    PIR sensor help please
    pir sensorraspberry pihelp me pleasenew
    8 Posts 5 Posters 4.6k Views 5 Watching
    • P Offline
      PHAGE.GOV
      Hello,
      So how would you connect a PIR sensor to the raspberry pi four?
      would i need like those connector things or like one of those weird board things? Im new so i have no idea how to do this, thanks in advance!!
        sdetweil @PHAGE.GOV
        @PHAGE-GOV google is your friend…
        • P Offline
          PHAGE.GOV
          literally cant find anything tho
          Mykle1M S 2 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @PHAGE.GOV
            @PHAGE-GOV
            Use the forum search. There is plenty of pir info
              sdetweil @PHAGE.GOV
              @PHAGE-GOV this Google search brought up a ton of info
              “how to connect pir to raspberry pi”
              • ? Offline
                A Former User
                maybe this can help you ?
                • ? Offline
                  A Former User
                  you have the pinout of RPI :)
                  • P Offline
                    pandeyprakhar00
                    Step 1: Calibrate your PIR Sensor. You may use a small circuit for testing !
                    Step 2: Connect your PIR sensor to Pi
                    Step 3: Install MMM-PirSensor module
                    https://github.com/paviro/MMM-PIR-Sensor
                    Hope it helps !
