    Hello-Lucy Module Microphone not working
    56 Posts 6 Posters 34.7k Views 7 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Linas123
      @Linas123
      OK, the module is loading. That’s good.
      If you run arecord test.wav in a terminal window does it record a sound file?
      L 1 Reply Last reply
      • L
        Linas123 @Mykle1
        @Mykle1 said in Hello-Lucy Module Microphone not working:
        arecord test.wav
        No it doesn’t work , there is yet the error “arecord: main:828:…”. I just noticed that my USB micro is now suddenly displayed as card 1. I change yet my /.asoundrc file again. Do I have to download the module again?
        Thank you for you fast replays.
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @Linas123
          arecord test.wav MUST work for Lucy to work.
          If you can get that to work then run arecord -l again to get your card and device numbers,
          Then enter those in the microphone config entry and run MM again
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @Mykle1
            @Mykle1
            You do NOT have to download the module again
            • L
              Linas123 @Mykle1
              @Mykle1
              It’s still the same as earlier. At the top is still the crossed-out green flashing microphone.
              • Mykle1M
                @Linas123
                Did you get arecord test.wav to record a sound file?
                I’m confused. Is it still reporting card 1?
                Did you make the changes to your config microphone option?
                How long are you waiting before quitting MM when you see thecrossed-out green flashing microphone?
                • L
                  Linas123 @Mykle1
                  @Mykle1
                  I’am confused too. It’s still card 1, when I enter “arecord -l”. When the Magic Mirror runs in the background and I enter “arecord test.wav” the Error “arecord: main:828: audio open error: Device or resource busy” appears. But, when I stop the Magic Mirror with pm2, record works. After reboot the Magic Mirror is yet on the top a micro icon and "Ready, “Hello Lucy”. But when I try to ask she, nothing happens. To you have a answer for this?
                    sdetweil @Linas123
                    @Linas123 said in Hello-Lucy Module Microphone not working:
                    and you say
                    ‘Hello Lucy’
                    right?
                    • L
                      Linas123 @sdetweil
                      Yes, of course. I tried it again. I shouted into the microphone, although “ERROR” was displayed and Lucy reacted. But when I tried to hide the news, it took a very long time. When I tried to continue, Lucy reacted once out of 10 and in between she always showed ERROR. Can I do something that she understand me better and that the delay is not so long.
                        sdetweil @Linas123
                        @Linas123 I don’t know. Was just trying to help.
                        Lots of times users didn’t know to say hello Lucy.
                        What language do you speak? Sometimes the language model cannot detect the intonation
                        • L
                          Linas123 @sdetweil
                          I speak with a german accent.
                          • L
                            Linas123
                            Thank you for all your help and your fast replays. Now it finally works with long charging times, but it works. Whenever I stop the Magic Mirror with pm2, the card for the microphone changes, but I can live with that because soon it will hang on the wall and then I won’t stop pm2.
                              sdetweil @Linas123
                              do you mean response times? (time from speak to action)
                              charging in english applies to batteries.
                              what pi device are you using?
                              • L
                                Linas123 @sdetweil
                                Sorry, I’am only just 16 years old and not so good in english. I mean response time and use the RPI 3b+.
                                  sdetweil @Linas123
                                  a LOT better than my german!!
                                  wonder what else is running. 3b+ is usually pretty good
                                  do you use SSH to connect to pi?
                                  if so, can you do top command to see what is running?
                                  • L
                                    Linas123 @sdetweil
                                    I use realVNC to see what is on my Mirror.
                                      sdetweil @Linas123
                                      @Linas123 can u minimize mirror (alt-spacebar, n)
                                      and then run top in a terminal window (ctrl-alt-t)
                                      ctrl-c to exit top
                                      • L
                                        Linas123
                                        Maybe I just think that response time is slow, although it is fast for a cheap computer like the raspberry.
                                        by top:
                                        top - 15:54:46 up  1:12,  2 users,  load average: 0,08, 0,10, 0,09
                                        Tasks: 145 total,   3 running, 142 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s):  2,5 us,  2,0 sy,  0,0 ni, 95,3 id,  0,0 wa,  0,0 hi,  0,2 si,  0,0 st
                                        MiB Mem :    925,6 total,    165,2 free,    428,2 used,    332,2 buff/cache
                                        MiB Swap:    100,0 total,     99,5 free,      0,5 used.    440,4 avail Mem
                                          PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
                                          439 root      20   0  158332  53688  36872 R   4,6   5,7   1:22.03 Xorg
                                          412 root      20   0   49124  32660  17316 R   3,3   3,4   1:35.48 vncserver+
                                         1196 pi        20   0   85152  27404  22580 S   3,3   2,9   0:03.96 x-termina+
                                         1171 root      20   0       0      0      0 I   1,7   0,0   0:00.67 kworker/u+
                                           69 root     -51   0       0      0      0 S   1,0   0,0   0:05.78 irq/86-mm+
                                          459 root      20   0   19576  12284  11788 S   1,0   1,3   0:10.49 vncagent
                                         1211 pi        20   0   10188   2840   2472 R   0,7   0,3   0:00.43 top
                                          911 pi        20   0  544920 150124  81960 S   0,3  15,8   2:31.64 electron
                                          951 pi        20   0  385260 116832  54260 S   0,3  12,3   1:23.20 electron
                                         1127 root      20   0       0      0      0 I   0,3   0,0   0:00.11 kworker/3+
                                         1176 root      20   0       0      0      0 I   0,3   0,0   0:00.44 kworker/0+
                                            1 root      20   0   33732   7972   6412 S   0,0   0,8   0:03.68 systemd
                                            2 root      20   0       0      0      0 S   0,0   0,0   0:00.01 kthreadd
                                            3 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_gp
                                            4 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 rcu_par_gp
                                            8 root       0 -20       0      0      0 I   0,0   0,0   0:00.00 mm_percpu+
                                            9 root      20   0       0      0      0 S   0,0   0,0   0:00.12 ksoftirqd+
                                          sdetweil @Linas123
                                          @Linas123 cool, thx… nothing running really…
                                          i also didn’t like the realtime responsiveness of the pi (til pi4)
                                          and bought odroid and jetson nano to get more speed.
                                          • L
                                            Linas123 @sdetweil
                                            That’s a cool idea, but I don’t like to change anything on the hardware. I keep that in mind for my next project.
                                            • 2 / 3
