    MMM-COVID19
    Scheduled Pinned Locked Moved Health
    63 Posts 25 Posters 40.9k Views 24 Watching
      Saeijou
      I don’t know what I am doing wrong, I can’t get it to work.
      I have that in my config:
          module: 'MMM-COVID19',
          positon: "top_left",
            updateInterval: 300000,
            worldStats: true,
            countries: ["Germany","USA"],
            headerRowClass: "small",
            rapidapiKey: "API_KEY"
      when I execute the curl command posted here I also get an output with my API key.
      I am not 100% sure what is meant with “posting it twice”, why would that be?
      Thank you for any help!
      Edit: MM is loading normally - no errors. the module is just not there
      • H Offline
        hweigel @Saeijou
        @Saeijou said in MMM-COVID19:
        positon
        Hey @Saeijou,
        try using
        instead of
        That should do the trick :-)
          Saeijou @hweigel
          @hweigel OH MY GOODNESS!!! I debugged that thing for HOURS! thank you so much :)
          • K Offline
            KD
            Hi Guys, I cannot get this to work - not sure what i am doing wrong…i can only see the header displaying and nothing else… please help! my config looks like this:
                                  position: "bottom_right",
                                  header: "COVID-19 Stats",
                                  worldStats: true,
                                  rapidapiKey: "My Rapidapikey",
                                  orderCountriesByName: "false",
                                  countries: [ "Austria", "Germany", "Italy" ],
                                  updateInterval: 10000000,
                                  lastUpdateInfo: "true",
                                  infoRowClass: "medium",
            Many Thanks in advance
            S mumblebajM 2 Replies Last reply Reply Quote 0
              sdetweil @KD
              @KD please use code block marks , mark the text and hit the </> button
              • K Offline
                KD @sdetweil
                @sdetweil Will do thank you - apologies i am new first post actually :)
                • P Offline
                  paulie420
                  Ok, I pulled the MMM-Covid19 git. I added the module in config.js, and entered my APIkey… However, it only displays the COVID-19 title and no data.
                  Am I correct in stating that its not working because now rapidapi has made the coronavirus monitor API paid? Because I think I have it all setup correctly, I notice that the API in rapidapi states PAID, and nothing shows… I want Covid data; is there a way, or am I doing something wrong? OR do I just need to pay and then it’ll show up??
                  • mumblebajM Offline
                    mumblebaj Module Developer @KD
                    @KD remove the comma after “medium” and you should be fine.
                      mumblebaj Module Developer @paulie420
                      @paulie420 The RapidAPI seems to be working fine. No need to pay. Can you post your config?
                      J A 2 Replies Last reply Reply Quote 0
                        Joeri @mumblebaj
                        @mumblebaj Hello, I’ve got the same problem, this is my config.
                        module: “MMM-COVID19”,
                        position: “lower_third”,
                        worldStats: true,
                        delta: true,
                        headerRowClass: ‘small’,
                        orderCountriesByName: “false”,
                        lastUpdateInfo: true,
                        countries: [ “Argentina”, “USA” ],
                        headerRowClass: “small”,
                        infoRowClass: “medium”,
                        rapidapiKey : “MY KEY”,
                          andfha @mumblebaj
                          @mumblebaj Same problem here. Looks like its paid now. curl shows “You are not subscribed to this API”
                            menckow
                            There are two versions of the api. A paid and a freemium version. The freemium one is the V2!
                            If you want to use the freemium version you will have to edit the node_helper.js file in the module directory (MMM-COVID19) and change the rapidapihost entry and the GET URL as well
                            rapidhost
                            NEW: “x-rapidapi-host”: “coronavirus-monitor-v2.p.rapidapi.com”,
                            OLD: “x-rapidapi-host”: “coronavirus-monitor.p.rapidapi.com”,
                            GET URL
                            NEW: ‘https://coronavirus-monitor-V2.p.rapidapi.com/coronavirus/cases_by_country.php’
                            OLD: ‘https://coronavirus-monitor.p.rapidapi.com/coronavirus/worldstat.php’
                            • I Offline
                              Indiz
                              Bonjour j’ai le même problème, je n’ai que le titre COVID-19 qui apparait et aucunes données.
                              Voici ma config:
                              	module: "MMM-COVID19",
                              	  worldStats: true,
                              	  delta: true,
                              	  countries: [ "USA", "France", "Spain" ],
                              	  rapidapiKey : "KEY",
                                dubalda
                                Hi guys,
                                I’m not getting much luck getting this to work. I just get the header and no errors in the log.
                                position: “top_left”,
                                worldStats: true,
                                delta: true,
                                countries: [ “Argentina”, “China”, “Italy”, “Spain” ],
                                rapidapiKey : “xxx”
                                I’ve also amended the node_helper.js for the module to include the new rapidhost URLs
                                var byCountryUrl = ‘https://coronavirus-monitor-V2.p.rapidapi.com/coronavirus/cases_by_country.php’
                                getGlobalStats: function(key) {
                                var self = this
                                var options = {
                                method: ‘GET’,
                                url: worldStatsUrl,
                                headers: {
                                //‘x-rapidapi-host’: ‘coronavirus-monitor.p.rapidapi.com’,
                                ‘x-rapidapi-host’: ‘coronavirus-monitor-v2.p.rapidapi.com’,
                                ‘x-rapidapi-key’: key
                                getStatsByCoutry: function(key) {
                                var self = this
                                var options = {
                                method: ‘GET’,
                                url: byCountryUrl,
                                headers: {
                                Any help would be great!
                                  sdetweil @dubalda
                                  @dubalda when u use the url in a browser does it return the right data?
                                    dubalda
                                    Hi Sam,
                                    I just get "{“message”:“Invalid API key. Go to https://docs.rapidapi.com/docs/keys for more info.”}
                                    Sorry, perhaps I missing something here…are you refering this URL
                                    Thx
                                      sdetweil @dubalda
                                      @dubalda whatever api you use. i always test in a browser first.
                                      u need to add the apikey to the url
                                      i am making it up (not exact text) cause i am on my phone in hospital
                                      url.php&api_key=whatever is the key
                                        dubalda
                                        Sorry to hear you’re in hospital! Hopefully it’s nothing to serious.
                                        I tried…
                                        https://coronavirus-monitor.p.rapidapi.com/coronavirus/united_states_cases.php&api_key=xxx
                                        and received.
                                        RapidAPI does see it’s free service. I’ve amened the entries in node_helper.js back to the their defaults but still no joy there. Very strange.
                                          sdetweil @dubalda
                                          @dubalda free and requiring a key are different.
                                          if u require a key you know who consumes your service
                                          i said dont take my words exactly.
                                          what does the service say is the apikey parameter name, exact spelling
                                          this aint magic, its grunt work getting the parms right
                                          i do my.own covid charts MyCovid19, see
                                          https://github.com/sdetweil/MyCovid19
                                          they have changed the data on me 3 times in a year. hard to keep up
                                            dubalda
                                            I’ve tried…
                                            curl -H “x-rapidapi-host: coronavirus-monitor-v2.p.rapidapi.com” -H “x-rapidapi-key: xxx” ‘https://coronavirus-monitor-v2.p.rapidapi.com/coronavirus/cases_by_country.php’
                                            And have copied the key (copy/paste) exactly from the website but get the message…
                                            “message”:“You are not subscribed to this API.”
                                            I think I’ll just get the Covid numbers from the news! Thanks for your help @sdetweil !
                                            • 3 / 4
