    Installing Magic mirror on windows 10
    38 Posts 9 Posters 25.6k Views 11 Watching
      sdetweil @Omeliel
      @Omeliel ok, so the problem is in the console side… can u show the messages from the window where you did npm start (called the terminal window)
      • O
        Omeliel
        Sorted. I post in few minutes solution.
        • O
          Omeliel
          So
          What worked for me was so far :
          Installation:
          I installed this: https://nodejs.org/en/download/
          In that tutorial, he said to install git bash. I didn’t I just used cmd from windows.
          From https://github.com/MichMich/MagicMirror I download the zip file, extracted in C: in windows (not as described in that tutorial).
          I renamed the extracted folder by just deleting master remain only MagicMirror as a folder.
          Open cmd in windows go in C:\MagicMirror and run npm install
          Then I went in C:\MagicMirror\config and delete sample extension ending to have just file named config.js
          After that, as @stedweil advised went and edit the package.json file and remove the display=${display… stuff from the start clause
          It should start with "node_modules, like this
          “start”: “node_modules/.bin/electron js/electron.js”,
          Now trying to start mm I got black screen only.
          I can’t remember where I saw but I think MichMich advice to go in C:\MagicMirror\vendor and run again npm install, I have done that and it worked.
          Now regarding editing the config.js, it need to be edited according to your area . There some tutorials for that too.
          • O
            Omeliel
            Tell me if is working for anyone who try it cuz i have 0 knowledge abot html, css, java :)) .
            Thank you @sdetweil @Michmich and @vintage89 and all others who spend their time share with us noobs :)) their knowlege.
            Kind regards
              sdetweil @Omeliel
              @Omeliel said in Installing Magic mirror on windows 10:
              is it working or not? prior message says working, your new question seems it is not
              O 2 Replies Last reply
              • O
                Omeliel @sdetweil
                • O
                  Omeliel @sdetweil
                  Is working for me . Need others to try. And let us knwo.
                    easy peasy
                    install nodejs  (google search)
                    (includes npm)
                    install git (google search)
                    open cmd.exe
                    git clone magicmirror repo
                    cd MagicMirror\config
                    copy config.js.sample config.js
                    cd ..
                    npm install --only=prod
                    when finished
                    cd vendor
                    npm install
                    cd ..\fonts
                    npm install
                    cd ..
                    notepad package.json
                    change start line to
                        "start": "node_modules/.bin/electron js/electron.js",
                    ctrl-s to save
                    alt key, file, exit to close ( or use mouse, file, exit)
                    npm start
                    voila
                    C S 2 Replies Last reply
                      Chrisflex @sdetweil
                      @sdetweil I am having the exact same problem
                      I will followed the suggested remedies mentioned but still no luck.
                      Please assist if you can even via Teamviewer.
                        sdetweil @Chrisflex
                        @Chrisflex said in Installing Magic mirror on windows 10:
                        what problem?
                          Chrisflex
                          The screen remains blank after start up.
                          Here is the log from the Console
                          alt text
                            sdetweil @Chrisflex
                            @Chrisflex looks like you missed these steps
                            cd vendor
                            npm install
                            cd ..\fonts
                            npm install
                            cd ..
                              Chrisflex
                              Thank you very much I will try it.
                              C 1 Reply Last reply
                                Chrisflex @Chrisflex
                                Thank you again it works!
                                I now have to figure out a way to change the news feed and get the local weather.
                                  sdetweil @Chrisflex
                                  @Chrisflex read the readme for each module
                                  Mykle1M 1 Reply Last reply
                                  Reply Quote 2
                                  • Mykle1M
                                    @sdetweil said in Installing Magic mirror on windows 10:
                                    I second this motion. :thumbs_up_light_skin_tone:
                                      Chrisflex @Mykle1
                                      @Mykle1 @sdetweil thanks I will do that
                                        sojourner @sdetweil
                                        @sdetweil This is solid gold :shooting_star: for the Windoz user in me! With these finishing steps, it works as expected. Thanks again!
                                        p.s. bonus points for suggesting notepad for editing the package.json along with the steps to quit nodepad… Too funny!
                                        • V
                                          vivian0239
                                          Hi, everyone!
                                          I have a task to install Magic Mirror on Windows. And I am very happy to find here. I tried the steps, but it still has error. My pc is Windows 10.
                                          I also changed package.json from:
                                          “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
                                          to
                                          I am new to JS, please tell me where I am wrong. Thank you!
                                          This is my log:
                                          ssdrive@home MINGW64 ~/MagicMirror
                                          $ npm install --only=prod
                                          magicmirror@2.12.0 install C:\Users\ssdrive\MagicMirror
                                          echo "Installing vendor files …
                                          " && cd vendor && npm install --loglevel=error
                                          magicmirror@2.12.0 postinstall C:\Users\ssdrive\MagicMirror
                                          npm run install-fonts && echo "MagicMirror installation finished successfully!
                                          magicmirror@2.12.0 install-fonts C:\Users\ssdrive\MagicMirror
                                          echo "Installing fonts …
                                          " && cd fonts && npm install --loglevel=error
                                          "Installing fonts …
                                          audited 1050 packages in 16.723s
                                          75 packages are looking for funding
                                          run npm fund for details
                                          found 3 low severity vulnerabilities
                                          run npm audit fix to fix them, or npm audit for details
                                          $ cd vendor
                                          ssdrive@home MINGW64 ~/MagicMirror/vendor
                                          $ npm install
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules\fsevents):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“win32”,“arch”:“x64”})
                                          added 82 packages from 57 contributors and audited 150 packages in 15.029s
                                          found 8 vulnerabilities (7 low, 1 high)
                                          $ cd …\fonts
                                          bash: cd: …fonts: No such file or directory
                                          $ cd …
                                          $ cd fonts
                                          ssdrive@home MINGW64 ~/MagicMirror/fonts
                                          $ npm install
                                          added 1 package from 1 contributor and audited 1 package in 0.993s
                                          found 0 vulnerabilities
                                          $ cd …
                                          $ notepad package.json
                                          $ npm start
                                          npm ERR! code EJSONPARSE
                                          npm ERR! file C:\Users\ssdrive\MagicMirror\package.json
                                          npm ERR! JSON.parse Failed to parse json
                                          npm ERR! JSON.parse Unexpected token , in JSON at position 209 while parsing near ‘…tron js/electron.js",
                                          npm ERR! JSON.parse “server”: "node …’
                                          npm ERR! JSON.parse Failed to parse package.json data.
                                          npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
                                          npm ERR! C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_33_43_328Z-debug.log
                                          $ npm start
                                          npm ERR! C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_41_40_531Z-debug.log
                                            sdetweil @vivian0239
                                            @vivian0239 said in Installing Magic mirror on windows 10:
                                            $ cd …\fonts
                                            $ cd …
                                            $ cd fonts
                                            $ npm install
                                            there are 3 dots in the CD commands change it to 2 dots
                                            do NOT install under min.
                                            just open a command prompt (CMD.exe) and do npm install
