    Installing Magic mirror on windows 10
    38 Posts 9 Posters 25.1k Views 11 Watching
      sdetweil @Omeliel
      @Omeliel still need to see errors in both consoles… terminal window and dev window
      • O
        Omeliel
        Thank you is exactly what in I am trying to do and followin those steps i got balck screen only either in server mode or in normal mode .
          sdetweil @Omeliel
          @Omeliel ok, so the problem is in the console side… can u show the messages from the window where you did npm start (called the terminal window)
          • O
            Omeliel
            Sorted. I post in few minutes solution.
            • O
              Omeliel
              So
              What worked for me was so far :
              Installation:
              I installed this: https://nodejs.org/en/download/
              In that tutorial, he said to install git bash. I didn’t I just used cmd from windows.
              From https://github.com/MichMich/MagicMirror I download the zip file, extracted in C: in windows (not as described in that tutorial).
              I renamed the extracted folder by just deleting master remain only MagicMirror as a folder.
              Open cmd in windows go in C:\MagicMirror and run npm install
              Then I went in C:\MagicMirror\config and delete sample extension ending to have just file named config.js
              After that, as @stedweil advised went and edit the package.json file and remove the display=${display… stuff from the start clause
              It should start with "node_modules, like this
              “start”: “node_modules/.bin/electron js/electron.js”,
              Now trying to start mm I got black screen only.
              I can’t remember where I saw but I think MichMich advice to go in C:\MagicMirror\vendor and run again npm install, I have done that and it worked.
              Now regarding editing the config.js, it need to be edited according to your area . There some tutorials for that too.
              • O
                Omeliel
                Tell me if is working for anyone who try it cuz i have 0 knowledge abot html, css, java :)) .
                Thank you @sdetweil @Michmich and @vintage89 and all others who spend their time share with us noobs :)) their knowlege.
                Kind regards
                  sdetweil @Omeliel
                  @Omeliel said in Installing Magic mirror on windows 10:
                  is it working or not? prior message says working, your new question seems it is not
                  O 2 Replies Last reply Reply Quote 0
                  • O
                    Omeliel @sdetweil
                    • O
                      Omeliel @sdetweil
                      Is working for me . Need others to try. And let us knwo.
                        easy peasy
                        install nodejs  (google search)
                        (includes npm)
                        install git (google search)
                        open cmd.exe
                        git clone magicmirror repo
                        cd MagicMirror\config
                        copy config.js.sample config.js
                        cd ..
                        npm install --only=prod
                        when finished
                        cd vendor
                        npm install
                        cd ..\fonts
                        npm install
                        cd ..
                        notepad package.json
                        change start line to
                            "start": "node_modules/.bin/electron js/electron.js",
                        ctrl-s to save
                        alt key, file, exit to close ( or use mouse, file, exit)
                        npm start
                        voila
                        C S 2 Replies Last reply Reply Quote 0
                          Chrisflex @sdetweil
                          @sdetweil I am having the exact same problem
                          I will followed the suggested remedies mentioned but still no luck.
                          Please assist if you can even via Teamviewer.
                            sdetweil @Chrisflex
                            @Chrisflex said in Installing Magic mirror on windows 10:
                            what problem?
                              Chrisflex
                              The screen remains blank after start up.
                              Here is the log from the Console
                              alt text
                                sdetweil @Chrisflex
                                @Chrisflex looks like you missed these steps
                                cd vendor
                                npm install
                                cd ..\fonts
                                npm install
                                cd ..
                                  Chrisflex
                                  Thank you very much I will try it.
                                    Chrisflex @Chrisflex
                                    Thank you again it works!
                                    I now have to figure out a way to change the news feed and get the local weather.
                                      sdetweil @Chrisflex
                                      @Chrisflex read the readme for each module
                                      • Mykle1M
                                        @sdetweil said in Installing Magic mirror on windows 10:
                                        I second this motion. :thumbs_up_light_skin_tone:
                                          Chrisflex @Mykle1
                                          @Mykle1 @sdetweil thanks I will do that
                                            sojourner @sdetweil
                                            @sdetweil This is solid gold :shooting_star: for the Windoz user in me! With these finishing steps, it works as expected. Thanks again!
                                            p.s. bonus points for suggesting notepad for editing the package.json along with the steps to quit nodepad… Too funny!
