    missing custom.css file
    19 Posts 6 Posters 6.9k Views 6 Watching
    • thedoorsfanaticT Offline
      thedoorsfanatic
      I am not an expert but I would name an empty text file to custom.css and put it in the css folder
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
        sdetweil @thedoorsfanatic
        @thedoorsfanatic right… to create the initial text file its
        touch ~/MagicMirror/css/custom.css
        then u can edit it…with your favorite editor
          I just set up another laptop board. Used @sdetweil’s installer. Fantastic! Copied the main.css file and renamed it to custom.css. Done!
            sdetweil @Mykle1
            @Mykle1 but that is sorta heavy weight . cause now you are overriding every class defined in main.css…
              Well, I emptied the body and deleted everything else. Did I forget to mention that? :-)
                sdetweil @Mykle1
                @Mykle1 yes… easier just to do the touch thing… create an empty file… (for users just starting out)
                  Yes. if you know about the touch thing. I did not. Now I do.
                    sdetweil @Mykle1
                    @Mykle1 or just editing and use save as
                      Or, have a blank custom.css file added during installation. Easier for the users just starting out. ;-)
                        sdetweil @Mykle1
                        @Mykle1 true… easy peasy… done (in my script…)
                          @sdetweil said in missing custom.css file:
                          What a great idea! ;-)
                          This is why you are the king! :thumbsup:
                          • BKeyportB Offline
                            BKeyport Module Developer
                            FWIW, I wouldn’t put a “blank” custom.css…
                            I’d put at the top of main.css
                            * Magic Mirror
                            * Main CSS
                            * Do not edit this file, make changes to custom.css instead.
                            and in custom.css
                             * Magic Mirror
                             * Custom CSS
                             * Add your custom CSS here, for help, please go to http://forum.magicmirror.builders
                              sdetweil @BKeyport
                              @BKeyport main.css is owned by the project. Submit a pull request to update that.
                              The comment in custom.css does not add anything in my opinion.
                              • BKeyportB Offline
                                I know that from a beginning user standpoint, having any user files point you to help would ease a lot of people. I’m just thinking of the person who heard of this project and decided to try it out because Pi’s are cheap, and it looked like a challenge (Me!) - I sure the heck didn’t know where I could get help at first, and have learned so much from here.
                                  mmmmh Project Sponsor
                                  Sorry for resurrecting this but I think an empty custom.css should be part of the default install. There are errors in the console log when it is missing.
                                    sdetweil @mmmmh
                                    @mmmmh if you use the automated installer, it will create an empty file
                                      mmmmh Project Sponsor @sdetweil
                                      @sdetweil Thanks for the hint. I installed it manually. I guess the assumption is if you know how to clone you also know how to touch. : )
                                        sdetweil @mmmmh
                                        @mmmmh well, there is no damage if its not there, so, if you need it, you will create it…
                                        i agree with you it should be there… there are quite a few new users that are following some
                                        guide, and get to the ‘edit custom.css file’ step and its not there and they are lost. and don’t know what to do.
