MMM-SmartWebDisplay : Regions / Resizing
13 Posts 5 Posters 2.6k Views 5 Watching
  • G Offline
    gaudouy
    I would like to know how to resize the " MMM-SmartWebDisplay " module so that it can occupy the following regions:
    alt text
    upper_third is yellow
    middle_center is cyan
    lower_third is magenta
    I would like it to occupy the following space(red):
    I tried without success for two days trying to modify the CSS, the module, the config file … nothing works.
    My skills are very very limited.
    Do you have any ideas ?
    Thanks in advance,
    Regards,
    • L Offline
      lavolp3 Module Developer
      I would set it into the top_left region right below the default clock module.
      Then in the custom.css I would set
      .MMM-SmartWebDisplay {
        height: xxxpx;  //put in the height you want, e.g. 600px
        width: 100%;
      Not sure if that works. Try it out.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • G Offline
        gaudouy
        Thanks for your response.
        I set the top_left region in the conf file and I add your code at the end of the css.
          height: 1000px;  //put in the height you want, e.g. 600px
          width: 100%;
        But it’s not working :( :
        • G Offline
          gaudouy
          When I define FullScreen, the size of the module is the same. What is the method for change his size ?
            A Former User
            @gaudouy said in MMM-SmartWebDisplay : Regions / Resizing:
            MMM-SmartWebDisplay
            like this ?
              A Former User
              for your help, try launch MM with dev for open console.
              You can modify CSS in real time and see result
              and… humm, use webview for displaying ALL link
              iframe is so limited for this and return many error :)
              • G Offline
                gaudouy
                @Bugsounet said in MMM-SmartWebDisplay : Regions / Resizing:
                It’s work when I modify the Ifram size ! Thanks :D
                • I Offline
                  imchrisrein
                  I am in the same boat. Added a webpage but only a small sliver is showing. The first picture is the style that I am going for and the second picture is my current setup.
                  dakboard-big-calendar.png 1614234230788-2021-02-25-010614_1080x1920_scrot.png
                  Any idea how to get the whole web page to show? Is it in my custom css or something within the module that needs to change?
                  S 1 Reply Last reply Feb 26, 2021, 1:22 AM Reply Quote 0
                    sdetweil @imchrisrein
                    @imchrisrein what position is it set in?
                    I 1 Reply Last reply Feb 26, 2021, 2:02 AM Reply Quote 0
                    • I Offline
                      imchrisrein @sdetweil
                      I have tried a bunch of different regions, but right now I have lower_third
                      S 1 Reply Last reply Feb 26, 2021, 2:38 AM Reply Quote 0
