    MMM-SmartWebDisplay : Regions / Resizing
    13 Posts 5 Posters 5.5k Views 5 Watching
    • G Offline
      gaudouy
      Hello,
      I would like to know how to resize the " MMM-SmartWebDisplay " module so that it can occupy the following regions:
      alt text
      upper_third is yellow
      middle_center is cyan
      lower_third is magenta
      I would like it to occupy the following space(red):
      I tried without success for two days trying to modify the CSS, the module, the config file … nothing works.
      My skills are very very limited.
      Do you have any ideas ?
      Thanks in advance,
      Regards,
      • lavolp3L Offline
        lavolp3 Module Developer
        I would set it into the top_left region right below the default clock module.
        Then in the custom.css I would set
        .MMM-SmartWebDisplay {
          height: xxxpx;  //put in the height you want, e.g. 600px
          width: 100%;
        Not sure if that works. Try it out.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
        • G Offline
          gaudouy
          Thanks for your response.
          I set the top_left region in the conf file and I add your code at the end of the css.
            height: 1000px;  //put in the height you want, e.g. 600px
            width: 100%;
          But it’s not working :( :
          • G Offline
            gaudouy
            When I define FullScreen, the size of the module is the same. What is the method for change his size ?
            • ? Offline
              [[global:former-user]]
              @gaudouy said in MMM-SmartWebDisplay : Regions / Resizing:
              MMM-SmartWebDisplay
              like this ?
              • ? Offline
                for your help, try launch MM with dev for open console.
                You can modify CSS in real time and see result
                and… humm, use webview for displaying ALL link
                iframe is so limited for this and return many error :)
                • G Offline
                  gaudouy
                  @Bugsounet said in MMM-SmartWebDisplay : Regions / Resizing:
                  It’s work when I modify the Ifram size ! Thanks :D
                  • I Offline
                    imchrisrein
                    I am in the same boat. Added a webpage but only a small sliver is showing. The first picture is the style that I am going for and the second picture is my current setup.
                    dakboard-big-calendar.png 1614234230788-2021-02-25-010614_1080x1920_scrot.png
                    Any idea how to get the whole web page to show? Is it in my custom css or something within the module that needs to change?
                      sdetweil @imchrisrein
                      @imchrisrein what position is it set in?
                      • I Offline
                        imchrisrein @sdetweil
                        I have tried a bunch of different regions, but right now I have lower_third
                          @imchrisrein lower-third starts 66% down from the top…
                          look at main.css to see the region positions
                          • I Offline
                            I don’t think this is something that I will be able to change in .css.
                            I am a noob at this but making changes have gone nowhere so far :crying_face:
                            edit**
                            I used Webview and think I am satisfied
                            Just need to center my qr code for my wifi now
                            • I Offline
                              imchrisrein @imchrisrein
                              @imchrisrein
