    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 107.7k Views 25 Watching
      A Former User
      MMM-AssistantMk2 v3.2.1
      NEW UPDATES
      3.2.1 (16/04/2020)
      • FIX: Send A2D response only on no hooked response
      • FIX: repository change owner
      • ADD: preprared recipe with-radio_fr.js recipe for A2D Radio (FR Only)
      • ADD: npm run rebuild -> REFRESH installation on MagicMirror version change
      3.2.0 (09/04/2020)
      • ADD: Chinese_simplified translate (thx to @wlmqpsc)
      • ADD: ability to play personnal sound on recipes soundExec command (see wiki)
      • FIX: no fade in animation on first use in Fullscreen ui
      • DEL: full addon code and cleanning
      • ADD: add control if A2D used
      3.1.2 (17/03/2020)
      • FIX: No sound response issue when custom action is used.
      • FIX: correct youtube search link.
      • ADD: Add A2D stop command (beta)
        A Former User
        we are now in v3.2.2 because i detect a problem in installation (package conflict and solved)
        • C
          costascontis
          using the latest module + MMM-Hotword and everything works exept controling MMM-Spotify by voice.I use the prepared recipe for it ,MMM-Spotify is showing whatever is playing allright but no voice command is working. My config:
                                 module: "MMM-AssistantMk2",
                                          ui: "Classic",
                                          assistantConfig: {
          						  projectId: "kitchen-tv-d4c48", // Required to use gaction.
                                                            modelId: "kitchen-tv", // (OPTIONAL for gaction)
                                                            instanceId: "kitchen-tv", // (OPTIONAL for gaction)
                                                            latitude: 37.975342,
                                                            longitude: 23.736151,
                                                      micConfig: {
                                                      recorder: "arecord",
          			                    device: "plughw:1"
                                                    recipes: [ "with-MMM-Hotword.js", "Reboot-Restart-Shutdown.js", "with-MMM-Spotify.js" ],
                                                    profiles: {
          					   "default": {
        profileFile: "default.json",
        lang: "en-US"
                                                      useA2D: false,
                                  module: "MMM-Hotword",
                                  position: "bottom_left",
                                  useDisplay: false,
                                  chimeOnFinish: null,
                                  recipes: ["with-AMk2v3_Jarvis.js"],
                                  mic: {
          			recordProgram: "arecord",
                                  device: "plughw:1",
          			module: "MMM-Spotify",
          				 style: "mini", // "default" or "mini" available
                                           control: "hidden", //"default", "hidden" available
                                           updateInterval: 1000,
                                           onStart: null, // disable onStart feature with `null`
                                           allowDevices: [], //If you want to limit devices to display info, use this.
                                           // allowDevices: ["RASPOTIFY", "My iPhoneX", "My Home speaker"],
          ? A 2 Replies Last reply Reply Quote 0
            A Former User @costascontis
            @costascontis : MMM-Spotify and recipes have an issue @eouia will solve it soon.
            I can’t inspect it, because I have no premium account
            • C
              costascontis @Guest
              @Bugsounet said in MMM-AssistantMk2 (v3):
              oh!!! need to have premium account on spotify to work?i dont…
                @costascontis
                You should be a premium member of Spotify
                • C
                  costascontis @Guest
                  @Sean said in MMM-AssistantMk2 (v3):
                  @costascontis
                  so as a free member on Spotify i can use MMM-Spotify to see what is playing but i can not control it by voice?
                    @costascontis said in MMM-AssistantMk2 (v3):
                    Hmmm. I didn’t test. but there is a possibility not to use any feature (Because some API’s are tied together, so I’m not sure)
                    • C
                      costascontis @Guest
                      @Sean i did so as a free member i can only see what’s playing,album photo an info about song,artist and device playing.I only cant control anything.
                        Notes: it’s not related to MMM-Spotify but it’s Spotify Api want that
                        • A
                          amsuvarna27 @costascontis
                          This post is deleted!
                            A Former User
                            MMM-AssistantMk2 v3.2.3
                            NEW UPDATES
                            3.2.3 (30/04/2020)
                            • ADD: New ui -> Simple
                            • OPT: Optional Build with Snowboy embed
                            • ADD: A2DStopCommand for personalize your stop command (Assistant2Display Server)
                            • FIX: some logs
                            3.2.2 (17/04/2020)
                            • FIX: Package.json (google-assistant)
                            E 1 Reply Last reply Reply Quote 1
                            • E
                              electros Project Sponsor @Guest
                              @Bugsounet Hi, I installed this module and A2D module and it’s working fine just few small problems:
                              1 When I want to use this module with A2D and the answer is coming on the screen all the modules is go hiding and its coming back on the screen after 1 minute. If I use without A2D everything works fine and the modules just go blurred behind of the answer window and come back fast.
                              2 it’s try to use that radio recipe but I can’t manage to start any radio station. I don’t know how it’s work. Every time when the assistant understands station name he look on the Internet to find information about that radio station but never want to start listening. I must install something else ?
                              Apart of this everything it’s fine and the module it’s brilliant. Thank you for this.
                                A Former User
                                hi @electros
                                1. i think you forget MagicMirror configuration part
                                  Read here
                                2. i have prepare a guide for create it
                                  Read here
                                but it’s not finish … there is some surprise again … if i have a lot of time ;)
                                • E
                                  @Bugsounet
                                  Hello again. I tried what you recommended but without much success. First I made the settings for A2D as you recommended and now when I ask something after the assistant answers me an internet window opens with reference to the answer this being a new and very good thing. But when the assistant starts saying the answer, it hides the modules on the screen apart of calendarext. I was talking about this in the post above. I put a short video on youtube.
                                  https://youtu.be/DOIkuA60tKo
                                  As for the radio, I tried after that tutorial but without success.
                                  I tried to use that file “with-radio_fr.js” but when I say “cheriefm” the assistant shows me the website of the radio station “cheriefm” saying “here is what I found on the web” without starting the radio station.
                                  Thank you.
                                    A Former User
                                    @electros said in MMM-AssistantMk2 (v3):
                                    it’s a know bug of calendarext
                                    ah … “cheriefm” is the name of the block (like a landmark)
                                    the think to say is “mets chérie fm” in the sample.
                                    you can try to change it for your language with pattern value
                                    exemple: if you change pattern value to radio test
                                    if you say : radio test it will reconize the cheriefm command and execute it (send to A2D mp3 link of the radio and img)
                                    E 2 Replies Last reply Reply Quote 0
                                    • E
                                      okay but couldn’t remain all the modules on the screen behind the assistant window?
                                      Well I need to practice more with this. for a start I think I should look for another microphone, the assistant doesn’t really understand what I’m saying.
                                      Do you think a respeaker board with 2 microphones would be better than a USB microphone?
                                      SergeS 1 Reply Last reply Reply Quote 0
                                      • SergeS
                                        Serge @electros
                                        One possible solution for mic
                                        Working on getting a good hardware solution for MMM-AssistantMK2
                                        • E
                                          electros Project Sponsor @Serge
                                          @Serge Thank you for the link i was looking for a solution like that.
                                          • J
                                            jimmydew
                                            Hey everyone, I have a problem with the MMM-assistantMk2:
                                            The Icon is showing on the mirror, when i click on it in VNC it activates,and works. but it doesnt activate by my voice on the mirror.
                                            any ideas? these are my configs:
                                            var config = {
                                            	port: 8080,
                                            	language: "en",
                                            	timeFormat: 24,
                                            	units: "metric",
                                            			     // false, default for all  NON-armv6l devices
                                            			module: "clock",
                                            			position: "top_left"
                                            			header: "US Holidays",
                                            						symbol: "calendar-check",
                                            						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                                            			module: "compliments",
                                            			position: "lower_third"
                                            			module: "currentweather",
                                            				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                            				appid: "YOUR_OPENWEATHER_API_KEY"
                                            			module: "weatherforecast",
                                            			header: "Weather Forecast",
                                            				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                            			module: "newsfeed",
                                            			position: "bottom_bar",
                                            				feeds: [
                                            						title: "New York Times",
                                            				showSourceTitle: true,
                                            				showPublishDate: true,
                                            				broadcastNewsFeeds: true,
                                            				broadcastNewsUpdates: true
                                                debug: false,
                                                ui: "Classic", // Classic2, Classic or Simple
                                                // if you want Google Nest ui style
                                                // set Fullscreen ui AND fullscreen_above position
                                                assistantConfig: {
                                                  projectId: "", // Required to use gaction.
                                                  modelId: "", // (OPTIONAL for gaction)
                                                  instanceId: "", // (OPTIONAL for gaction)
                                                  latitude: 52.0955919,
                                                  longitude: 4.4711253,
                                                responseConfig: {
                                                  useHTML5: true, // sound render by HTML5
                                                  useScreenOutput: true,
                                                  useAudioOutput: true,
                                                  useChime: true,
                                                  timer: 5000,
                                                  myMagicWord: true,
                                                  //Your prefer sound play program.
                                                  //By example, if you are running this on OSX, `afplay` could be available.
                                                  //by default mpg321 play program is enabled
                                                  //if audio output cutting try with mpg123 or cvlc program
                                                  playProgram: "mpg321",
                                                  chime: {
                                                    beep: "beep.mp3",
                                                    error: "error.mp3",
                                                    continue: "continue.mp3",
                                                    open: "Google_beep_open.mp3",
                                                    close: "Google_beep_close.mp3",
                                                  // false - animated icons, 'standby' - static icons only for standby state, true - all static icons
                                                  useStaticIcons: false
                                                micConfig: { // put there configuration generated by auto-installer
                                                  device: "plughw:1",
                                                customActionConfig: {
                                                  autoMakeAction: false,
                                                  autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                                                  actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
                                                recipes: [ "with-MMM-TelegramBot.js" ],
                                                profiles: {
                                                  "default": {
                                                    lang: "en-US"
                                                useA2D: false,
                                                A2DStopCommand: "stop",
                                                useSnowboy: true,
                                                snowboy: {
                                                  audioGain: 2.0,
                                                  Frontend: true,
                                                  Model: "jarvis",
                                                  Sensitivity: null
                                            (it’s running on raspberry pi 4b)
                                            • 6
                                            • 7
                                            • 4 / 7
