    read csv-data and put it in an array
    313 Posts 3 Posters 540.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp yep… and you could use divs(as row) and spans(as column) for the table, instead of table/tr/td
      https://html-cleaner.com/features/replace-html-table-tags-with-divs/
        sdetweil @Perlchamp
        @Perlchamp cool thing about the routine, if u decide to use div/span under instead is to fix the routine,
        no mainline code has to change
        • PerlchampP Offline
          Perlchamp
          i don’t think so. therefor i’m a little bit toooooooo retro ;-)
            sdetweil @Perlchamp
            @Perlchamp each to their own!..
              Perlchamp
              if i do this :
              //bodyTDimage.className = "td-image";
              it looks like:
              and i ask me, WHY css is not working only for this cell !!
                sdetweil @Perlchamp
                @Perlchamp td has a class, you are overriding it…
                you want that class on the text in the td, not the td itself…
                table, th, tr, all have classes… you can ADD a class instead of SET a class
                += adds to
                  Perlchamp
                  but the other cell (name plus age) works, WHY ?
                    sdetweil @Perlchamp
                    @Perlchamp not a css class wizard
                      Perlchamp
                      no i don’t override the general td-class, cause i use:
                      .modulname .classname
                      font: 16px;
                        sdetweil @Perlchamp
                        @Perlchamp but you SET the ONLY classname to be yours… classame=
                        wipes out what was there
                        you do not append yours to the list of classNames already assigned className +=
                          Perlchamp
                          ok, i will try
                            Perlchamp
                            doesn’t work either
                              sdetweil @Perlchamp
                              @Perlchamp bummer
                                Perlchamp
                                when I had a big pile of html objects to create I wrote a little routine to hide the 4 lines per object
                                where i have to place it ?
                                sam, take my going code and see by yourself. here is the css:
                                .birthdaylist .app {
                                    width: 200px;
                                    padding: 0px;
                                .birthdaylist .table {
                                  padding: 0px;
                                  margin: 0px;
                                  border: 1px solid white;
                                  width: 200px;
                                .birthdaylist .thead {
                                .birthdaylist .tr-head {
                                .birthdaylist header {
                                  letter-spacing: 0.1em;
                                  text-transform: uppercase;
                                  font-size: 20px;
                                  font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
                                  font-weight: 400;
                                  border-bottom: 1px solid #444444;
                                  line-height: 20px;
                                  padding-bottom: 5px;
                                  color: #ffffff;
                                  font-variant: small-caps;
                                .birthdaylist .tfoot {
                                  height: 10px;
                                  padding: 0px;
                                  margin: 0px;
                                .birthdaylist .tr-foot {
                                  height: 10px;
                                  padding: 0px;
                                  margin: 0px;
                                .birthdaylist .td-foot {
                                  line-height: 16px;
                                  font-size: 16px;
                                  padding: 0px;
                                  margin: 0px;
                                  border: 1px solid #444444;
                                .birthdaylist .tbody {
                                .birthdaylist .tr-body {
                                .birthdaylist .td-image {
                                  width: 27px;
                                  background-repeat: no-repeat;
                                  background-position: top left;
                                  background-image: url("/modules/birthdaylist/images/kalenderblatt.png");
                                  font-size: 20px;
                                  color: #000000;
                                  font-weight: 400;
                                  line-height: 26px;
                                  vertical-align: top;
                                  text-align: center;
                                  margin: 0px;
                                  padding: 10px 0px 0px 0px;
                                  border: 1px solid orange;
                                  height: 28px;
                                .birthdaylist .td-body {
                                  font-size: 18px;
                                  color: #888888;
                                  line-height: 22px;
                                  padding: 0px 0px 8px 8px;
                                  margin: 0px;
                                  height: 28px;
                                  width: 160px;
                                .birthdaylist span {
                                  color: orange;
                                  font-weight: bold;
                                  sdetweil @Perlchamp
                                  @Perlchamp said in read csv-data and put it in an array:
                                  its just another routine like getDom()
                                  I put it right in front of getDom
                                    Perlchamp
                                    and the parent-element itselfs get a 0 (null) as parent ?
                                      sdetweil @Perlchamp
                                      @Perlchamp i usually don’t use it for wrapper, but yes… the routine would have to check and not set if parent null, same for id
                                        Perlchamp
                                        doesn’t work (black screen) yet, BUT:
                                        1. the classes set in “” ?
                                        2. no use of appendchild ?
                                        3. the wrapper set in “” ?
                                        i did :
                                        1. no
                                        2. correct
                                        3. no
                                        question:
                                        get i problems with this.create… because of “var self = this” ?
                                          Perlchamp
                                          my code (only table):
                                          	    // create table
                                          	    var wrapper = this.createEl('table', "birthday-table", table , 0)
                                          	    //var wrapper = document.createElement("table");
                                          	    //wrapper.className = 'table';
                                          	    //wrapper.id = 'birthday-table';
                                          	    // create header
                                          	    var tHeader = this.createEl('thead', "birthday-thead", thead , wrapper)
                                          	    //var tHeader = document.createElement("thead");
                                          	    //tHeader.className = "thead";
                                          	    //tHeader.id = "birthday-thead";
                                          	    var headerTR = this.createEl('tr', "birthday-tr-head", tr-head , tHeader)
                                          	    //var headerTR = document.createElement("tr");
                                          	    //headerTR.className = "tr-head";
                                          	    //headerTR.id = "birthday-tr-head";
                                          	    var headerTH = document.createElement("th");
                                          	    //var headerTH = this.createEl('th', "birthday-th-head", th-head , headerTR)
                                          	    headerTH.colSpan = "2";
                                          	    headerTH.scope = "col";
                                          	    headerTH.innerHTML = " ";
                                          	    //headerTH.className = "th-head";
                                          	    //headerTH.id = "birthday-th-head";
                                          	    //headerTR.appendChild(headerTH);
                                          	    //tHeader.appendChild(headerTR);
                                          	    //wrapper.appendChild(tHeader);
                                          	    // Create TFOOT section -- currently used for debugging only
                                          	    var tFooter = this.createEl('tfoot', "birthday-tfood", tfoot , wrapper)
                                          	    //var tFooter = document.createElement('tfoot');
                                          	    //tFooter.className = "tfoot";
                                          	    //tFooter.id = "birthday-tfoot";
                                          	    //var footerTR = document.createElement("tr");
                                          	    var footerTR = this.createEl('tr', "birthday-tf-foot", tr-foot , tFooter)
                                          	    //footerTR.className = "tr-foot";
                                          	    //footerTR.id = "birthday-tr-foot";
                                          	    //var footerTD = document.createElement("td");
                                          	    var footerTD = this.createEl('td', "birthday-td-foot", td-foot , footerTR)
                                          	    footerTD.colSpan ="2";
                                          	    //footerTD.className = "td-foot";
                                          	    //footerTD.id = "birthday-td-foot";
                                          	    if (this.config.debugging) {
                                          		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode! < br / > Please see console log.";
                                          	    else {
                                          		footerTD.innerHTML = "&nbsp;";
                                          	    //footerTR.appendChild(footerTD);
                                          	    //tFooter.appendChild(footerTR);
                                          	    //wrapper.appendChild(tFooter);
                                          	    // create TBODY section with day names
                                          	    var tBody = this.createEl('tBody', "birthday-tbody", tbody , wrapper)
                                          	    //var tBody = document.createElement("tBody");
                                          	    //tBody.className = "tbody";
                                          	    //tBody.id = "birthday-tbody";
                                          	    for(var birthday of Object.keys(this.active_birthdays)) {
                                          		for(var person of this.active_birthdays[birthday]) {
                                          		    //var m = document.createElement('div');
                                          		    // create looped row section
                                          		    var bodyTR = this.createEl('tr', "birthday-tr-body", tr-body , tBody)
                                          		    //var bodyTR = document.createElement("tr");
                                          		    //bodyTR.className = "tr-body";
                                          		    //bodyTR.id = "birthday-tr-body";
                                          		    var bodyTDimage = this.createEl('td', "birthday-td-image", td-image , bodyTR)
                                          		    //var bodyTDimage = document.createElement("td");
                                          		    //bodyTDimage.id = "birthday-td-image";
                                          		    if (birthday.charAt(0) === "0") {
                                          			birthday = birthday.replace("0","");
                                          			birthday = birthday.substring(0,1);
                                          		    bodyTDimage.innerHTML = birthday.substring(0,2);
                                          		    var bodyTD = this.createEl('td', "birthday-td-body", td-body , bodyTDimage)
                                          		    //var bodyTD = document.createElement("td");
                                          		    //bodyTD.className = "td-body";
                                          		    //bodyTD.id = "birthday-td-body";
                                          		    bodyTD.innerHTML = person.name + "&nbsp;&nbsp;&nbsp; < span class=\"age-span\" > " + person.age + " < /span > ";
                                          		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                                          		    //wrapper.appendChild(m);
                                          		    //bodyTR.appendChild(bodyTDimage);
                                          		    //bodyTR.appendChild(bodyTD);
                                          		    //tBody.appendChild(bodyTR);
                                          		    //wrapper.appendChild(tBody);
                                            sdetweil @Perlchamp
                                            @Perlchamp all except parent in quotes
                                            tables parent is wrapper, wrappers parent is null/0
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
