    MMM-SoccerLiveScore pleas help
    52 Posts 5 Posters 24.8k Views 5 Watching
      Manu85
      this is how it is in the config.js
      disabled:true,
      module: ‘MMM-SoccerLiveScore’,
      position: ‘top_right’,
      header: ‘Scores en direct’,
      leagues: [34, 1, 8],
      showNames: true,
      showLogos: true,
      debug:true,
      displayTime: 60 * 1000,
      showTables: true
        sdetweil @Manu85
        @Manu85 ok… looks good…
        however, the node_helper in the module folder is also the old one… not the new that you were supposed to have copied…
          Manu85
          @sdetweil yet I followed your instructions, but I may have made a mistake! what should I do?
            sdetweil @Manu85
            @Manu85
            cd ~/MagicMirror/modules
            mv MMM-SoccerLiveScore MMM-SoccerLiveScore.old
            mv NewSoccerLive MMM-SoccerLiveScore
            cd MMM-SoccerLiveScore
            npm install
            then u can change disabled: back to false
              Manu85
              I made all the lines and went to false, the MM started but soccer does not appear on the screen
                sdetweil @Manu85
                @Manu85 output of
                pm2 logs --lines=100
                please
                  Manu85
                  @sdetweil in your mailbox
                    sdetweil @Manu85
                    @Manu85 makes no sense…
                    can u edit ~/MagicMirror/modules/MMM-SoccerLiveScore/node_helper.js
                    and show me the top few lines, should look like this
                    /* Magic Mirror
                     * Module: MyCovid19
                     * Node_helper written by sdetweil
                    const NodeHelper = require('node_helper');
                    const request = require('request');
                    const path = require('path')
                    var moment = require('moment');
                    //const cvt=require("xlsx-to-json")
                    const cvt=require('csvtojson')
                    var fs=require('fs')
                      Manu85
                      @sdetweil I have a file “/home/pi/MagicMirror/modules/MMM-SoccerLiveScore.old” and in this file I have another file “MMM-SoccerLiveScore” is this file “node_helper.js” you want?
                        sdetweil @Manu85
                        @Manu85 i have no idea what you did… there should be two folders in ~/MagicMirror/modules (related to this problem)
                        MMM-SoccerLiveScore.old the original module
                        MMM-SoccerLiveScore my updated module, rename from NewSoccerLive
                          Manu85
                          @sdetweil I just emailed you the screenshot of what I have, thanks again for your help
                            sdetweil @Manu85
                            @Manu85 do
                            cd ~/MagicMirror/modules/MMM-SoccerLiveScore.old
                            mv MMM-SoccerLiveScore ..
                            cd ~/MagicMirror
                            restart mirror
                              Manu85
                              I’m sorry, after passing these lines the screen remains black
                                sdetweil @Manu85
                                @Manu85 show me outout
                                  Manu85
                                  @sdetweil I just resumed our entire conversation and I just redid "cd ~ / MagicMirror / modules
                                  git clone https://github.com/sdetweil/MMM-SoccerLiveScore NewSoccerLive
                                  cp …/NewSoccerLive/*.js. "
                                  I do not know if I did well, but I think I have abused your kindness enough, I send you the somefile on your email, thank you
                                    Manu85
                                    @sdetweil I sent you the email from somefile
                                    • StoffbeuteluweS Offline
                                      Stoffbeuteluwe Project Sponsor @sdetweil
                                      @sdetweil Hello, I tried the new module… until now it works fine.
                                      I have set debug: true,
                                        sdetweil @Stoffbeuteluwe
                                        @Stoffbeuteluwe cool, thx for the feedback
                                          Manu85
                                          @sdetweil hello, this morning the MM is frozen … I sent you the somefile file by email. yesterday evening after 2 or 3 hours the soccer module displayed the module screens very quickly 1/2 second and this morning the module disappeared, the seconds of the MM watch go from 35s to 50s
                                          @Stoffbeuteluwe is your MM still working well?
                                          • lavolp3L Offline
                                            lavolp3 Module Developer
                                            Don’t want to undermine the work you have put into here, especially yours @sdetweil, but my MMM-soccer v2 is actively developed by me and should work in its present state.
                                            And basically does the same.
                                            How to troubleshoot modules
                                            MMM-soccer v2, MMM-AVStock
                                            S StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                                            • 2 / 3
