    Installing Magic mirror on windows 10
    38 Posts 9 Posters 20.9k Views 11 Watching
    • V Offline
      vintage89
      I’ve tried installing MM on windows 10, while I wait for my new raspberry.
      I’ve been following these instructions: https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7-10
      But when I want to start it I get this error:
      $ DISPLAY=:0 npm start
      > magicmirror@2.11.0 start C:\Users\andre\Desktop\MagicMirror
      'DISPLAY' is not recognized as an internal or external command,
      operable program or batch file.
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.11.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.11.0 start script.
      npm ERR!     C:\Users\andre\AppData\Roaming\npm-cache\_logs\2020-04-10T21_40_49_270Z-debug.log
        sdetweil @vintage89
        @vintage89 edit the package.json file and remove the display=${display… stuff from the start clause
        It should start with "node_modules, like this
        “start”: “node_modules/.bin/electron js/electron.js”,
        • O Offline
          Omeliel
          Hi. New around here. I followed the steps it runs but it show only a black screen with no modules loaded. Can you help ?
          Laptop config:
          I7
          16 Gb ram
          Nvidia 1060 gtx
          Kind regards
            sdetweil @Omeliel
            @Omeliel tell me more, what steps did u follow?
            if you did npm start, there should be messages in the command prompt window…
            otherwise, on that black screen do ctrl-shift-i to open the developers window,
            select the tab labeled console, and scroll up to find any errors…
            • O Offline
              Omeliel @sdetweil
              @sdetweil all of this :
              Type cd MagicMirror and press the Enter key. Now you’re in the ~/MagicMirror directory.
              Type npm install and press the Enter key. This will install the dependencies for MagicMirror.
              It will take some time to complete depending on your PC. Mine took 6 minutes.
              You may see npm WARN for a few items but these are NOT errors and don’t affect anything.
              When that’s done, we continue, still in the ~/MagicMirror directory.
              Type npm start and press the Enter key. You WILL get a “Please create a config file.” message
              I just wanted you to see it. No worries. We’re almost done. Follow me!
              Press the Alt key on your keyboard. This drops down a menu bar at the top of your screen.
              You won’t see your mouse cursor until you move it all the way to the top of the screen into the
              menu bar. There it is! Click on the File menu and click Exit. This brings you back to your
              desktop. If there is a “Windows Security Alert” window concerning “Electron” click the Allow access button.
              You’ll notice “fatal: Not a git repository (or any of the parent directories): .git” in your teminal window.
              Not to worry. Minimize your terminal window or move it out of the way.
              Here we create your working config.js file.
              We’re not going to use the terminal to do this. This way is just easier, especially for beginners.
              From your desktop, navigate to your MagicMirror folder. Remember where it is? 🙂
              Double click the MagicMirror folder.
              Double click the config folder.
              Right click the config.js.sample file.
              Choose Copy
              Right click somewhere else in that same window and choose Paste.
              Rename the “COPY” you just pasted to config.js
              Windows may ask about changing the file type. Accept! It’s now a JScript Script File.
              The config.js file that you just created is your working config file.
              This is where you’ll add your entries for other modules to your mirror.
              Had enough? Lets run that MagicMirror, NOW!
              If your Git Bash terminal window is still open (I never told you to close it) we can continue.
              If you need to open a new one then do so now and type cd MagicMirror to enter the MagicMirror directory.
              Now that you’re in the ~/MagicMirror directory of your terminal:
              Plus I del Display=0 as you said . Before that aint work .
              Errors :
              nunjucks.min.js:1 Failed to load resource: the server responded with a status of 404 (Not Found)
              Roboto-Condensed-Regular.woff2:1 Failed to load resource: the server responded with a status of 404 (Not Found)
              Roboto-Condensed-Regular.woff:1 Failed to load resource: the server responded with a status of 404 (Not Found)
                sdetweil @Omeliel
                @Omeliel said in Installing Magic mirror on windows 10:
                looks like this step failed
                • O Offline
                  Omeliel
                  I have done that . Npm install . Still black screen.
                    sdetweil @Omeliel
                    @Omeliel show me the output of npm install
                    • O Offline
                      Omeliel
                        sdetweil @Omeliel
                        @Omeliel u are doing ~/MagicMirror something
                        you want
                        THEN
                        npm install
                        I think this is causing the files to be put in the users root, NOT in the MagicMirror folder
                        fonts should be installed in MagicMirror/fonts
                        vendor should be installed in MagicMirror/vendor
                        can u see if ~/fonts and ~/vendor exist?
                        also, at the end, this will fail to run, as the MINGW env has no graphical environment itself,
                        so electron won’t run… u will need to run serveronly mode and access the MM via another browser
                        you could install MM ON windows (open cmd.exe)…
                        also, you are installing under MINGW (looks like linux), not on windows natively
                        • 1 / 4
