    Installing Magic mirror on windows 10
    38 Posts 9 Posters 21.6k Views 11 Watching
      sdetweil @Omeliel
      @Omeliel said in Installing Magic mirror on windows 10:
      Type npm install and press the Enter key. This will install the dependencies for MagicMirror.
      looks like this step failed
      • O Offline
        Omeliel
        I have done that . Npm install . Still black screen.
          sdetweil @Omeliel
          @Omeliel show me the output of npm install
          • O Offline
            Omeliel
              sdetweil @Omeliel
              @Omeliel u are doing ~/MagicMirror something
              you want
              THEN
              npm install
              I think this is causing the files to be put in the users root, NOT in the MagicMirror folder
              fonts should be installed in MagicMirror/fonts
              vendor should be installed in MagicMirror/vendor
              can u see if ~/fonts and ~/vendor exist?
              also, at the end, this will fail to run, as the MINGW env has no graphical environment itself,
              so electron won’t run… u will need to run serveronly mode and access the MM via another browser
              you could install MM ON windows (open cmd.exe)…
              also, you are installing under MINGW (looks like linux), not on windows natively
                @Omeliel you could install on windows directly
                https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10
                • O Offline
                  Omeliel
                  I have fonts and vendor in MM. I run npm install from cmd in win beeing in mm folder. Also run node_serveronly but still same results npm.jpg node_serveronly.jpg
                    sdetweil @Omeliel
                    @Omeliel still need to see errors in both consoles… terminal window and dev window
                    • O Offline
                      Omeliel
                      Thank you is exactly what in I am trying to do and followin those steps i got balck screen only either in server mode or in normal mode .
                        sdetweil @Omeliel
                        @Omeliel ok, so the problem is in the console side… can u show the messages from the window where you did npm start (called the terminal window)
                        • 1 / 4
