    missing custom.css file
    19 Posts 6 Posters 6.6k Views 6 Watching
    • G Offline
      Gorman_ni
      hi, just got this up and running but for the life of me can’t find my custom.css file or figure out how to set one up correctly, i only have main.css in there. any help would be appreciated.
      • thedoorsfanaticT Offline
        thedoorsfanatic
        I am not an expert but I would name an empty text file to custom.css and put it in the css folder
        My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
          sdetweil @thedoorsfanatic
          @thedoorsfanatic right… to create the initial text file its
          touch ~/MagicMirror/css/custom.css
          then u can edit it…with your favorite editor
            I just set up another laptop board. Used @sdetweil’s installer. Fantastic! Copied the main.css file and renamed it to custom.css. Done!
              sdetweil @Mykle1
              @Mykle1 but that is sorta heavy weight . cause now you are overriding every class defined in main.css…
                Well, I emptied the body and deleted everything else. Did I forget to mention that? :-)
                  sdetweil @Mykle1
                  @Mykle1 yes… easier just to do the touch thing… create an empty file… (for users just starting out)
                    Yes. if you know about the touch thing. I did not. Now I do.
                      sdetweil @Mykle1
                      @Mykle1 or just editing and use save as
                        Or, have a blank custom.css file added during installation. Easier for the users just starting out. ;-)
                          sdetweil @Mykle1
                          @Mykle1 true… easy peasy… done (in my script…)
                            @sdetweil said in missing custom.css file:
                            What a great idea! ;-)
                            This is why you are the king! :thumbsup:
                            • BKeyportB Offline
                              BKeyport Module Developer
                              FWIW, I wouldn’t put a “blank” custom.css…
                              I’d put at the top of main.css
                              * Magic Mirror
                              * Main CSS
                              * Do not edit this file, make changes to custom.css instead.
                              and in custom.css
                               * Magic Mirror
                               * Custom CSS
                               * Add your custom CSS here, for help, please go to http://forum.magicmirror.builders
                                sdetweil @BKeyport
                                @BKeyport main.css is owned by the project. Submit a pull request to update that.
                                The comment in custom.css does not add anything in my opinion.
                                • BKeyportB Offline
                                  I know that from a beginning user standpoint, having any user files point you to help would ease a lot of people. I’m just thinking of the person who heard of this project and decided to try it out because Pi’s are cheap, and it looked like a challenge (Me!) - I sure the heck didn’t know where I could get help at first, and have learned so much from here.
                                    mmmmh Project Sponsor
                                    Sorry for resurrecting this but I think an empty custom.css should be part of the default install. There are errors in the console log when it is missing.
                                      sdetweil @mmmmh
                                      @mmmmh if you use the automated installer, it will create an empty file
                                        mmmmh Project Sponsor @sdetweil
                                        @sdetweil Thanks for the hint. I installed it manually. I guess the assumption is if you know how to clone you also know how to touch. : )
                                          sdetweil @mmmmh
                                          @mmmmh well, there is no damage if its not there, so, if you need it, you will create it…
                                          i agree with you it should be there… there are quite a few new users that are following some
                                          guide, and get to the ‘edit custom.css file’ step and its not there and they are lost. and don’t know what to do.
