    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 419.6k Views 51 Watching
      bennerzzz
      @RedNax Hi, I installed this module yesterday however, I received an email pertaining to my api key exceeding the allotted rate of 10 in which I had 22. I have the free plan of 500 calls. Should I decrease the updateInterval? If so, to what value?
      thanks.
        RedNax Module Developer
        You went over the 10 calls per minute, probably while setting up/testing? The default settings won’t go over that when left alone. When you debug/play with :D your mirror through a browser on your pc and hit f5 a lot, you’ll go over it quickly. I’ve personally never had it happen.
          bennerzzz
          Yes, it said I went over 10 calls/minute while testing and perhaps refreshing the page caused it to do so. Anyway, thanks for the quick reply. Awesome module!
            moosedookie
            Great module, I have always preferred wunderground.
            Thanks a bunch!
              New version now shows the current moon phase and there’s a new layout option :)
              in config set layout:“vertical” for the traditional layout:
              or layout: “horizontal” for:
              Y 1 Reply Last reply Reply Quote 2
              • Y Offline
                yo-less Module Developer @RedNax
                @RedNax Excellent idea, I really like the new layout option. As soon as you have more than 4 days in the forecast table, though, you end up with a module that takes up a lot of your screen, I’d suggest adding a new table row every four days.
                  RedNax Module Developer @yo-less
                  @yo-less Thanks, i’ve added your suggestion :D
                  • Y Offline
                    @RedNax That was quick :D. Nice!
                    I’m still toying around with my fork of your module but I’ve made so many minor and bigger adjustments that it will be hard to simply merge the two module versions, as I would have to make every adjustment customizable in the config file to submit a pull request you could easily merge, but I will keep you updated on my progress.
                      mcg
                      @RedNax Thanks a lot for this beauty! Really love it :)
                      And the new horizontal design is an awesome idea as well!
                      I have a little remark anyway: In the text area it states the min/max temperature. From my personal point of view it should be either “°C” or “°” but not just “C”. Maybe that’s a localization thing…?!
                        Thanks! The text area is reproduced as it is delivered by WeatherUnderground… so barring any heuristics on the actual content it’s beyond our control…
                        Y 1 Reply Last reply Reply Quote 1
                        • Y Offline
                          @RedNax I managed to parse my way through it with some crazy regex stuff a few days ago (As this is the first time I have done this, it took me an insane amount of time to add the degree symbol only where it should be added), I know I keep saying this, but I will eventually push it to my MMM-WunderGround fork and then you can decide which of my features you would like to implement.
                          R ? 2 Replies Last reply Reply Quote 0
                            @yo-less Wow, kudos… i consider regex to be black magic ;)
                            • Y Offline
                              @RedNax Thanks, my head certainly felt like it had been occupied with occult practices when I was done :D
                              • P Offline
                                Plati
                                @RedNax i have little question. I have a small question. If you want to update the module I have to copy the files manually from github? Is there a command or something that will do it automatically? Forgive the question, just starting to work with raspberry etc :)
                                • strawberry 3.141S Offline
                                  strawberry 3.141 Project Sponsor Module Developer @Plati
                                  @Plati go into the modules directory and type git pull
                                  • P Offline
                                    Plati @strawberry 3.141
                                    @strawberry-3.141 but always I get an answer “Already up-to-date.”
                                      @Plati then there is no update and you are on the newest version
                                      • P Offline
                                        @strawberry-3.141 The last update is from yesterday, last updated my files was a week ago
                                          are you on the master branch?
                                          • P Offline
                                            @strawberry-3.141 no, in module.
                                            cd ~/MagicMirror/modules/default/MMM-WunderGround
                                            git pull
                                            • 9
                                            • 10
                                            • 2 / 10
