MMM-Lunartic only a picture when static
MMM-Lunartic only shows a picture of the moon when the image is static
image: "static", // animation, current, DayNight or staticNo other option is working.
@shgmongohh said in MMM-Lunartic only a picture when static:
animation and static are both working. I just tested them both.
DayNight is out of order until the API resumes normal operation (April)
current will work if you replace the MMM-Lunartic.js file with the one that is in the temporary fix folder that is inside the MMM-Lunartic folder. (But the other three won’t until the API resumes normal operation in April)
@sdetweil - Don’t say you told me so! :-)
@Mykle1 Thanks its working
Thanks its working
Cool. I’ll make an announcement when the API is working correctly. Thanks for your interest in the module. :thumbsup:
Kindly mark the topic as solved. :-)
