    missing custom.css file
    19 Posts 6 Posters 6.9k Views 6 Watching
      I just set up another laptop board. Used @sdetweil’s installer. Fantastic! Copied the main.css file and renamed it to custom.css. Done!
        sdetweil @Mykle1
        @Mykle1 but that is sorta heavy weight . cause now you are overriding every class defined in main.css…
          Well, I emptied the body and deleted everything else. Did I forget to mention that? :-)
            sdetweil @Mykle1
            @Mykle1 yes… easier just to do the touch thing… create an empty file… (for users just starting out)
              Yes. if you know about the touch thing. I did not. Now I do.
                sdetweil @Mykle1
                @Mykle1 or just editing and use save as
                  Or, have a blank custom.css file added during installation. Easier for the users just starting out. ;-)
                    sdetweil @Mykle1
                    @Mykle1 true… easy peasy… done (in my script…)
                      @sdetweil said in missing custom.css file:
                      What a great idea! ;-)
                      This is why you are the king! :thumbsup:
                      • BKeyportB Offline
                        BKeyport Module Developer
                        FWIW, I wouldn’t put a “blank” custom.css…
                        I’d put at the top of main.css
                        * Magic Mirror
                        * Main CSS
                        * Do not edit this file, make changes to custom.css instead.
                        and in custom.css
                         * Magic Mirror
                         * Custom CSS
                         * Add your custom CSS here, for help, please go to http://forum.magicmirror.builders
                          sdetweil @BKeyport
                          @BKeyport main.css is owned by the project. Submit a pull request to update that.
                          The comment in custom.css does not add anything in my opinion.
                          • BKeyportB Offline
                            I know that from a beginning user standpoint, having any user files point you to help would ease a lot of people. I’m just thinking of the person who heard of this project and decided to try it out because Pi’s are cheap, and it looked like a challenge (Me!) - I sure the heck didn’t know where I could get help at first, and have learned so much from here.
                              mmmmh Project Sponsor
                              Sorry for resurrecting this but I think an empty custom.css should be part of the default install. There are errors in the console log when it is missing.
                                sdetweil @mmmmh
                                @mmmmh if you use the automated installer, it will create an empty file
                                  mmmmh Project Sponsor @sdetweil
                                  @sdetweil Thanks for the hint. I installed it manually. I guess the assumption is if you know how to clone you also know how to touch. : )
                                    sdetweil @mmmmh
                                    @mmmmh well, there is no damage if its not there, so, if you need it, you will create it…
                                    i agree with you it should be there… there are quite a few new users that are following some
                                    guide, and get to the ‘edit custom.css file’ step and its not there and they are lost. and don’t know what to do.
