    Blank Black screen after the last - 2.11 - update
    20 Posts 5 Posters 6.4k Views 4 Watching
    • K Offline
      kondef
      I just unfortunately did the update of 2.11 backing up only the modules folder and config.cs file. Now with either npm start or npm run start, nothing happens. I have a black blank screen. I followed the instructions of MichMich with the commands git pull && npm install.How can i fix that problems guys? Please consider that i am not expert with programming so please explain in a simple way. My node versions is:10.19
        sdetweil @kondef
        @kondef what kind of pi?
        u will also have to do npm install in any module folder that has a package.json file
        I think my upgrade script will work, haven’t had a chance to try myself (trying to fix install)
        see
          JoeFranz
          I also had it with me, that’s because of the MMM-Pir-Sensor module. I deactivated it for now.
          • K Offline
            kondef @sdetweil
            @sdetweil I have raspberry pi3 b+. I reinstalled npm for all modules that have json file but i am still getting the same problem!
              sdetweil @kondef
              @kondef r u using pm2 to start?
              If so do
              pm2 logs
              ctrl-c to exit
              Then npm start
              Also may need to open developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors…
              • K Offline
                kondef @sdetweil
                @sdetweil No i start manually npm start
                  sdetweil @kondef
                  @kondef so, you should open the dev window
                  • K Offline
                    kondef @sdetweil
                    @sdetweil You mean npm run start dev ? I am sorry i told you i am not expert. By pressing Control - Shift - i the only thing happens is a small window opens.
                      sdetweil @kondef
                      @kondef should be the right side of screen
                      npm start dev can do the same on startup
                      • K Offline
                        kondef
                        I am getting “DevTools was disconnected from the page. Once page is reloaded, DevTools will automatically reconnect” and the page now is white blank and thre is nothing on the dev console.
                        But i managed to take a photo while magic mirror was loading and i got the following: "MODULE NOT FOUND. Require Stack /home/pi/MagicMirror/modules/MMM-Hotword/snowboy/lib/node/index.js
                        /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                        /home/pi/MagicMirror/js/app.js
                        /home/pi/MagicMirror/js/electron.js
                        /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.
                          sdetweil @kondef
                          @kondef images don’t post…
                          • K Offline
                            kondef @sdetweil
                            Please note that i already did npm install on Hotword module
                              sdetweil @kondef
                              @kondef yeh, hotword needs an electron-rebuild I think
                              • K Offline
                                kondef @sdetweil
                                @sdetweil How? I tried to update snowboy but i am getting an error.
                                  sdetweil @kondef
                                  @kondef I don’t know right now. Be a few hours til I have time to test myself
                                    sdetweil @kondef
                                    @kondef the doc for hotword install says
                                    if troubles do
                                    git clone https://github.com/Kitt-AI/snowboy.git
                                    cd snowboy
                                    rm -rf .git
                                    cp -r resources/models ..
                                    npm install -y nan node-pre-gyp
                                    ./node_modules/node-pre-gyp/bin/node-pre-gyp clean configure build
                                    npm install -y
                                    npm install -y electron-rebuild
                                    ./node_modules/.bin/electron-rebuild
                                      mattx38 @kondef
                                      @kondef you can see my topic where @sdetweil helped me to solve issues.
                                      At this time, my mirror works again, excepted the Remote-Control module.
                                      Don’t worry, your mirror will come back well soon also for you ;-)
                                      • K Offline
                                        kondef @mattx38
                                        @mattx38 @sdetweil thank you so much guys for your immediate response. I actually deleted the hotword folder and reinstall again and now works fine. Now i am searching for a calendar that i can add multiple ones and to have a fancy -but not taking much space- look. Any ideas?
                                          rcikahskd
                                          Did anyone solve the issue?
                                            sdetweil @rcikahskd
                                            @rcikahskd which issue?
