    Installing Magic mirror on windows 10
    38 Posts 9 Posters 20.9k Views 11 Watching
      sdetweil @Chrisflex
      @Chrisflex looks like you missed these steps
      cd vendor
      npm install
      cd ..\fonts
      npm install
      cd ..
        Chrisflex
        Thank you very much I will try it.
          Chrisflex @Chrisflex
          Thank you again it works!
          I now have to figure out a way to change the news feed and get the local weather.
            sdetweil @Chrisflex
            @Chrisflex read the readme for each module
              @sdetweil said in Installing Magic mirror on windows 10:
              I second this motion. :thumbs_up_light_skin_tone:
                Chrisflex @Mykle1
                @Mykle1 @sdetweil thanks I will do that
                  sojourner @sdetweil
                  @sdetweil This is solid gold :shooting_star: for the Windoz user in me! With these finishing steps, it works as expected. Thanks again!
                  p.s. bonus points for suggesting notepad for editing the package.json along with the steps to quit nodepad… Too funny!
                  • V Offline
                    vivian0239
                    Hi, everyone!
                    I have a task to install Magic Mirror on Windows. And I am very happy to find here. I tried the steps, but it still has error. My pc is Windows 10.
                    I also changed package.json from:
                    “start”: “DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js”,
                    to
                    “start”: “node_modules/.bin/electron js/electron.js”,
                    I am new to JS, please tell me where I am wrong. Thank you!
                    This is my log:
                    ssdrive@home MINGW64 ~/MagicMirror
                    $ npm install --only=prod
                    magicmirror@2.12.0 install C:\Users\ssdrive\MagicMirror
                    echo "Installing vendor files …
                    " && cd vendor && npm install --loglevel=error
                    magicmirror@2.12.0 postinstall C:\Users\ssdrive\MagicMirror
                    npm run install-fonts && echo "MagicMirror installation finished successfully!
                    magicmirror@2.12.0 install-fonts C:\Users\ssdrive\MagicMirror
                    echo "Installing fonts …
                    " && cd fonts && npm install --loglevel=error
                    "Installing fonts …
                    audited 1050 packages in 16.723s
                    75 packages are looking for funding
                    run npm fund for details
                    found 3 low severity vulnerabilities
                    run npm audit fix to fix them, or npm audit for details
                    $ cd vendor
                    ssdrive@home MINGW64 ~/MagicMirror/vendor
                    $ npm install
                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules\fsevents):
                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“win32”,“arch”:“x64”})
                    added 82 packages from 57 contributors and audited 150 packages in 15.029s
                    found 8 vulnerabilities (7 low, 1 high)
                    $ cd …\fonts
                    bash: cd: …fonts: No such file or directory
                    $ cd …
                    $ cd fonts
                    ssdrive@home MINGW64 ~/MagicMirror/fonts
                    $ npm install
                    added 1 package from 1 contributor and audited 1 package in 0.993s
                    found 0 vulnerabilities
                    $ cd …
                    $ notepad package.json
                    $ npm start
                    npm ERR! code EJSONPARSE
                    npm ERR! file C:\Users\ssdrive\MagicMirror\package.json
                    npm ERR! JSON.parse Failed to parse json
                    npm ERR! JSON.parse Unexpected token , in JSON at position 209 while parsing near ‘…tron js/electron.js",
                    npm ERR! JSON.parse “server”: "node …’
                    npm ERR! JSON.parse Failed to parse package.json data.
                    npm ERR! JSON.parse package.json must be actual JSON, not just JavaScript.
                    npm ERR! C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_33_43_328Z-debug.log
                    $ npm start
                    npm ERR! C:\Users\ssdrive\AppData\Roaming\npm-cache_logs\2020-08-09T20_41_40_531Z-debug.log
                      sdetweil @vivian0239
                      @vivian0239 said in Installing Magic mirror on windows 10:
                      $ cd …\fonts
                      $ cd …
                      $ cd fonts
                      $ npm install
                      there are 3 dots in the CD commands change it to 2 dots
                      do NOT install under min.
                      just open a command prompt (CMD.exe) and do npm install
                        suqiqi
                        ‘node_moudles’ is not recognized as an internal or external command,
                        operable program or batch file.
                        • 3 / 4
