    Config help please
    15 Posts 3 Posters 8.9k Views 3 Watching
      snotrocket
      Hello all. Pretty new to this and just love it. Making some mirrors for xmas and just can’t get the config file correct. what am i missing?
      Thanks in advance!
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: 'en',
      	timeFormat: 12,
      	units: 'imperial',
      			module: 'alert',
      			module: 'clock',
      			position: 'top_left'
      			module: 'calendar',
      			header: 'US Holidays',
      			position: 'top_left',
      						symbol: 'calendar-check-o ',
      						url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
      			module: 'compliments',
      			position: 'lower_third'
      			module: 'currentweather',
      			position: 'top_right',
      				locationID: '',  //ID from http://www.openweathermap.org
      				appid: '#########################'
      			module: 'weatherforecast',
      			header: 'Weather Forecast',
      				appid: '##########################'
      			module: 'newsfeed',
      			position: 'bottom_bar',
      				feeds: [
      						title: "ESPN",
      						url: “http://www.espn.com/espn/rss/news”
      						title: “Reuters Sports”,
      						url: “http://feeds.reuters.com/reuters/sportsNews”
      						title: "Yahoo NFL"
      					https://sports.yahoo.com/nfl/rss.xml
      				showSourceTitle: false,
      				showPublishDate: false
        snotrocket
        Yay! It works! I added the NFL module and tweaked the compliments.
        Thank you so much!!! Working code is below.
         * MIT Licensed.
        var config = {
        	port: 8080,
        	language: 'en',
        	timeFormat: 12,
        	units: 'imperial',
        			module: 'alert',
        			module: 'clock',
        			module: 'calendar',
                position: 'bottom_center',
                        updateInterval: 30000,
                        compliments: {
                                morning: [
                                "Good morning!",
        						"Lets go tackle today"
                                afternoon: [
                                "What an awesome day!"
                                evening: [
                                        "Did you do everything you wanted today?",
                                        "Wasn't the day just spectacular?"
        				appid: '#######################'
        				appid: '############################'
        			module: 'newsfeed',
        				feeds: [
        						title: "ESPN",
        						url: "http://www.espn.com/espn/rss/news"
        						title: "Reuters Sports",
        						url: "http://feeds.reuters.com/reuters/sportsNews"
        			module: 'MMM-NFL',
        			position: 'middle_center',
        			colored: true,
        			helmets: true,
        			reloadInterval: 10000,
        			focus_on: ['CHI']
        strawberry 3.141S L 2 Replies Last reply Reply Quote 0
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @snotrocket
          @snotrocket you used the wrong quotes in the newsfeed section and for the last feed you missed to specify url:
          		module: 'newsfeed',
          			feeds: [
          					title: "ESPN",
          					title: "Yahoo NFL",
                                                  url: "https://sports.yahoo.com/nfl/rss.xml"
            snotrocket
            Fixed it. Still a no go.
            Thanks in advance.
            Config:
             * MIT Licensed.
            var config = {
            	port: 8080,
            	language: 'en',
            	timeFormat: 12,
            	units: 'imperial',
            			module: 'alert',
            			module: 'clock',
            			module: 'calendar',
            			module: 'newsfeed',
            				feeds: [
            						title: "ESPN",
            						title: "Yahoo NFL"
              @snotrocket you are still using the wrong quotes use " or ' instead of “
                snotrocket
                Oooooh. Would the different quotes come from notepad++ or something? I think I edited in that and copied via SSH.
                Fixing now.
                  snotrocket
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	language: 'en',
                  	timeFormat: 12,
                  	units: 'imperial',
                  			module: 'alert',
                  			module: 'clock',
                  			module: 'calendar',
                                  compliments: {
                                          morning: [
                                          "Good morning!",
                                          afternoon: [
                                          evening: [
                  			module: 'newsfeed',
                  				feeds: [
                  						title: "ESPN",
                  			module: 'MMM-NFL',
                  			colored: true,
                  			helmets: true,
                  			focus_on: ['CHI']
                    @snotrocket there is no need to let the nfl module reload every 10 seconds, it will detect itself if there is a live match and during live matches it will refresh data more frequently
                      snotrocket
                      So set it to an hour or two?
                        @snotrocket if you want to use the default of 30mins you can remove it from your config.js completely
                          snotrocket
                          even better! Thanks.
                            snotrocket
                            Can i set the size of the NFL module? in the middle it takes up a huge amount of the screen when it shows all upcoming matches.
                              @snotrocket you can either limit with focus_on option the amount of matches displayed or use custom.css to make personal changes to the style
                              • L Offline
                                l8kerjuan @snotrocket
                                @snotrocket any chance you have a photo of what your mirror looks like… as far as layout… havent been able to see a functioning nfl or nhl module up on screen. just curios if i even want to tinker and add to mine… im so close to being done!! thanks
                                  snotrocket @l8kerjuan
                                  @l8kerjuan Here is the base config on a monitor, not the mirror when I was!testing it. I removed the module before the mirror was finished because the Bears were well… Da Bears. ! I think I have a copy of the config file as well. I’ll go look for it.
                                  • L Offline
                                    @snotrocket that looks cool. thanks
