    Installing Magic mirror on windows 10
    38 Posts 9 Posters 20.5k Views 11 Watching
    • C Offline
      Chrisflex @Mykle1
      @Mykle1 @sdetweil thanks I will do that
        sojourner @sdetweil
        @sdetweil This is solid gold :shooting_star: for the Windoz user in me! With these finishing steps, it works as expected. Thanks again!
        p.s. bonus points for suggesting notepad for editing the package.json along with the steps to quit nodepad… Too funny!
        • V Offline
          vivian0239
          Hi, everyone!
          I have a task to install Magic Mirror on Windows. And I am very happy to find here. I tried the steps, but it still has error. My pc is Windows 10.
          I also changed package.json from:
          “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
          to
          “start”: “node_modules/.bin/electron js/electron.js”,
          I am new to JS, please tell me where I am wrong. Thank you!
          This is my log:
          ssdrive@home MINGW64 ~/MagicMirror
          $ npm install --only=prod
          magicmirror@2.12.0 install C:\Users\ssdrive\MagicMirror
          echo "Installing vendor files …
          " && cd vendor && npm install --loglevel=error
          magicmirror@2.12.0 postinstall C:\Users\ssdrive\MagicMirror
          npm run install-fonts && echo "MagicMirror installation finished successfully!
          magicmirror@2.12.0 install-fonts C:\Users\ssdrive\MagicMirror
          echo "Installing fonts …
          " && cd fonts && npm install --loglevel=error
          "Installing fonts …
          audited 1050 packages in 16.723s
          75 packages are looking for funding
          run npm fund for details
          found 3 low severity vulnerabilities
          run npm audit fix to fix them, or npm audit for details
          $ cd vendor
          ssdrive@home MINGW64 ~/MagicMirror/vendor
          $ npm install
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules\fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“win32”,“arch”:“x64”})
          added 82 packages from 57 contributors and audited 150 packages in 15.029s
          found 8 vulnerabilities (7 low, 1 high)
          $ cd …\fonts
          bash: cd: …fonts: No such file or directory
          $ cd …
          $ cd fonts
          ssdrive@home MINGW64 ~/MagicMirror/fonts
          $ npm install
          added 1 package from 1 contributor and audited 1 package in 0.993s
          found 0 vulnerabilities
          $ cd …
          $ notepad package.json
          $ npm start
          npm ERR! code EJSONPARSE
          npm ERR! file C:\Users\ssdrive\MagicMirror\package.json
          npm ERR! JSON.parse Failed to parse json
          npm ERR! JSON.parse Unexpected token , in JSON at position 209 while parsing near ‘…tron js/electron.js",
          npm ERR! JSON.parse “server”: "node …’
          npm ERR! JSON.parse Failed to parse package.json data.
          npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
          npm ERR! C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_33_43_328Z-debug.log
          $ npm start
          npm ERR! C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_41_40_531Z-debug.log
            sdetweil @vivian0239
            @vivian0239 said in Installing Magic mirror on windows 10:
            $ cd …\fonts
            $ cd …
            $ cd fonts
            $ npm install
            there are 3 dots in the CD commands change it to 2 dots
            do NOT install under min.
            just open a command prompt (CMD.exe) and do npm install
              suqiqi
              ‘node_moudles’ is not recognized as an internal or external command,
              operable program or batch file.
                suqiqi @sdetweil
                @sdetweil ‘node_moudles’ is not recognized as an internal or external command,
                please help me thank you
                  sdetweil @suqiqi
                  @suqiqi where do u see that?
                  the folder is node_modules
                    rdcullis
                    Hi all, I am giving this a try and running into the same errors as above, i have followed the advise but i dont get the black screen, after the error fix for display, i get new error:
                    $ npm start
                    magicmirror@2.14.0 start C:\Users\Richard\MagicMirror
                    ‘electron’ is not recognized as an internal or external command,
                    npm ERR! code ELIFECYCLE
                    npm ERR! errno 1
                    npm ERR! magicmirror@2.14.0 start: electron js/electron.js
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.14.0 start script.
                    npm ERR! C:\Users\Richard\AppData\Roaming\npm-cache_logs\2021-03-29T19_41_46_132Z-debug.log
                    any help here would be great, thanks
                    • C CheapDad referenced this topic on
                    • 4 / 4
