    Mistake in the config.js and i dont no
    11 Posts 4 Posters 12.1k Views 3 Watching
    • T
      Thomas
      I´m a Newbie and a have a problem with the config.js at the Magic Mirror.
      I ´m insert a the third module MMM-Fuel and now a have a error after the boot.
      Here ist my config.js datei.
      can someone help me with this Problem ?
      Many thanks !!
      Thomas
      /* Magic Mirror Config Sample
      • By Michael Teeuw http://michaelteeuw.nl
      • MIT Licensed.
      var config = {
      port: 8080,
      language: 'en',
      timeFormat: 24,
      units: 'metric',
      		module: 'alert',
      		module: 'clock',
      		position: 'top_left'
      		module: 'calendar',
      		module: 'compliments',
      		position: 'lower_third'
      		module: 'currentweather',
      		position: 'top_right',
      			locationID: '',  //ID from http://www.openweathermap.org
      			appid: 'YOUR_OPENWEATHER_API_KEY'
      		module: 'weatherforecast',
      		header: 'Weather Forecast',
      			locationID: '5128581',  //ID from http://www.openweathermap.org
      		module: 'newsfeed',
      		position: 'bottom_bar',
      			feeds: [
      					title: "New York Times",
      			showSourceTitle: true,
      			showPublishDate: true
                          module: "MMM-Fuel",
                              api_key: "e4a59b56-f6c7-4bef-1eb3-456af035d82c",
                              lat: 52.518611,
                              lng: 13.408333,
                              types: ["diesel"],
      if (typeof module !== ‘undefined’) {module.exports = config;}
      B 1 Reply Last reply
      • B
        broberg Project Sponsor @Thomas
        @Thomas
        you are missing { }, around the fuel module
        should look like this
                            module: "MMM-Fuel",
                                api_key: "",
                                lat: 52.518611,
                                lng: 13.408333,
                                types: ["diesel"],
        And btw, don’t give out your API-key, remove it when you post config files
        Reply Quote 1
        • T
          Thomas
          @broberg
          Many thanks for your answer.
          Please lock at my config.js again.
          There is a error in it but i dont no.
          Sorry that i request you again !!
          Many thanks ! (you are german ?)
          Thomas
          var config = {
          port: 8080,
          language: 'en',
          timeFormat: 24,
          units: 'metric',
          		module: 'alert',
          		module: 'clock',
          		module: 'calendar',
          		module: 'newsfeed',
          			feeds: [
                              module: "MMM-Fuel",
                                  api_key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                  lat: 52.518611,
                                  lng: 13.408333,
                                  types: ["diesel"],
          B T Y 3 Replies Last reply
          • B
            @Thomas
            try to remove the dots under types: [“diesel”],
            I’m Swedish btw.
            Reply Quote 1
            • T
              Thomas @Thomas
              @Thomas
              Good morning and thanks for your answer.
              i delete the points under diesel but it doesn´t work.
              we will see :-)
              Many thanks for your support !
              Best Regards Thomas
              • Y
                yawns Moderator @Thomas
                Please remove this
                  	module: 'calendar',
                T 1 Reply Last reply
                Reply Quote 1
                • T
                  Thomas @yawns
                  @yawns
                  Good morning , thanks for the support !
                  I delete the entires and now i have no error but a blank screen :-)
                  Idont now …it very difficult.
                  i think i quit the projekt…its better :-)
                  here is my config again …
                  Best regards from Germany !
                  Thomas
                  var config = {
                  port: 8080,
                  language: 'en',
                  timeFormat: 24,
                  units: 'metric',
                  		module: 'alert',
                  		module: 'clock',
                  		module: 'newsfeed',
                  			feeds: [
                                      module: "MMM-Fuel",
                                          api_key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                          lat: 52.518611,
                                          lng: 13.408333,
                                          types: ["diesel"],
                  • Y
                    yawns Moderator
                    Okay, dann eben auf deutsch.
                    Ich habe deine config Datei komplett kopiert und bei mir eingefügt. Das funktioniert, also kopiere bitte das hier drunter komplett und ersetze deine config Datei dadurch.
                    var config = {
                    	port: 8080,
                    	language: 'de',
                    	timeFormat: 24,
                    	units: 'metric',
                    			module: 'alert',
                    			module: 'clock',
                    			module: 'newsfeed',
                    				feeds: [
                    			module: "MMM-Fuel",
                    				lat: 52.518611,
                    				lng: 13.408333,
                    				types: ["diesel"],
                    Hier fehlen natürlich die Keys für Currentweather/Forecast und MMM-Fuel, aber ich sehe Ausgaben auf dem Bildschirm.
                    Hast du MMM-Fuel auch als Modul bei dir installiert? Oder hast du nur die Einträge in der config Datei gesetzt? Wenn ich nur die Einträge setze, sehe ich einen schwarzen Bildschirm. Wenn ich aber das Modul installiere, dann funktioniert es. Öffne eine Konsole auf dem Raspberry oder nutze eine SSH shell, um auf dem Raspberry zu arbeiten:
                    cd ~/MagicMirror/modules
                    git clone https://github.com/fewieden/MMM-Fuel.git
                    cd MMM-Fuel
                    npm install
                    Danach den MagicMirror neu starten und testen.
                    Grüße aus Solingen, Stefan
                    Reply Quote 1
                    • T
                      Thomas @yawns
                      @yawns
                      Hallo Stefan,
                      vielen vielen Dank für deine Hilfe.
                      Ich habe alles so gamacht wie Du beschrieben hast und siehe da es lief.
                      Super !
                      Es ist als absoluter Änfänger machmal gar nicht so leicht.
                      Eine Frag zu Abschluss. Kann man die Schriftfarbe der einzelnen Module auch ändern ?
                      Vielleicht hast Du ja da auch eine Lösung parat. :-)
                      Dir und deiner Familie einen guten Rutsch in´s neue Jahr und die besten Wünsche für 2017 !
                      Grüße aus Steinheim /Westf
                      Thomas
                      strawberry 3.141S 1 Reply Last reply
                      • strawberry 3.141S
                        strawberry 3.141 Project Sponsor Module Developer @Thomas
                        @Thomas you can define your own styling in ~/MagicMirror/css/custom.css, for the most modules this should work
                        .MODULENAME {
                          color: blue;
                        Reply Quote 1
                        • T
                          Thomas @strawberry 3.141
                          @strawberry-3.141
                          Thanks a lot ! It works !
                          Thomas
