    Installing Magic mirror on windows 10
    38 Posts 9 Posters 25.9k Views 11 Watching
      sdetweil @Chrisflex
      @Chrisflex read the readme for each module
      Mykle1M 1 Reply Last reply
      Reply Quote 2
      • Mykle1M
        @sdetweil said in Installing Magic mirror on windows 10:
        I second this motion. :thumbs_up_light_skin_tone:
        C 1 Reply Last reply
          Chrisflex @Mykle1
          @Mykle1 @sdetweil thanks I will do that
            sojourner @sdetweil
            @sdetweil This is solid gold :shooting_star: for the Windoz user in me! With these finishing steps, it works as expected. Thanks again!
            p.s. bonus points for suggesting notepad for editing the package.json along with the steps to quit nodepad… Too funny!
            • V
              vivian0239
              Hi, everyone!
              I have a task to install Magic Mirror on Windows. And I am very happy to find here. I tried the steps, but it still has error. My pc is Windows 10.
              I also changed package.json from:
              “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
              to
              “start”: “node_modules/.bin/electron js/electron.js”,
              I am new to JS, please tell me where I am wrong. Thank you!
              This is my log:
              ssdrive@home MINGW64 ~/MagicMirror
              $ npm install --only=prod
              magicmirror@2.12.0 install C:\Users\ssdrive\MagicMirror
              echo "Installing vendor files …
              " && cd vendor && npm install --loglevel=error
              magicmirror@2.12.0 postinstall C:\Users\ssdrive\MagicMirror
              npm run install-fonts && echo "MagicMirror installation finished successfully!
              magicmirror@2.12.0 install-fonts C:\Users\ssdrive\MagicMirror
              echo "Installing fonts …
              " && cd fonts && npm install --loglevel=error
              "Installing fonts …
              audited 1050 packages in 16.723s
              75 packages are looking for funding
              run npm fund for details
              found 3 low severity vulnerabilities
              run npm audit fix to fix them, or npm audit for details
              $ cd vendor
              ssdrive@home MINGW64 ~/MagicMirror/vendor
              $ npm install
              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules\fsevents):
              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“win32”,“arch”:“x64”})
              added 82 packages from 57 contributors and audited 150 packages in 15.029s
              found 8 vulnerabilities (7 low, 1 high)
              $ cd …\fonts
              bash: cd: …fonts: No such file or directory
              $ cd …
              $ cd fonts
              ssdrive@home MINGW64 ~/MagicMirror/fonts
              $ npm install
              added 1 package from 1 contributor and audited 1 package in 0.993s
              found 0 vulnerabilities
              $ cd …
              $ notepad package.json
              $ npm start
              npm ERR! code EJSONPARSE
              npm ERR! file C:\Users\ssdrive\MagicMirror\package.json
              npm ERR! JSON.parse Failed to parse json
              npm ERR! JSON.parse Unexpected token , in JSON at position 209 while parsing near ‘…tron js/electron.js",
              npm ERR! JSON.parse “server”: "node …’
              npm ERR! JSON.parse Failed to parse package.json data.
              npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
              npm ERR! C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_33_43_328Z-debug.log
              $ npm start
              npm ERR! C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_41_40_531Z-debug.log
                sdetweil @vivian0239
                @vivian0239 said in Installing Magic mirror on windows 10:
                $ cd …\fonts
                $ cd …
                $ cd fonts
                $ npm install
                there are 3 dots in the CD commands change it to 2 dots
                do NOT install under min.
                just open a command prompt (CMD.exe) and do npm install
                  suqiqi
                  ‘node_moudles’ is not recognized as an internal or external command,
                  operable program or batch file.
                    suqiqi @sdetweil
                    @sdetweil ‘node_moudles’ is not recognized as an internal or external command,
                    please help me thank you
                      sdetweil @suqiqi
                      @suqiqi where do u see that?
                      the folder is node_modules
                        rdcullis
                        Hi all, I am giving this a try and running into the same errors as above, i have followed the advise but i dont get the black screen, after the error fix for display, i get new error:
                        $ npm start
                        magicmirror@2.14.0 start C:\Users\Richard\MagicMirror
                        ‘electron’ is not recognized as an internal or external command,
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno 1
                        npm ERR! magicmirror@2.14.0 start: electron js/electron.js
                        npm ERR! Exit status 1
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.14.0 start script.
                        npm ERR! C:\Users\Richard\AppData\Roaming\npm-cache_logs\2021-03-29T19_41_46_132Z-debug.log
                        any help here would be great, thanks
                        • C CheapDad referenced this topic on
