    Installing Magic mirror on windows 10
    38 Posts 9 Posters 25.9k Views 11 Watching
    • O
      Omeliel
      Thank you is exactly what in I am trying to do and followin those steps i got balck screen only either in server mode or in normal mode .
        sdetweil @Omeliel
        @Omeliel ok, so the problem is in the console side… can u show the messages from the window where you did npm start (called the terminal window)
        • O
          Omeliel
          Sorted. I post in few minutes solution.
          • O
            Omeliel
            So
            What worked for me was so far :
            Installation:
            I installed this: https://nodejs.org/en/download/
            In that tutorial, he said to install git bash. I didn’t I just used cmd from windows.
            From https://github.com/MichMich/MagicMirror I download the zip file, extracted in C: in windows (not as described in that tutorial).
            I renamed the extracted folder by just deleting master remain only MagicMirror as a folder.
            Open cmd in windows go in C:\MagicMirror and run npm install
            Then I went in C:\MagicMirror\config and delete sample extension ending to have just file named config.js
            After that, as @stedweil advised went and edit the package.json file and remove the display=${display… stuff from the start clause
            It should start with "node_modules, like this
            “start”: “node_modules/.bin/electron js/electron.js”,
            Now trying to start mm I got black screen only.
            I can’t remember where I saw but I think MichMich advice to go in C:\MagicMirror\vendor and run again npm install, I have done that and it worked.
            Now regarding editing the config.js, it need to be edited according to your area . There some tutorials for that too.
            • O
              Omeliel
              Tell me if is working for anyone who try it cuz i have 0 knowledge abot html, css, java :)) .
              Thank you @sdetweil @Michmich and @vintage89 and all others who spend their time share with us noobs :)) their knowlege.
              Kind regards
                sdetweil @Omeliel
                @Omeliel said in Installing Magic mirror on windows 10:
                is it working or not? prior message says working, your new question seems it is not
                O 2 Replies Last reply
                • O
                  Omeliel @sdetweil
                  • O
                    Omeliel @sdetweil
                    Is working for me . Need others to try. And let us knwo.
                      easy peasy
                      install nodejs  (google search)
                      (includes npm)
                      install git (google search)
                      open cmd.exe
                      git clone magicmirror repo
                      cd MagicMirror\config
                      copy config.js.sample config.js
                      cd ..
                      npm install --only=prod
                      when finished
                      cd vendor
                      npm install
                      cd ..\fonts
                      npm install
                      cd ..
                      notepad package.json
                      change start line to
                          "start": "node_modules/.bin/electron js/electron.js",
                      ctrl-s to save
                      alt key, file, exit to close ( or use mouse, file, exit)
                      npm start
                      voila
                      C S 2 Replies Last reply
                        Chrisflex @sdetweil
                        @sdetweil I am having the exact same problem
                        I will followed the suggested remedies mentioned but still no luck.
                        Please assist if you can even via Teamviewer.
                          sdetweil @Chrisflex
                          @Chrisflex said in Installing Magic mirror on windows 10:
                          what problem?
                            Chrisflex
                            The screen remains blank after start up.
                            Here is the log from the Console
                            alt text
                              sdetweil @Chrisflex
                              @Chrisflex looks like you missed these steps
                              cd vendor
                              npm install
                              cd ..\fonts
                              npm install
                              cd ..
                                Chrisflex
                                Thank you very much I will try it.
                                C 1 Reply Last reply
                                  Chrisflex @Chrisflex
                                  Thank you again it works!
                                  I now have to figure out a way to change the news feed and get the local weather.
                                    sdetweil @Chrisflex
                                    @Chrisflex read the readme for each module
                                    Mykle1M 1 Reply Last reply
                                    Reply Quote 2
                                    • Mykle1M
                                      @sdetweil said in Installing Magic mirror on windows 10:
                                      I second this motion. :thumbs_up_light_skin_tone:
                                        Chrisflex @Mykle1
                                        @Mykle1 @sdetweil thanks I will do that
                                          sojourner @sdetweil
                                          @sdetweil This is solid gold :shooting_star: for the Windoz user in me! With these finishing steps, it works as expected. Thanks again!
                                          p.s. bonus points for suggesting notepad for editing the package.json along with the steps to quit nodepad… Too funny!
                                          • V
                                            vivian0239
                                            Hi, everyone!
                                            I have a task to install Magic Mirror on Windows. And I am very happy to find here. I tried the steps, but it still has error. My pc is Windows 10.
                                            I also changed package.json from:
                                            “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
                                            to
                                            I am new to JS, please tell me where I am wrong. Thank you!
                                            This is my log:
                                            ssdrive@home MINGW64 ~/MagicMirror
                                            $ npm install --only=prod
                                            magicmirror@2.12.0 install C:\Users\ssdrive\MagicMirror
                                            echo "Installing vendor files …
                                            " && cd vendor && npm install --loglevel=error
                                            magicmirror@2.12.0 postinstall C:\Users\ssdrive\MagicMirror
                                            npm run install-fonts && echo "MagicMirror installation finished successfully!
                                            magicmirror@2.12.0 install-fonts C:\Users\ssdrive\MagicMirror
                                            echo "Installing fonts …
                                            " && cd fonts && npm install --loglevel=error
                                            "Installing fonts …
                                            audited 1050 packages in 16.723s
                                            75 packages are looking for funding
                                            run npm fund for details
                                            found 3 low severity vulnerabilities
                                            run npm audit fix to fix them, or npm audit for details
                                            $ cd vendor
                                            ssdrive@home MINGW64 ~/MagicMirror/vendor
                                            $ npm install
                                            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules\fsevents):
                                            npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“win32”,“arch”:“x64”})
                                            added 82 packages from 57 contributors and audited 150 packages in 15.029s
                                            found 8 vulnerabilities (7 low, 1 high)
                                            $ cd …\fonts
                                            bash: cd: …fonts: No such file or directory
                                            $ cd …
                                            $ cd fonts
                                            ssdrive@home MINGW64 ~/MagicMirror/fonts
                                            $ npm install
                                            added 1 package from 1 contributor and audited 1 package in 0.993s
                                            found 0 vulnerabilities
                                            $ cd …
                                            $ notepad package.json
                                            $ npm start
                                            npm ERR! code EJSONPARSE
                                            npm ERR! file C:\Users\ssdrive\MagicMirror\package.json
                                            npm ERR! JSON.parse Failed to parse json
                                            npm ERR! JSON.parse Unexpected token , in JSON at position 209 while parsing near ‘…tron js/electron.js",
                                            npm ERR! JSON.parse “server”: "node …’
                                            npm ERR! JSON.parse Failed to parse package.json data.
                                            npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
                                            npm ERR! C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_33_43_328Z-debug.log
                                            $ npm start
                                            npm ERR! C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_41_40_531Z-debug.log
