    read csv-data and put it in an array
    313 Posts 3 Posters 540.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp the short birthday
      bd =(birthday.startsWith(“0”)? birthday.substring(1): birthday).split(‘.’)[0]
      if the birthday starts with ‘0’ then get the rest skipping the 0
      01.05 -> 1.05
      then split the result on ‘.’
      yields array of [ 1, 05]
      and take the first element in the array [0] = 1
      if it doesn’t start with 0,use the whole string, split and take the 1st element of array
      10.05 = [10,05] = 10
      • PerlchampP Offline
        Perlchamp
        sorry, i’m still sorting my code …uff
          Perlchamp
          back again. WITHOUT a class reference (third element = null) i see the days.
          WITH class-reference (“TD-IMAGE”) i see NO days.
          the rest is working very good, thank you for that :-)
            sdetweil @Perlchamp
            @Perlchamp what does TD-IMAGE class def look like?
              Perlchamp
              .birthdaylist .TD-IMAGE {
                width: 27px;
                font-size: 20px;
                color: #000000;
                background-repeat: no-repeat;
                background-position: top left;
                background-image: url("/modules/birthdaylist/images/kalenderblatt.png");
                font-weight: 400;
                line-height: 26px;
                vertical-align: top;
                text-align: center;
                margin: 0px;
                padding: 10px 0px 0px 0px;
                sdetweil @Perlchamp
                @Perlchamp said in read csv-data and put it in an array:
                .birthdaylist
                there is no birthdaylist class being used (unless u changed the modulename again)
                maybe
                .TD-IMAGE {
                  Perlchamp
                  IT WORKS !!, Sam, it WORKS !
                  had a wrong image-name. that is UNPARDONABLE !!
                  now, this background-image will shown, if two people tzhe same day… problems, problems, problems …
                  SOLUTION: these people (same day) should be in ONE cell, separated by < /br > therefor i don’t need a third cell ;-)
                  @Perlchamp no images email or text => i would like sending emails (with attached images, too)
                  this is the homerun, touchdown and goal !
                    sdetweil @Perlchamp
                    @Perlchamp oh by the way TD-IMAGE color is black, on black background!
                    my email was in the chat message
                      Perlchamp
                      yes black on black, why not ? because of the mirrors lucidity … better safe than sorry ;-)
                        sdetweil
                        great progress. smaller more manageable code…
                        off to sleep
                          Perlchamp
                          bloody nice dreams, sam
                            Perlchamp
                            hi sam, for me it’s a milestone :
                                // type: td, id: id of element, className: classname of element
                                // parent: parent of element, value: value
                                createEl : function (type, id, className, parent, value) {
                            	var el= document.createElement(type);
                            	if(id)
                            	    el.id = id;
                            	if(className)
                            	    el.className = className;
                            	if(parent)
                            	    parent.appendChild(el);
                            	if(value)
                            	    el.appendChild(document.createTextNode(value));
                            	return el;
                                // creates a tableheader with columnnaes
                                createTableHeader: function(parent, className, columnlabels) {
                            	var header = document.createElement("tr");
                            	for(columnName of columnlabels) {
                            	    this.createEl("th", null, className, header, columnName);
                            	parent.appendChild(header);
                            	return header;
                                // creates a tablefooter with columns
                                createTableFooter: function(parent, className, column) {
                            	var footer = document.createElement("tr");
                            	for(colContent of column) {
                            	    this.createEl("td", null, className, footer, colContent);
                            	parent.appendChild(footer);
                            	return footer;
                                // this is the major worker of the module, it provides the
                                // 	   displayable content for this module
                                getDom: function() {
                            	var wrapper = this.createEl("div",null,null,null,null);
                            	// tell MM to call and get our content
                            	Log.log(JSON.stringify(this.active_birthdays));
                            	if ((moment() > this.midnight) || (!this.loaded)) {
                            	    var month = moment().month();
                            	    var year = moment().year();
                            	    var monthName = moment().format("MMMM");
                            	    var monthLength = moment().daysInMonth();
                            	    var now_day_month = moment().format("DD.MM");
                            	    if(Object.keys(this.active_birthdays).length > 0) {
                            		// create table
                            		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
                            		// create tableheader here
                            		var table_header = this.createTableHeader(table, null, [" "," "]);
                            		// create TBODY section with day names
                            		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
                            		var day_month_now = moment().format("DD.MM");
                            		var birthdays_seen= {}
                            		var spacer = " ";
                            		for(var birthday of Object.keys(this.active_birthdays)) {
                            		    for(var person of this.active_birthdays[birthday]) {
                            			// create looped row section
                            			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
                            			// delete leading 0 and month
                            			var bd = "";
                            			if(birthdays_seen[birthday] == undefined) {
                            			    bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
                                         		    birthdays_seen[birthday] = true;
                            			let date1 = moment(birthday,'DD.MM').valueOf();
                            			let date2 = moment(now_day_month,'DD.MM').valueOf();
                            			if (date1 < date2) {
                            			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE_DIMMED" , bodyTR, bd);
                            			    var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY_DIMMED" , bodyTR, person.name);
                            			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE_DIMMED", nameTD, person.age);
                            			else {
                            			    var imageTD = this.createEl('td', "birthday-td-image", "TD-IMAGE" , bodyTR, bd);
                            			    var nameTD = this.createEl('td', "birthday-td-body", "TD-BODY" , bodyTR, person.name);
                            			    var spanTD = this.createEl("span", "birthday-span-body", "TD-AGE", nameTD, person.age);
                            			var spacerTR = this.createEl('tr', null, null , tBody, null);
                            			var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, spacer);
                            			spacerTD.colSpan = "2";
                            		// Create TFOOT section -- currently used for debugging only
                            		if (this.config.debugging) {
                            		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
                            		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                            		else {
                            	    // pass the created content back to MM to add to DOM.
                            	    return wrapper;
                            	// Dom is loaded
                            	this.loaded = true;
                            css-file via email
                              Perlchamp
                              the next working step:
                              			var bd = "";
                              			let entrie = moment(birthday,'DD.MM').valueOf();
                              			let now = moment(now_day_month,'DD.MM').valueOf();
                              			if (entrie < now) {
                              			    if(this.config.dimmEntries) {
                              			    else {
                              			else {
                              now should be the last step:
                              people who are their birthday at the same day in one cell separated by < /br > … that’s (maybe) too difficult for me, but just figuring out …
                                sdetweil @Perlchamp
                                @Perlchamp ok, busy at the moment… about an hour 13:30 my time
                                  Perlchamp
                                  ok, doesn’t matter. enjoy your meal with your family.
                                    Perlchamp
                                    i’m a step foward (did write two functions for smarter code) :
                                    	return footer;
                                        // compares two dates, requires moment.js :
                                        // output "1"  : date1 > date2
                                        // output "-1" : date1 < date2
                                        // output "0"  : fault
                                        compareDate: function(now, entrie, format) {
                                    	let date_1 = moment(now,format).valueOf();
                                    	let date_2 = moment(entrie,format).valueOf();
                                    	if (date_1 > date_2) {
                                    	    return 1;
                                    	else if (date_1 < date_2) {
                                    	    return -1;
                                    	else {
                                    	    return 0;
                                    the lastone is used here:
                                    			var bd = "";
                                    			if (this.compareDate(now,birthday,"DD.MM") === 1) {
                                    			    else {
                                    			else {
                                    it works fine for me :-). for the last step (people with the same birthday in one cell, separeted via < /br >) i have momently no ideas…
                                      sdetweil @Perlchamp
                                      @Perlchamp ok, not sure how u want to present the two people with the same date
                                      simplified code
                                      	getDom: function(){
                                      		var wrapper = this.createEl("div",null,null,null);
                                      		if(Object.keys(this.active_birthdays).length>0){
                                      			// create your table  here
                                      			var table = this.createEl("table", "birthday-table", null, wrapper );
                                      			// table header here, array of column names
                                      			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
                                      			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
                                      					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
                                      					let now = moment().format('DD.MM').valueOf();
                                      					let entrie=now
                                      					var bd = "";
                                      			    	if(birthdays_seen[birthday]==undefined){
                                      						var imageTD = this.createEl('td', null, "TD-IMAGE_"+(entrie < now)?"DIMMED":'' , bodyTR, bd);
                                      					else{
                                      						this.createEl('span', null , null , bodyTR,bd);
                                      					var nameTD = this.createEl('td', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' , bodyTR, person.name);
                                      					var spanTD = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', nameTD, person.age);
                                      					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, "----");
                                      		return wrapper;
                                      maybe? but why?
                                      we have currently two rows, 3 columns
                                         day       name   age
                                         empty  name   age
                                      you want ?? two columns?
                                         row (2 cols)
                                           day      name + age < br>
                                                       name + age
                                         row (3 cols)
                                           dayn   name   age
                                        Perlchamp
                                        hi sam,
                                        right row 2 cols day name + age < br > … < br > name+age < br >
                                        the image below displays that:
                                        look at my code, it’s all implemated but not the users in one cell :
                                        	    var now = moment();
                                        		// create table
                                        		var spacer = " ";
                                        			var bd = "";
                                        			    else {
                                        			else {
                                        		else {
                                        	    return wrapper;
                                        	// Dom is loaded
                                        	this.loaded = true;
                                          sdetweil @Perlchamp
                                          @Perlchamp i missed the span instead of td for age… working on the join
                                            Perlchamp
                                            i have the span ! look in my code !
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
