    Getting MMM to open on the second monitor and correctly size
    24 Posts 3 Posters 8.5k Views 3 Watching
    • C
      Chrisflex
      I have a second monitor to the right of my default monitor
      The idea is to open MMM on that screen and have it scaled correctly which is about 220 x 330 mm, this monitor is mounted vertically.
      Your help is appreciated.
        sdetweil @Chrisflex
        @Chrisflex well, to the right is ‘easy’
        in config.js u need to tell it where (left/right) to position the monitor in the display space.
        add this to config.js
        var config = {
        	electronOptions:{x:1920 },       // add this line, where x is the width of your 1st display
        now orientation… you MAY be able to use also width and height… altho it says to fullscreen on that montitor, so it should work
        electronOptions:{x:1920, width:xx,  height: yy },
        • C
          Chrisflex @sdetweil
          @sdetweil said in Getting MMM to open on the second monitor and correctly size:
          var config = {
          Great thank you for the advice I will try it later.
            sdetweil @Chrisflex
            @Chrisflex i have two monitors and have MM open on the second display
            • C
              Chrisflex
              I have entered the information as it is below
              var config = {electronOptions:{x:1920, width:768, height: 1360 },
              It still only opens on the primary screen.
              1920, 768, and 1360 are highlighted red
              I am not sure what that means.
              This is all being done in Windows 10 with Note+ as the editor.
                sdetweil @Chrisflex
                @Chrisflex how wide is the 1st display?
                did u try that 1st?
                just move to the second display and see what happens?
                highlighted in red by what?
                  sdetweil @Chrisflex
                  @Chrisflex on my machine, height and width don’t do anything, as the fullscreen takes over
                  you might also add fullscreen:false to the options above
                  that made mine use the sizes specified
                  I am on linux
                  if there is an error in the config. it will open on the primary display
                  look at the output of npm start
                  • C
                    Chrisflex
                    I have entered the information like this
                         this does not work      {electronOptions:{fullscreen:false ,x:1920 },
        {electronOptions:{x:1920,fullscreen:false }
                    This works
                    {electronOptions:{fullscreen:false }
                    It brings up a small screen but not sized correctly.
                    it shows Electron in the top left corner
                    this screen can be dragged to the second monitor.
                    here is the start up log
                    [2020-05-03 18:34:52.838] [LOG] Starting MagicMirror: v2.11.0
                    [2020-05-03 18:34:52.840] [LOG] Loading config …
                    [2020-05-03 18:34:52.844] [LOG] Loading module helpers …
                    [2020-05-03 18:34:52.845] [LOG] No helper found for module: alert.
                    [2020-05-03 18:34:52.881] [LOG] Initializing new module helper …
                    [2020-05-03 18:34:52.881] [LOG] Module helper loaded: updatenotification
                    [2020-05-03 18:34:52.881] [LOG] No helper found for module: clock.
                    [2020-05-03 18:34:53.145] [LOG] Initializing new module helper …
                    [2020-05-03 18:34:53.146] [LOG] Module helper loaded: calendar
                    [2020-05-03 18:34:53.146] [LOG] No helper found for module: compliments.
                    [2020-05-03 18:34:53.146] [LOG] No helper found for module: on-this-day.
                    [2020-05-03 18:34:53.147] [LOG] No helper found for module: random_quotes.
                    [2020-05-03 18:34:53.147] [LOG] No helper found for module: currentweather.
                    [2020-05-03 18:34:53.147] [LOG] No helper found for module: weatherforecast.
                    [2020-05-03 18:34:53.167] [LOG] Initializing new module helper …
                    [2020-05-03 18:34:53.167] [LOG] Module helper loaded: newsfeed
                    [2020-05-03 18:34:53.167] [LOG] All module helpers loaded.
                    [2020-05-03 18:34:53.269] [LOG] Starting server on port 8080 …
                    [2020-05-03 18:34:53.287] [LOG] Server started …
                    [2020-05-03 18:34:53.289] [LOG] Connecting socket for: updatenotification
                    [2020-05-03 18:34:53.289] [LOG] Connecting socket for: calendar
                    [2020-05-03 18:34:53.290] [LOG] Starting node helper for: calendar
                    [2020-05-03 18:34:53.290] [LOG] Connecting socket for: newsfeed
                    [2020-05-03 18:34:53.291] [LOG] Starting module: newsfeed
                    [2020-05-03 18:34:53.291] [LOG] Sockets connected & modules started …
                    [2020-05-03 18:34:53.362] [LOG] Launching application.
                    [2020-05-03 18:34:55.366] [LOG] Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/chris.flekas%40gmail.com/public/basic.ics - Interval: 300000
                    [2020-05-03 18:34:55.395] [LOG] Create new news fetcher for url: http://feeds.news24.com/articles/News24/TopStories/rss - Interval: 300000
                    [2020-05-03 18:34:55.806] [ERROR] fatal: not a git repository (or any of the parent directories): .git
                    thank you very much for you help
                      sdetweil
                      its like this
                      var config= {
                      electronOptions:{fullscreen:false, x:1920, width: 600, height:800 }, // note the trailing comma (which means more to come
                      • C
                        Chrisflex
                        Thank you I will try it tomorrow.
                        • C
                          Chrisflex
                          If I hover over the Electron icon in the taskbar I can see it must be open somewhere but not visible on one of the screens.
                          information entered like this
                          var config = {electronOptions:{fullscreen:false, x:1920, width: 600, height:800 },
                          alt text
                            sdetweil @Chrisflex
                            @Chrisflex i haven’t tried on windows… may boot over there today
                            • C
                              Chrisflex @sdetweil
                              @sdetweil Thanks I appreciate your help.
                                sdetweil @Chrisflex
                                @Chrisflex
                                this did what we were talking about
                                var config = {
                                	electronOptions: { x:1920,fullscreen:false , width: 600, height:800},
                                	address: "localhost",
                                alt text
                                this did on second screen not full screen (MM default size is 800x600)
                                var config = {
                                	electronOptions: { x:1920,fullscreen:false },
                                alt text
                                and this did second screen full screen
                                var config = {
                                	electronOptions: { x:1920},
                                alt text
                                • C
                                  Chrisflex
                                  the first option gives me this error
                                  var config = {
                                  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: C:\Users\Dell Server\MagicMirror\config\config.js:11
                                  var config = {electronOptions:electronOptions: {x:1920,fullscreen:false , width: 600, height:800},
                                  SyntaxError: Unexpected token :
                                  at Module._compile (internal/modules/cjs/loader.js:722:23)
                                  at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
                                  at Module.load (internal/modules/cjs/loader.js:645:32)
                                  at Function.Module._load (internal/modules/cjs/loader.js:560:12)
                                  at Module.require (internal/modules/cjs/loader.js:685:19)
                                  at require (internal/modules/cjs/helpers.js:16:16)
                                  at loadConfig (C:\Users\Dell Server\MagicMirror\js\app.js:69:12)
                                  at App.start (C:\Users\Dell Server\MagicMirror\js\app.js:210:3)
                                  at Object. (C:\Users\Dell Server\MagicMirror\js\electron.js:115:7)
                                  at Module._compile (internal/modules/cjs/loader.js:786:30)
                                  The second option
                                  var config = {
                                  address: “localhost”,
                                  gives me this error
                                  var config = {electronOptions:electronOptions: {x:1920,fullscreen:false},
                                  the last option
                                  starts MM in a window that can be dragged across to the second monitor but is not sized correctly.
                                  It is the size of the normal full screen
                                  S B 2 Replies Last reply Reply Quote 0
                                    sdetweil @Chrisflex
                                    @Chrisflex u are adding just the electronOptions line
                                    I was just showing where it went
                                    • C
                                      Chrisflex
                                      Copied from my config js file
                                      var config = {electronOptions:{x:1920 },
                                      address: “localhost”, // Address to listen on, can be:
                                      // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
                                      // - “0.0.0.0”, “::” to listen on any interface
                                      // Default, when address config is left out or empty, is “localhost”
                                      Is that correct?
                                        sdetweil @Chrisflex
                                        @Chrisflex better when on separate lines
                                        That looks ok
                                        Should be full screen on second display
                                          sdetweil @Chrisflex
                                          @Chrisflex posted pics above
                                          • B
                                            bhepler Module Developer @Chrisflex
                                            @Chrisflex - Please use the markdown features of the forum when posting code or logs.
