    Installing Magic mirror on windows 10
    38 Posts 9 Posters 25.6k Views 11 Watching
    • O
      Omeliel
      I have fonts and vendor in MM. I run npm install from cmd in win beeing in mm folder. Also run node_serveronly but still same results npm.jpg node_serveronly.jpg
        sdetweil @Omeliel
        @Omeliel still need to see errors in both consoles… terminal window and dev window
        • O
          Omeliel
          Thank you is exactly what in I am trying to do and followin those steps i got balck screen only either in server mode or in normal mode .
            sdetweil @Omeliel
            @Omeliel ok, so the problem is in the console side… can u show the messages from the window where you did npm start (called the terminal window)
            • O
              Omeliel
              Sorted. I post in few minutes solution.
              • O
                Omeliel
                So
                What worked for me was so far :
                Installation:
                I installed this: https://nodejs.org/en/download/
                In that tutorial, he said to install git bash. I didn’t I just used cmd from windows.
                From https://github.com/MichMich/MagicMirror I download the zip file, extracted in C: in windows (not as described in that tutorial).
                I renamed the extracted folder by just deleting master remain only MagicMirror as a folder.
                Open cmd in windows go in C:\MagicMirror and run npm install
                Then I went in C:\MagicMirror\config and delete sample extension ending to have just file named config.js
                After that, as @stedweil advised went and edit the package.json file and remove the display=${display… stuff from the start clause
                It should start with "node_modules, like this
                “start”: “node_modules/.bin/electron js/electron.js”,
                Now trying to start mm I got black screen only.
                I can’t remember where I saw but I think MichMich advice to go in C:\MagicMirror\vendor and run again npm install, I have done that and it worked.
                Now regarding editing the config.js, it need to be edited according to your area . There some tutorials for that too.
                • O
                  Omeliel
                  Tell me if is working for anyone who try it cuz i have 0 knowledge abot html, css, java :)) .
                  Thank you @sdetweil @Michmich and @vintage89 and all others who spend their time share with us noobs :)) their knowlege.
                  Kind regards
                    sdetweil @Omeliel
                    @Omeliel said in Installing Magic mirror on windows 10:
                    is it working or not? prior message says working, your new question seems it is not
                    O 2 Replies Last reply
                    • O
                      Omeliel @sdetweil
                      • O
                        Omeliel @sdetweil
                        Is working for me . Need others to try. And let us knwo.
                          easy peasy
                          install nodejs  (google search)
                          (includes npm)
                          install git (google search)
                          open cmd.exe
                          git clone magicmirror repo
                          cd MagicMirror\config
                          copy config.js.sample config.js
                          cd ..
                          npm install --only=prod
                          when finished
                          cd vendor
                          npm install
                          cd ..\fonts
                          npm install
                          cd ..
                          notepad package.json
                          change start line to
                              "start": "node_modules/.bin/electron js/electron.js",
                          ctrl-s to save
                          alt key, file, exit to close ( or use mouse, file, exit)
                          npm start
                          voila
                          C S 2 Replies Last reply
                            Chrisflex @sdetweil
                            @sdetweil I am having the exact same problem
                            I will followed the suggested remedies mentioned but still no luck.
                            Please assist if you can even via Teamviewer.
                              sdetweil @Chrisflex
                              @Chrisflex said in Installing Magic mirror on windows 10:
                              what problem?
                                Chrisflex
                                The screen remains blank after start up.
                                Here is the log from the Console
                                alt text
                                  sdetweil @Chrisflex
                                  @Chrisflex looks like you missed these steps
                                  cd vendor
                                  npm install
                                  cd ..\fonts
                                  npm install
                                  cd ..
                                    Chrisflex
                                    Thank you very much I will try it.
                                    C 1 Reply Last reply
                                      Chrisflex @Chrisflex
                                      Thank you again it works!
                                      I now have to figure out a way to change the news feed and get the local weather.
                                        sdetweil @Chrisflex
                                        @Chrisflex read the readme for each module
                                        Mykle1M 1 Reply Last reply
                                        Reply Quote 2
                                        • Mykle1M
                                          @sdetweil said in Installing Magic mirror on windows 10:
                                          I second this motion. :thumbs_up_light_skin_tone:
                                            Chrisflex @Mykle1
                                            @Mykle1 @sdetweil thanks I will do that
