    MMM-DWD-Pollen
    Scheduled Pinned Locked Moved Health
    healthweather
    32 Posts 10 Posters 19.6k Views 10 Watching
      MajorC Project Sponsor
      Update:
      I now use:
      .MMM-DWD-Pollen table {
      	margin-left: auto;
      	margin-right: -40px;
      Not sure if this is a good way, but it works for me at the moment.
      • C Offline
        CarstenD @MajorC
        @majorc Thanks. Somehow this does not really work on mine. Now the text is stretching into the right border.
        But good that it works for you.
          MajorC Project Sponsor @CarstenD
          @carstend that is strange. This is the only css I use for DWD-Pollen. Do you have something else in your custom css?
          • K Offline
            Klinge
            Hello,
            maybe someone of you could help me, because in my new opened topic I got no answers unfortunately.
            I try to start the module MMM-DWD-Pollen. But the data will not be loaded. I am living in the region “Östl. Niedersachsen”. On the Github site this region is declared with the number “32”. And on the DWD Site it is declared with the number “5”. But both numbers are not working. And now I don´t know which number I can use for my region.
            It would be great if someone could help me.
            Thank you in advance.
            S F 2 Replies Last reply Reply Quote 0
              sdetweil @Klinge
              @Klinge if someone knows and is willing to help they will.
              this forum is all volunteer community
              • K Offline
                Klinge @sdetweil
                @sdetweil said in MMM-DWD-Pollen:
                Yes, I know, and that’s absolutely fine, of course. It was just another attempt here.
                • F Offline
                  fatgrandma @Klinge
                  @Klinge
                  The Number on github is the correct one as statet on the github site
                  “There is a map that sows all part regions (but you have to match it to the numbers shown above)”
                  Dumb take but did you try to just wait one day? DWD pushes the numbers out once a day, if there are no new ones it shows nothing on the module.
                  • K Offline
                    Klinge @fatgrandma
                    @fatgrandma Thank you for your answer.
                    When I take the wrong number from the DWD site I got the message “No values today. No values tomorrow”. But you are right. In this case I have to wait a day more. I guess DWD published his new values at 11 a.m. every day, doesn´t it?
                    But when I take the correct number from the github site(!), I get only the message “Loading”. And this has been the case for several days.
                    • C Offline
                      CarstenD
                      Apparently DWD had changed its numbering. I updated the Readme.
                      Those are the new regions:
                      10=Schleswig-Holstein und Hamburg
                      11=Inseln und Marschen
                      12=Geest,Schleswig-Holstein und Hamburg
                      20=Mecklenburg-Vorpommern
                      30=Niedersachsen und Bremen
                      31=Westl. Niedersachsen/Bremen
                      32=Östl. Niedersachsen
                      40=Nordrhein-Westfalen
                      41=Rhein.-Westfäl. Tiefland
                      42=Ostwestfalen
                      43=Mittelgebirge NRW
                      50=Brandenburg und Berlin
                      60=Sachsen-Anhalt
                      61=Tiefland Sachsen-Anhalt
                      62=Harz
                      70=Thüringen
                      71=Tiefland Thüringen
                      72=Mittelgebirge Thüringen
                      80=Sachsen
                      81=Tiefland Sachsen
                      82=Mittelgebirge Sachsen
                      90=Hessen
                      91=Nordhessen und hess. Mittelgebirge
                      92=Rhein-Main
                      100=Rheinland-Pfalz und Saarland
                      101=Rhein, Pfalz, Nahe und Mosel
                      102=Mittelgebirgsbereich Rheinland-Pfalz
                      103=Saarland
                      110=Baden-Württemberg
                      111=Oberrhein und unteres Neckartal
                      112=Hohenlohe/mittlerer Neckar/Oberschwaben
                      113=Mittelgebirge Baden-Württemberg
                      120=Bayern
                      121=Allgäu/Oberbayern/Bay. Wald
                      122=Donauniederungen
                      123=Bayern nördl. der Donau, o. Bayr. Wald, o. Mainfranken
                      124=Mainfranken
                      • C Offline
                        CarstenD @CarstenD
                        I checked your region (32) and there is indeed no data from DWD. The only region is 31 with data.
                        • K Offline
                          Klinge @Sachse
                          @Sachse Please excuse me for replying to such an old post. But unfortunately I have the same problem as you had. The module only worked fine for a few days, and now it won’t load the data any more. I have now tried to reproduce your solution. But I unfortunately did not solve it. When I enter “pm2 status” and “netstat -plan|grep 8080”, I get the following output.
                          pi@raspberrypi:~/MagicMirror/modules $ pm2 status
                          │ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
                          │ 0  │ MagicMirror    │ default     │ 2.26.0  │ fork    │ 749      │ 5h     │ 0    │ online    │ 0%       │ 2.6mb    │ pi       │ enabled  │
                          pi@raspberrypi:~/MagicMirror/modules $ netstat -plan|grep 8080
                          (Es konnten nicht alle Prozesse identifiziert werden; Informationen über
                          nicht-eigene Processe werden nicht angezeigt; Root kann sie anzeigen.)
                          tcp6       0      0 ::1:8080                :::*                    LISTEN      838/electron.js
                          tcp6       0      0 ::1:8080                ::1:46942               TIME_WAIT   -
                          tcp6       0      0 ::1:8080                ::1:46944               FIN_WAIT2   -
                          tcp6       0      0 ::1:8080                ::1:44370               VERBUNDEN   838/electron.js
                          tcp6       0      0 ::1:44370               ::1:8080                VERBUNDEN   941/Electron --shar
                          tcp6       1      0 ::1:46944               ::1:8080                CLOSE_WAIT  941/Electron --shar
                          It would be really nice if you could please give me the crucial hint where the problem is now and how it can be solved? :-)
                            bhepler Module Developer @Klinge
                            @Klinge - It appears that your problem isn’t the same. @Sachse had two instances of the Magic Mirror framework running at the same time. You probably don’t have that problem.
                            The DWD site appears to be up and is hosting a json file. So let’s start at the beginning. Please post the relevant portion of your config.js file. We don’t need everything, just the part that configures the MMM-DWD-Pollen module. That will let us try and replicate your problem. Be sure to use the Markdown features when you post your code snippet!
