    Problems with my Config file
    12 Posts 4 Posters 4.3k Views 4 Watching
    • O Offline
      Omensch
      Hey guys,
      I just refound my old pi and now I am trying to create a MagicMirror. I came pretty far now I have a problem with my config file.
      If you could help me it would be great :D
      Thanks for your help.
      /* Magic Mirror Config Sample
      * MIT Licensed.
      var config = {
         port: 8080,
         ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
         language: 'de',
         timeFormat: 24,
         units: 'metric',
         		module: 'alert',
         		module: "updatenotification",
         		position: "top_bar"
         		module: 'clock',
         		position: 'top_left'
         		module: 'MMM-DWD-WarnWeather',
         		position: 'top_left',
         		header: 'DWD Wetterwarnungen',
         			region: 'Rhein-Neckar-Kreis und Stadt Heidelberg',
         			changeColor: true,
         			interval: 5 * 60 * 1000, // every 5 minutes
         			longversion: true,
         			loadingText: 'Warnungen werden geladen...',
         			noWarningText: 'Keine Warnungen'
         		module: 'currentweather',
         		position: 'top_right',
         			locationID: '2907911',  //ID from http://www.openweathermap.org
         			appid: 'd8b2c41a44ce77e3c34237894cbf055b'
         		module: 'weatherforecast',
         		header: 'Weather Forecast',
         		module: 'newsfeed',
         		position: 'bottom_bar',
         			feeds: [
         					title: "Sport",
         					url: "http://www.sport1.de/news.rss"
         			showSourceTitle: true,
         			showPublishDate: true
         		module: 'newsfeed',
         			feeds: [
         					title: "Tagesschau",
         					url: "http://www.tagesschau.de/xml/rss2"
         		module: 'newsfeed',
         			feeds: [
         					title: "Heise News",
         					url: "https://www.heise.de/newsticker/heise-atom.xml"
         		header: "Events",
         					symbol: "calendar-check-o ",
         					url: "https://calendar.google.com/calendar/embed?src=h5gvpq6g8rhfk2lbu8n70rc71g%40group.calendar.google.com&ctz=Europe%2FBerlin"
           module: "MMM-NowPlayingOnSpotify",
           position: "top_bar",
             clientID: "69f1b99772754d889d9a7542303fbe1e",
             clientSecret: "*******************************",
             accessToken: "BQA_OLriFvy1ORb-Um55wNFHQE5Mw9yhqoVINvkTUlBD-HYL9So_WEJz4vh5lDGW1nAiTjWnZa0x0hq5PWWMIrrGl4XtEAOl6ErU5bCxsb4hCEAAFH7PT5uXFBO6ni_cDM8ODEutvTHyuNLsHoceZQ",
             refreshToken: "AQBr-Ft2KPpjCERS1jfHdcg74gKlnL_otE4NKKVCGeVL3_0a-5G7L1AeBu8RHaZsowLV6pOAlaiLduave_Ea1nVBuxbdGKr8iYiSQ4XbHLybk-fSvVOYgoXTocQIwUUAK0o"
      • E Offline
        EdO
        What kind of problem are you having? Have you run:
        npm run config:check
        to see if there are any syntax errors?
        • O Offline
          Omensch
          well I don’t know what this really means.
          do you have an idea?
          pi@raspberrypi:~ $ npm run config:check
          npm ERR! Linux 4.4.50-v7+
          npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "run" "config:check"
          npm ERR! node v6.17.1
          npm ERR! npm  v3.10.10
          npm ERR! path /home/pi/package.json
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR! syscall open
          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is most likely not a problem with npm itself
          npm ERR! enoent and is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR!     /home/pi/npm-debug.log
          • O Offline
            Omensch @EdO
            @EdO my problem is that when I run MM, it sais: please create config file
              sdetweil @Omensch
              @Omensch please, run that in the MagicMirror folder
                sdetweil @Omensch
                @Omensch I ran config:check and don’t see any errors…
                what problem are u having?
                • E Offline
                  EdO
                  I’m not seeing anything jump out at me though I’m not familiar with all of your modules. If the config:check doesn’t show any errors, then you need to go through each module definition to make sure it is correct.
                  You can go through each one checking the documentation as you go or you can do what I’ve done. When I ran into a similar problem I commented out every module except one. Then one at a time I restarted MM to see if that module was defined properly until I found the offending module. Once you know the one that is causing problems, you will need to pull up the documentation for it to find out what is wrong.
                  When you find the offending module, now you need to check to see what is wrong with that module definition. Chances are it’s a parameter that is misspelled or not applicable or specified incorrectly.
                    sdetweil @Omensch
                    @Omensch also, how did u do the setup of MagicMirror?
                    Manually, or with my automated install script?
                    From here
                    • O Offline
                      Omensch @EdO
                      @EdO thanks I’ll try that
                      • O Offline
                        Omensch @sdetweil
                        @sdetweil with the command from the website of MagicMirror
                        S Mykle1M 2 Replies Last reply Reply Quote 0
                          sdetweil @Omensch
                          @Omensch the old installer?
                          try the new one, rename the MagicMirror folder out of the way
                          then execute this from a terminal window or ssh session
                          bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                            Mykle1 Project Sponsor Module Developer @Omensch
                            @Omensch
                            Save yourself a lot of time and trouble and follow @sdetweil’s suggestion.
