    Works with Node Serveronly but not npm start MM
    24 Posts 4 Posters 5.8k Views 4 Watching
      JohnBachini @sdetweil
      Wow… you got it working… thanks a lot for that.!! :thumbs_up:
      Think there were a few people who couldn’t get this module working so hopefully this will of solved it for them as well.
        sdetweil @JohnBachini
        @JohnBachini thanks for the feedback… looks like you gotta go ALL the way into the failing folder. sheesh…
          sdetweil
          I updated the two issues in this module on github that reference this problem with the fix instructions here
          so eventually the google search will link them together
            I bet you thought you’d heard the last of this, so you know how you managed to get it all working. Well the problem now is the complete opposite. In that now it doesn’t work node servermode. ?
            I thought i was going mad and must have been running it incorrectly :thinking_face:
            Any ideas ?
            pi@MagicMirror:~ $ cd MagicMirror/
            pi@MagicMirror:~/MagicMirror $ node serveronly
            [2020-04-29 14:24:42.858] [LOG]    Starting MagicMirror: v2.11.0
            [2020-04-29 14:24:42.868] [LOG]    Loading config ...
            [2020-04-29 14:24:42.873] [LOG]    Loading module helpers ...
            [2020-04-29 14:24:42.874] [LOG]    No helper found for module: MMM-Logging.
            [2020-04-29 14:24:42.875] [LOG]    No helper found for module: alert.
            [2020-04-29 14:24:42.911] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:42.912] [LOG]    Module helper loaded: updatenotification
            [2020-04-29 14:24:42.912] [LOG]    No helper found for module: clock.
            [2020-04-29 14:24:42.913] [LOG]    No helper found for module: MMM-OpenmapWeather.
            [2020-04-29 14:24:42.913] [LOG]    No helper found for module: weatherforecast.
            [2020-04-29 14:24:43.238] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:43.238] [LOG]    Module helper loaded: MMM-Tools
            [2020-04-29 14:24:43.239] [LOG]    No helper found for module: MMM-PlexNowPlaying.
            [2020-04-29 14:24:43.240] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:43.241] [LOG]    Module helper loaded: mmm-hue-lights
            [2020-04-29 14:24:43.243] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:43.243] [LOG]    Module helper loaded: MMM-homeassistant-sensors
            [2020-04-29 14:24:43.366] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:43.367] [LOG]    Module helper loaded: MMM-Hotword
            [2020-04-29 14:24:44.467] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:44.468] [LOG]    Module helper loaded: MMM-AssistantMk2
            [2020-04-29 14:24:44.470] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:44.470] [LOG]    Module helper loaded: MMM-Assistant2Display
            [2020-04-29 14:24:44.849] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:44.850] [LOG]    Module helper loaded: MMM-Parcel
            [2020-04-29 14:24:44.899] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
            was compiled against a different Node.js version using
            NODE_MODULE_VERSION 73. This version of Node.js requires
            NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
            the module (for instance, using `npm rebuild` or `npm install`).
            [2020-04-29 14:24:44.900] [LOG]    Loading module helpers ...
            [2020-04-29 14:24:44.901] [LOG]    No helper found for module: MMM-Logging.
            [2020-04-29 14:24:44.902] [LOG]    No helper found for module: alert.
            [2020-04-29 14:24:44.902] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:44.903] [LOG]    Module helper loaded: updatenotification
            [2020-04-29 14:24:44.903] [LOG]    No helper found for module: clock.
            [2020-04-29 14:24:44.904] [LOG]    No helper found for module: MMM-OpenmapWeather.
            [2020-04-29 14:24:44.904] [LOG]    No helper found for module: weatherforecast.
            [2020-04-29 14:24:44.905] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:44.906] [LOG]    Module helper loaded: MMM-Tools
            [2020-04-29 14:24:44.906] [LOG]    No helper found for module: MMM-PlexNowPlaying.
            [2020-04-29 14:24:44.907] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:44.907] [LOG]    Module helper loaded: mmm-hue-lights
            [2020-04-29 14:24:44.908] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:44.908] [LOG]    Module helper loaded: MMM-homeassistant-sensors
            [2020-04-29 14:24:44.909] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:44.910] [LOG]    Module helper loaded: MMM-Hotword
            [2020-04-29 14:24:44.910] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:44.911] [LOG]    Module helper loaded: MMM-AssistantMk2
            [2020-04-29 14:24:44.911] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:44.912] [LOG]    Module helper loaded: MMM-Assistant2Display
            [2020-04-29 14:24:44.912] [LOG]    Initializing new module helper ...
            [2020-04-29 14:24:44.913] [LOG]    Module helper loaded: MMM-Parcel
            [2020-04-29 14:24:44.920] [LOG]    Whoops! There was an uncaught exception...
            [2020-04-29 14:24:44.920] [ERROR]  Error: The module '/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/build/Release/magic.node'
                at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                at Module.load (internal/modules/cjs/loader.js:653:32)
                at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                at Module.require (internal/modules/cjs/loader.js:692:17)
                at require (internal/modules/cjs/helpers.js:25:18)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-synology-ds/node_modules/mmmagic/lib/index.js:1:13)
                at Module._compile (internal/modules/cjs/loader.js:778:30)
                at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
            [2020-04-29 14:24:44.924] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [2020-04-29 14:24:44.925] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
