    MMM-SmartWebDisplay : Regions / Resizing
    13 Posts 5 Posters 5.7k Views 5 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      I would set it into the top_left region right below the default clock module.
      Then in the custom.css I would set
      .MMM-SmartWebDisplay {
        height: xxxpx;  //put in the height you want, e.g. 600px
        width: 100%;
      Not sure if that works. Try it out.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      • G Offline
        gaudouy
        Thanks for your response.
        I set the top_left region in the conf file and I add your code at the end of the css.
          height: 1000px;  //put in the height you want, e.g. 600px
          width: 100%;
        But it’s not working :( :
        • G Offline
          gaudouy
          When I define FullScreen, the size of the module is the same. What is the method for change his size ?
            A Former User
            @gaudouy said in MMM-SmartWebDisplay : Regions / Resizing:
            MMM-SmartWebDisplay
            like this ?
              A Former User
              for your help, try launch MM with dev for open console.
              You can modify CSS in real time and see result
              and… humm, use webview for displaying ALL link
              iframe is so limited for this and return many error :)
              • G Offline
                gaudouy
                @Bugsounet said in MMM-SmartWebDisplay : Regions / Resizing:
                It’s work when I modify the Ifram size ! Thanks :D
                • I Offline
                  imchrisrein
                  I am in the same boat. Added a webpage but only a small sliver is showing. The first picture is the style that I am going for and the second picture is my current setup.
                  dakboard-big-calendar.png 1614234230788-2021-02-25-010614_1080x1920_scrot.png
                  Any idea how to get the whole web page to show? Is it in my custom css or something within the module that needs to change?
                    sdetweil @imchrisrein
                    @imchrisrein what position is it set in?
                    • I Offline
                      imchrisrein @sdetweil
                      I have tried a bunch of different regions, but right now I have lower_third
                        @imchrisrein lower-third starts 66% down from the top…
                        look at main.css to see the region positions
                        • I Offline
                          I don’t think this is something that I will be able to change in .css.
                          I am a noob at this but making changes have gone nowhere so far :crying_face:
                          edit**
                          I used Webview and think I am satisfied
                          Just need to center my qr code for my wifi now
                          • I Offline
                            imchrisrein @imchrisrein
                            @imchrisrein
