    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 173.8k Views 19 Watching
      JJW @sdetweil
      @sdetweil said in MMM-Fitbit2:
      npm install -g npm@6.14.10
      Will try now, thank you very much.
        JJW @sdetweil
        @sdetweil Thank you for your help, have the Fitbit module displaying on the monitor now, however, just says loading.:grinning_squinting_face:
          sdetweil @JJW
          @jjw now we need to look for messages in the place u start MM
          npm start or pm2, if pm2, then the pm2 logs --lines=100 command will show
          and the developers window on the MM screen
          ctrl-shift-i, select the console tab, and add part of the module name to the filter field , fit
          J 2 Replies Last reply Reply Quote 0
            JJW @sdetweil
            @sdetweil I ran “pm2 logs --lines=100” in the command line and the only returns I got were for the calendar.
            0|MagicMir | [05.06.2021 18:31.09.798] [INFO] Calendar-Fetcher: Broadcasting 10 events.
            I’m sorry I don’t know what you mean by developer window, but when I use ctrl+shift+i out of the cmd I take a screenshot and then when I’m in the cmd I just rename the box.
              JJW @sdetweil
              @sdetweil I ran another test for 1000 line and the only mention of Fit is:
              0|MagicMir | [05.06.2021 18:22.00.914] [INFO] Checking git for module: MMM-Fitbit2
              After that, it moves onto multicast.
                sdetweil @JJW
                @jjw on the magicmirror screen, not commandline
                press ctrl-shift-i together
                a new window will open 1/2 the Mm screen
                in that window there is a tabbed interface,
                here showing error from one of my modules, part of name in filter field
                  JJW @sdetweil
                  @sdetweil Ah, I think because I’m accessing my Pi via VNC viewer, that’s what makes it take a screenshot instead of opening that menu, even when on the MM screen, is there another way to access this? If not work directly through the Pi.
                    sdetweil @JJW
                    @jjw well, you could access from your pc, if the address/ipWhitelist settings in config.js allow it
                    then use chrome to view and open the dev window
                      JJW @sdetweil
                      @sdetweil This is what comes up when I filter by fit
                        sdetweil @JJW
                        @jjw ok, now you know everything I know.
                        no errors were reported.
                          JJW @sdetweil
                          @sdetweil Thank you for the continued help, really appreciate you taking the time. One last thought, I’ve gone through the processes again, and one of the dependencies, “python-fitbit” requires you to run
                          sudo pip install -r requirements/base.txt
                          When I run this code, I get the error message
                          Could not open requirements file: [Errno 2] No such file or directory: ‘requirements/base.txt’
                          S V 2 Replies Last reply Reply Quote 0
                            sdetweil @JJW
                            @jjw what folder are u supposed to be in when u run that command?
                              JJW @sdetweil
                              @sdetweil Unfortunately it doesn’t say so I’ve just tried running in and out of the Fitbit directory.
                              https://github.com/m-roberts/MMM-Fitbit2
                              redirects you to this webpage
                              https://pypi.org/project/fitbit/0.3.1/
                              and I can’t see anywhere it says what folder to install it into.
                              • V Offline
                                Vizulize Module Developer @JJW
                                @jjw Running init.sh inside the MMM-Fitbit2 folder should take care of installing the dependencies for you.
                                  JJW @Vizulize
                                  @vizulize I’ve done that, unfortunately still just have loading.
                                    Dresch360 Project Sponsor
                                    Entered all of the required information in the Fitbit application registry.
                                    At the ./auth.sh process, entered correct “Client ID” and “Client Secret” and I get the following after Allowing full access during authentication process:
                                    **Fitbit
                                    The app you’re trying to connect did not provide valid information to Fitbit. Please report this issue to them.
                                    Developer information: invalid_request - Missing parameters: client_id**
                                    Any help would be greatly appreciated!
                                      Also - attempted to authorize and obtain token directly from the Fitbit site using their token authenticator from the “OAuth 2.0 tutorial page” and I received the error message below:
                                      404 Not Found
                                      Missing parameters: state
                                      Traceback (most recent call last):
                                      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 54, in call
                                      return self.callable(*self.args, **self.kwargs)
                                      TypeError: index() missing 1 required positional argument: ‘state’
                                      During handling of the above exception, another exception occurred:
                                      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 628, in respond
                                      self._do_respond(path_info)
                                      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 687, in _do_respond
                                      response.body = self.handler()
                                      File “/usr/local/lib/python3.7/dist-packages/cherrypy/lib/encoding.py”, line 219, in call
                                      self.body = self.oldhandler(*args, **kwargs)
                                      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 60, in call
                                      raise sys.exc_info()[1]
                                      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 58, in call
                                      test_callable_spec(self.callable, self.args, self.kwargs)
                                      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 157, in test_callable_spec
                                      raise cherrypy.HTTPError(404, message=message)
                                      cherrypy._cperror.HTTPError: (404, ‘Missing parameters: state’)
                                        sdetweil @Dresch360
                                        @dresch360 looks like something changed in the api requirements, but the library version hasnt
                                          @sdetweil - Thanks for your reply. So does this mean that no new tokens can be created?
                                            richmp95
                                            any chance of this being revived and updated?
                                            • 4 / 5
