    missing custom.css file
    19 Posts 6 Posters 6.3k Views 6 Watching
      sdetweil @thedoorsfanatic
      @thedoorsfanatic right… to create the initial text file its
      touch ~/MagicMirror/css/custom.css
      then u can edit it…with your favorite editor
        I just set up another laptop board. Used @sdetweil’s installer. Fantastic! Copied the main.css file and renamed it to custom.css. Done!
          sdetweil @Mykle1
          @Mykle1 but that is sorta heavy weight . cause now you are overriding every class defined in main.css…
            Well, I emptied the body and deleted everything else. Did I forget to mention that? :-)
              sdetweil @Mykle1
              @Mykle1 yes… easier just to do the touch thing… create an empty file… (for users just starting out)
                Yes. if you know about the touch thing. I did not. Now I do.
                  sdetweil @Mykle1
                  @Mykle1 or just editing and use save as
                    Or, have a blank custom.css file added during installation. Easier for the users just starting out. ;-)
                      sdetweil @Mykle1
                      @Mykle1 true… easy peasy… done (in my script…)
                        @sdetweil said in missing custom.css file:
                        What a great idea! ;-)
                        This is why you are the king! :thumbsup:
