    read csv-data and put it in an array
    313 Posts 3 Posters 540.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp cool… do you want ages aligned?
      • PerlchampP Offline
        Perlchamp
        yes, of course, sir …
          sdetweil @Perlchamp
          @Perlchamp need to specify width of td
          By default, a browser will adjust table columns to fit the contents of the table. However, if you want to control the width of each column, you can do so by adjusting the width of each or of a single row.
          if you had th, then you could see the length of the names as they go by, and then adjust the th width before sending the content to MM…
            Perlchamp
            width:27px; is placed in css
            but this:
            //bodyTDimage.id = "birthday-td-image";
            works. i really have to write html-text in the module-file ?
              sdetweil @Perlchamp
              @Perlchamp eh? commenting out a line?
              have a th is the same as what you have document.createElement(“th”)
                Perlchamp
                wrong line, moment:
                //bodyTDimage.className = "td-image";
                this works, but unformatted, of course
                i don’t like things like:
                innerHTLM = tags, tags, tags …
                  sdetweil @Perlchamp
                  @Perlchamp eh? where is that?
                    Perlchamp
                    getDom:
                        getDom: function() {
                    	var self = this;
                    	// tell MM to call and get our content
                    	Log.log(JSON.stringify(this.active_birthdays))
                    	if ((moment() > this.midnight) || (!this.loaded)) {
                    	    var month = moment().month();
                    	    var year = moment().year();
                    	    var monthName = moment().format("MMMM");
                    	    var monthLength = moment().daysInMonth();
                    	    // create table
                    	    var wrapper = document.createElement("table");
                    	    wrapper.className = 'table';
                    	    wrapper.id = 'birthday-table';
                    	    // create header
                    	    var tHeader = document.createElement("thead");
                    	    tHeader.className = "thead";
                    	    tHeader.id = "birthday-thead";
                    	    var headerTR = document.createElement("tr");
                    	    headerTR.className = "tr-head";
                    	    headerTR.id = "birthday-tr-head";
                    	    var headerTH = document.createElement("th");
                    	    headerTH.colSpan = "2";
                    	    headerTH.scope = "col";
                    	    headerTH.className = "th-head";
                    	    headerTH.id = "birthday-th-head";
                    	    headerTH.innerHTML = " ";
                    	    headerTR.appendChild(headerTH);
                    	    tHeader.appendChild(headerTR);
                    	    wrapper.appendChild(tHeader);
                    	    // Create TFOOT section -- currently used for debugging only
                    	    var tFooter = document.createElement('tfoot');
                    	    tFooter.className = "tfoot";
                    	    tFooter.id = "birthday-tfoot";
                    	    var footerTR = document.createElement("tr");
                    	    footerTR.className = "tr-foot";
                    	    footerTR.id = "birthday-tr-foot";
                    	    var footerTD = document.createElement("td");
                    	    footerTD.colSpan ="2";
                    	    footerTD.className = "td-foot";
                    	    footerTD.id = "birthday-td-foot";
                    	    if (this.config.debugging) {
                    		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                    	    else {
                    		footerTD.innerHTML = "&nbsp;";
                    	    footerTR.appendChild(footerTD);
                    	    tFooter.appendChild(footerTR);
                    	    wrapper.appendChild(tFooter);
                    	    // create TBODY section with day names
                    	    var tBody = document.createElement("tBody");
                    	    tBody.className = "tbody";
                    	    tBody.id = "birthday-tbody";
                    	    for(var birthday of Object.keys(this.active_birthdays)) {
                    		for(var person of this.active_birthdays[birthday]) {
                    		    //var m = document.createElement('div');
                    		    // create looped row section
                    		    var bodyTR = document.createElement("tr");
                    		    bodyTR.className = "tr-body";
                    		    bodyTR.id = "birthday-tr-body";
                    		    var bodyTDimage = document.createElement("td");
                    		    if (birthday.charAt(0) === "0") {
                    			birthday = birthday.replace("0","");
                    			birthday = birthday.substring(0,1);
                    		    bodyTDimage.innerText = birthday.substring(0,2);
                    		    var bodyTD = document.createElement("td");
                    		    bodyTD.className = "td-body";
                    		    bodyTD.id = "birthday-td-body";
                    		    bodyTD.innerHTML = person.name + "&nbsp;&nbsp;&nbsp;<span class=\"age-span\">" + person.age + "</span>";
                    		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                    		    //wrapper.appendChild(m);
                    		    bodyTR.appendChild(bodyTDimage);
                    		    bodyTR.appendChild(bodyTD);
                    		    tBody.appendChild(bodyTR);
                    		    wrapper.appendChild(tBody);
                    	    // pass the created content back to MM to add to DOM.
                    	    return wrapper;
                    	this.loaded = true;
                    //		var bodyAgeSpan = document.createElement("span");
                    //		bodyAgeSpan.className = "age-span";
                    //		bodyAgeSpan.id = "birthday-age-span";
                    //		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
                    //		bodyTD.appendChild(bodyAgeSpan);
                      sdetweil @Perlchamp
                      @Perlchamp fiddling with it here… technically you are supposed to have a text element as a child of the td
                      < table>
                         < tr>
                            < td> value < /td>
                      var n = document.createTextNode(value);
                        @Perlchamp
                        			   // bodyTR.className = "tr-body";
                        			   // bodyTDimage.className = "td-image";
                        			   // bodyTDimage.innerHTML = birthday;
                        			    bodyTDimage.appendChild(document.createTextNode(birthday));
                        			   // bodyTD.className = "td-body";
                        			   // bodyTD.innerTEXT = person.name ;
                        				bodyTD.appendChild(document.createTextNode(person.name));
                        				var ageTD = document.createElement("td");
                        			    ageTD.id = "birthday-td-age";
                        			    //ageTD.innerTEXT = person.age ;
                        			    ageTD.appendChild(document.createTextNode(person.age));
                        			    bodyTR.appendChild(ageTD);
                        and set the class for the text element
                          Perlchamp
                          you were too fast !!
                          to your information:
                          table needs a header (thead, tr, th) and a footer (tfoot, tr, td), and, of
                          course a boda (tbody, tr, td), my cose, where a put html-tags in the table and text without variable works fine.
                          but later, if i should dissapointed, i will try this.
                            sdetweil @Perlchamp
                            @Perlchamp >where a put html-tags in the table
                            its exactly the same as writing the html
                            they don’t NEED a thead/tfoot, these are optional
                            you could create a big text string of the html < table>… < /table>
                            and then assign that text string to the wrapper div innerHTML.
                            same result…
                              @sdetweil when I had a big pile of html objects to create I wrote a little routine to hide the 4 lines per object
                              createEl(type, id, class, parent){
                                 var el = document.createElement(type)
                                 el.id=id
                                 if(class)
                                   el.classname=class
                                 parent.addChild(el)
                                 return el
                              then to use
                                  var table= this.createEl('table', "birthday-tbody", null , wrapper)
                                          etc
                                          etc
                                Perlchamp
                                in the moment you’re too fast for me …
                                this code is from the test-module:
                                	    // tabelle erstellen
                                	    // tabellenkopf erstellen
                                	    headerTH.innerHTML = this.translate(this.config.title);
                                	    else {
                                		footerTD.innerHTML = "";
                                	    // Create TBODY section with day names
                                	    var eintraege = 3;
                                	    for (var i=1; i<=eintraege; i++) {
                                		bodyTDimage.innerHTML = "23";
                                		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
                                	    this.loaded = true;
                                	    return wrapper;
                                and looks like :
                                  sdetweil @Perlchamp
                                  @Perlchamp ok, so you WANT a title, header and footer…
                                  still no different than an actual table in all html
                                  by using document.creatElement and appendChild() there are no close tags to create
                                  a td is a closed thing you add text to a td…
                                  with my little helper routine, you write exactly what you would have written in html
                                  and can indent/outdent to match for readability
                                    @Perlchamp maybe a nunjuks template , but its the same work to create the template the generate the content
                                    the template has to have all the same stuff you are doing, including the loop part
                                      Perlchamp
                                      This post is deleted!
                                        sdetweil @Perlchamp
                                        @Perlchamp said in read csv-data and put it in an array:
                                        sorry sam, but my code is displayed wrong ! what in hell …
                                        the tbody section:
                                        any < must have a space after it to display on the forum… no way to escape them yet…
                                        no real work from site admin on problem
                                          Perlchamp
                                              // Override dom generator.
                                          	    else {
                                          	    var eintraege = 3;
                                          	    for (var i=1; i< =eintraege; i++) {
                                          		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;< span class=\"age-span\"> 46 < /span > < /br > Frank Dubiel&nbsp;&nbsp; < span class=\"age-span\" > 54 < /span > < /br >Jürgen Gruse&nbsp;&nbsp; < span class=\"age-span\" > 52 < /span > ";
                                          	    this.loaded = true;
                                          	    return wrapper;
                                          this code looks like the image i did send before
                                            Perlchamp
                                            @sdetweil said in read csv-data and put it in an array:
                                            i will shurely take this, if my current html should work. now it’s too much “risk” for me, to change it.
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
