    Installing Magic mirror on windows 10
    38 Posts 9 Posters 25.6k Views 11 Watching
      sdetweil @Omeliel
      @Omeliel show me the output of npm install
      • O
        Omeliel
          sdetweil @Omeliel
          @Omeliel u are doing ~/MagicMirror something
          you want
          THEN
          npm install
          I think this is causing the files to be put in the users root, NOT in the MagicMirror folder
          fonts should be installed in MagicMirror/fonts
          vendor should be installed in MagicMirror/vendor
          can u see if ~/fonts and ~/vendor exist?
          also, at the end, this will fail to run, as the MINGW env has no graphical environment itself,
          so electron won’t run… u will need to run serveronly mode and access the MM via another browser
          you could install MM ON windows (open cmd.exe)…
          also, you are installing under MINGW (looks like linux), not on windows natively
            @Omeliel you could install on windows directly
            https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10
            • O
              Omeliel
              I have fonts and vendor in MM. I run npm install from cmd in win beeing in mm folder. Also run node_serveronly but still same results npm.jpg node_serveronly.jpg
                sdetweil @Omeliel
                @Omeliel still need to see errors in both consoles… terminal window and dev window
                • O
                  Omeliel
                  Thank you is exactly what in I am trying to do and followin those steps i got balck screen only either in server mode or in normal mode .
                    sdetweil @Omeliel
                    @Omeliel ok, so the problem is in the console side… can u show the messages from the window where you did npm start (called the terminal window)
                    • O
                      Omeliel
                      Sorted. I post in few minutes solution.
                      • O
                        Omeliel
                        So
                        What worked for me was so far :
                        Installation:
                        I installed this: https://nodejs.org/en/download/
                        In that tutorial, he said to install git bash. I didn’t I just used cmd from windows.
                        From https://github.com/MichMich/MagicMirror I download the zip file, extracted in C: in windows (not as described in that tutorial).
                        I renamed the extracted folder by just deleting master remain only MagicMirror as a folder.
                        Open cmd in windows go in C:\MagicMirror and run npm install
                        Then I went in C:\MagicMirror\config and delete sample extension ending to have just file named config.js
                        After that, as @stedweil advised went and edit the package.json file and remove the display=${display… stuff from the start clause
                        It should start with "node_modules, like this
                        “start”: “node_modules/.bin/electron js/electron.js”,
                        Now trying to start mm I got black screen only.
                        I can’t remember where I saw but I think MichMich advice to go in C:\MagicMirror\vendor and run again npm install, I have done that and it worked.
                        Now regarding editing the config.js, it need to be edited according to your area . There some tutorials for that too.
                        • O
                          Omeliel
                          Tell me if is working for anyone who try it cuz i have 0 knowledge abot html, css, java :)) .
                          Thank you @sdetweil @Michmich and @vintage89 and all others who spend their time share with us noobs :)) their knowlege.
                          Kind regards
                            sdetweil @Omeliel
                            @Omeliel said in Installing Magic mirror on windows 10:
                            is it working or not? prior message says working, your new question seems it is not
                            O 2 Replies Last reply
                            • O
                              Omeliel @sdetweil
                              • O
                                Omeliel @sdetweil
                                Is working for me . Need others to try. And let us knwo.
                                  easy peasy
                                  install nodejs  (google search)
                                  (includes npm)
                                  install git (google search)
                                  open cmd.exe
                                  git clone magicmirror repo
                                  cd MagicMirror\config
                                  copy config.js.sample config.js
                                  cd ..
                                  npm install --only=prod
                                  when finished
                                  cd vendor
                                  npm install
                                  cd ..\fonts
                                  npm install
                                  cd ..
                                  notepad package.json
                                  change start line to
                                      "start": "node_modules/.bin/electron js/electron.js",
                                  ctrl-s to save
                                  alt key, file, exit to close ( or use mouse, file, exit)
                                  npm start
                                  voila
                                  C S 2 Replies Last reply
                                    Chrisflex @sdetweil
                                    @sdetweil I am having the exact same problem
                                    I will followed the suggested remedies mentioned but still no luck.
                                    Please assist if you can even via Teamviewer.
                                      sdetweil @Chrisflex
                                      @Chrisflex said in Installing Magic mirror on windows 10:
                                      what problem?
                                        Chrisflex
                                        The screen remains blank after start up.
                                        Here is the log from the Console
                                        alt text
                                          sdetweil @Chrisflex
                                          @Chrisflex looks like you missed these steps
                                          cd vendor
                                          npm install
                                          cd ..\fonts
                                          npm install
                                          cd ..
                                            Chrisflex
                                            Thank you very much I will try it.
                                            C 1 Reply Last reply
