    Help on reading in a text file from a Google Drive
    7 Posts 4 Posters 1.4k Views 4 Watching
    • B
      bobguehne
      Trying to write a module that will display my recipes that I have stored on my google drive. I have a Categories Text file and then a folder for each category of recipe. Reading in the Categories text file has proven difficult. Any help or examples? How do you specify a local path for XMLHttpRequest? Is that the right way to go? My gdrive is mounted at /home/pi/mnt/gdrive. Any help is appreciated.
        sdetweil @bobguehne
        @bobguehne the local mm web server starts at ~/MagicMirror
        You cannot see local files outside this path
        Make a link to that mount in your module folder, using the ln command
        Reply Quote 1
        • B
          bobguehne
          Hey! Thank you so, so, so much! FINALLY got it working! Yay! On to the next problem…
            sdetweil @bobguehne
            @bobguehne cool. Have fun!
            • T
              ToastyRoshi
              Any chance of sharing module?
              B Mykle1M 2 Replies Last reply
              • B
                bobguehne @ToastyRoshi
                @ToastyRoshi Maybe when it’s done. I have a long way to go.
                • Mykle1M
                  Mykle1 Project Sponsor Module Developer @ToastyRoshi
                  @ToastyRoshi said in Help on reading in a text file from a Google Drive:
                  While you’re waiting you can check this one out. I think it’s fantastic.
                  https://github.com/cowboysdude/MMM-Recipe
