirror itself?
                        Or can you just not add this module?
                        Does your Mirror work fine without this module loaded?
                        S I 2 Replies Last reply Reply Quote 0
                          sdetweil @cyberphox
                          @cyberphox his problem in unrelated to module. I am debugging
                          C 1 Reply Last reply Reply Quote 1
                          • C Offline
                            cyberphox @sdetweil
                            @sdetweil I figured it might not be!
                            Thanks!!! You rock as always
                            • I Offline
                              iorifly @cyberphox
                              @cyberphox
                              Yes, my mirror works perfectly without the module.
                              I have some topics here. look at my problems:
                                sdetweil @iorifly
                                @iorifly fix reported in other topic
                                • I Offline
                                  iorifly
                                  With the help of @sdetweil , I was able to solve problems with MM.
                                  Now I am having trouble accessing HA with MMM-HASS.
                                    If anyone can help I will be happy.
                                  alt text
                                  My HA configuration looks like this configuration.yam:
                                  homeassistant:
                                    whitelist_external_dirs:
                                      - /tmp
                                      - /config/temp/
                                    auth_providers:
                                        - type: legacy_api_password
                                          api_password: "juere3027"
                                        - type: trusted_networks
                                          trusted_networks:
                                            - 192.168.1.0/24
                                            - 127.0.0.1
                                            - ::1
                                          allow_bypass_login: true
                                        - type: homeassistant
                                  config.js
                                                  module: "MMM-HASS",
                                                  position: "middle_center",
                                                          host: "192.168.1.158",
                                                          port: "8123",
                                                          apipassword: "juere3027",
                                                          hassiotoken: true,
                                                          https: false,
                                                          devices: [
                                                          { deviceLabel: "Quintal",
        deviceReadings: [
        { sensor: "sensor.caixa_dagua", icon: "mdi:waves", suffix: "%"}
                                  The mirror executes loads the other modules, but HASS does not load. I have the following output:
                                  > magicmirror@2.10.1 start /home/pi/MagicMirror
                                  > ./run-start.sh
                                  [22:26:04.896] [LOG] Starting MagicMirror: v2.10.1
                                  [22:26:04.931] [LOG] Loading config ...
                                  [22:26:04.951] [LOG] Loading module helpers ...
                                  [22:26:04.959] [LOG] No helper found for module: alert.
                                  [22:26:05.139] [LOG] Initializing new module helper ...
                                  [22:26:05.146] [LOG] Module helper loaded: updatenotification
                                  [22:26:05.151] [LOG] No helper found for module: clock.
                                  [22:26:06.647] [LOG] Initializing new module helper ...
                                  [22:26:06.650] [LOG] Module helper loaded: calendar
                                  [22:26:06.653] [LOG] No helper found for module: compliments.
                                  [22:26:07.888] [LOG] Initializing new module helper ...
                                  [22:26:07.890] [LOG] Module helper loaded: MMM-DarkSkyForecast
                                  [22:26:08.030] [LOG] Initializing new module helper ...
                                  [22:26:08.035] [LOG] Module helper loaded: newsfeed
                                  [22:26:08.129] [LOG] Initializing new module helper ...
                                  [22:26:08.133] [LOG] Module helper loaded: MMM-HASS
                                  [22:26:08.137] [LOG] All module helpers loaded.
                                  [22:26:08.143] [LOG] Starting server on port 8080 ...
                                  [22:26:08.251] [LOG] Server started ...
                                  [22:26:08.256] [LOG] Connecting socket for: updatenotification
                                  [22:26:08.261] [LOG] Connecting socket for: calendar
                                  [22:26:08.265] [LOG] Starting node helper for: calendar
                                  [22:26:08.268] [LOG] Connecting socket for: MMM-DarkSkyForecast
                                  [22:26:08.271] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
                                  [22:26:08.275] [LOG] Connecting socket for: newsfeed
                                  [22:26:08.278] [LOG] Starting module: newsfeed
                                  [22:26:08.282] [LOG] Connecting socket for: MMM-HASS
                                  [22:26:08.288] [LOG] Sockets connected & modules started ...
                                  [22:26:08.293] [LOG]
                                  [22:26:08.451] [ERROR]  { Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                                      at Server.setupListenHandle [as _listen2] (net.js:1280:14)
                                      at listenInCluster (net.js:1328:12)
                                      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1461:7)
                                      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:61:10)
                                    code: 'EADDRINUSE',
                                    errno: 'EADDRINUSE',
                                    syscall: 'listen',
                                    address: '127.0.0.1',
                                    port: 8080 }
                                  [22:26:08.444] [LOG]    Whoops! There was an uncaught exception...
                                  [22:26:08.510] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  [22:26:08.512] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                  [22:26:22.272] [LOG]    Use existing news fetcher for url: https://noticias.r7.com/rio-de-janeiro/feed.xml
                                  [22:26:22.303] [LOG]    Request URL: http://192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                                  [22:26:22.388] [LOG]    { undefined: undefined, label: 'Quintal' }
                                  • I Offline
                                    iorifly
                                    I see that the module tries to connect to the Home assistant.
                                    https://imgur.com/oHjP479
                                      sdetweil @iorifly
                                      @iorifly said in Which modules with Home Assistant currently work?:
                                      EADDRINUSE
                                      U already have some application using that port, and are trying to start another
                                      • I Offline
                                        iorifly
                                        I don’t know what it would be. It is not related to MMM-HASS.
                                        Even with a simple config.js I have this msg. I think I should restart my raspberry.
                                          sdetweil @iorifly
                                          @iorifly does mm start on boot?
                                          • I Offline
                                            iorifly
                                            Do not. I restarted and the msg stopped. Now I’m fighting with MMM-HASS.
                                            I take back what I said. He did give me more information!
                                            The mistake I have is in the development of the module. The error is in the connection of the module to the HA system.
                                            I can’t do anything but wait for the developer’s announcement.
                                            [14:23:57.773] [LOG]    Create new news fetcher for url: https://noticias.r7.com/rio-de-janeiro/feed.xml - Interval: 300000
                                            [14:23:57.895] [LOG]    { deviceLabel: 'Quintal',
                                              deviceReadings:
                                               [ { sensor: 'sensor.caixa_dagua',
                                                   icon: 'wi wi-thermometer',
                                                   suffix: '%' } ] }
                                            [14:23:57.919] [LOG]    192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                                            [14:23:57.920] [LOG]    Request URL: http://192.168.1.158:8123/api/states/sensor.caixa_dagua?api_password=juere3027
                                            [14:23:58.215] [ERROR]  (node:18860) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                            [14:23:58.440] [LOG]    null
                                            [14:23:58.443] [LOG]    401: Unauthorized
                                            [14:23:58.445] [LOG]    { undefined: undefined, label: 'Quintal' }
                                            [14:23:59.415] [LOG]    Refreshed access token because it has expired. Expired at: 14:23:57 now is: 14:23:59
                                            [14:23:59.450] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
                                            [14:23:59.487] [LOG]    Refreshed access token because it has expired. Expired at: 15:23:59 now is: 14:23:59
