    mmm assistant mk2
    112 Posts 12 Posters 74.5k Views 11 Watching
    • ChrisC
      Chris @Guest
      @Bugsounet
      Hello,
      First of all, thank you for not stopping your work on this module which is of high quality.
      I tried to install the new assistant. I followed the wiki. However, I have a problem.
      Indeed, when the mirror is launched, I find myself with the following message:
      [2020-06-01 14:04:54.256] [LOG]    [ASSISTANT][ERROR] token.json file not found
      However, I followed the WIKI well and applied the following command:
      (env) pi@raspberrypi:~/MagicMirror/modules/MMM-GoogleAssistant $ ACCESSTOKEN=ya29.a0AfH6SMABBPj590X_itMQG616F8QpxddhPVuSXCE4qvZs6znHKbG2n5RggszFMdl0V5HP0lf956H9O7VHlbuGuMxSzkU3pMkdbpFxs485NwfXYl9T7hfLzB0EOPlRTwcifZW-8rIUlZlWXXXXXXXXXXXXXXXXXXX
      Do you have any idea about this problem?
      Thanking you in advance,
      Regards,
        A Former User
        @dvbit try this:
        launch it in root directly in RPI terminal (not ssh)
        cd ~/MagicMirror
        sudo ./node_modules/.bin/electron js/electron.js --no-sandbox
        give me result
          A Former User
          @chris: token.json file must be located in ~/MagicMirror/modules/MMM-GoogleAssistant/token.json
          ChrisC 1 Reply Last reply Reply Quote 0
            sdetweil @Guest
            @Bugsounet u can also run the fixsandbox script from my repo
            if they use my installer I fix it… otherwise they either need the --nosandbox or run my script
              A Former User
              sam, i suspect a bug in electron
              chown root and chmod 4755 ?
                sdetweil @Guest
                @Bugsounet yes, what my script does…
                not a bug, new feature
                  A Former User
                  yes but i don’t understand why … with pulseaudio there is no sound but with root it’s works …
                  There is a permission missing somewhere
                    sdetweil @Guest
                    @Bugsounet sorry, got no idea what the side effects are…
                    they wanted some additional security
                    are u launching a player as a background task, or playing direct to the device? if the latter then u get all the security crap
                      A Former User
                      sam:
                      in RPI4: it’s works
                      pi@Raspberry:~/MagicMirror/node_modules/electron/dist $ ls -la
                      total 107516
                      drwxr-xr-x 4 pi   pi     4096 mai   20 15:23 .
                      drwxr-xr-x 3 pi   pi     4096 juin   1 13:37 ..
                      -rw-r--r-- 1 pi   pi   145945 mai   20 15:23 chrome_100_percent.pak
                      -rw-r--r-- 1 pi   pi   209147 mai   20 15:23 chrome_200_percent.pak
                      -rwsr-xr-x 1 root pi  4204060 mai   20 15:23 chrome-sandbox
                      i have no idea if @dvbit it’s the same
                      Note: this Issue take me head since 6 month
                      S ? 2 Replies Last reply Reply Quote 0
                        sdetweil @Guest
                        @Bugsounet yes, added in V6 of electron (and chrome 45 I think?) we are running 6.1.7
                          A Former User
                          pi@Raspberry:~/MagicMirror/node_modules/electron/dist $ ./electron -v
                          v6.1.12
                            sdetweil @Guest
                            @Bugsounet weird we call for 6.1.7 or above
                            "electron": "^6.1.7"
                            • ChrisC
                              Chris @Guest
                              @Bugsounet
                              Hello,
                              Indeed, I did not understand well in WIKI.
                              If it can be used for others, you must create a token.js file and insert the code:
                              Now it works perfectly,
                              Thank you so much,
                              Regards,
                                A Former User @sdetweil
                                but only in 6.x.x branch
                                actually electron is releasing with v9 ;)
                                • D
                                  dvbit @dvbit
                                  @dvbit said in mmm assistant mk2:
                                  Update: I reinstalled from scratch (again for a2d I had to do a npm rebuild, you may want to take note)
                                  Still the same issue of assistant hanging after query:
                                  I do the query, hotword recognized, query recognized, answer fetched, answer saved in temp and displayed on screen bottom but no audio feedback and gogle spin icon going.
                                  After refreshing the screen goes again in “steady state”
                                  Now I am sure I have a sound output issue.
                                  Meaning that I can play sounds on the mirror via vlc but somehow the plugin cannot.
                                  I guess that somehow the plugin does not receive a feedback of “play ended” from the output.
                                  What I also noticed is that if I refresh the browser by vnc the mirror will go again in a waiting status.
                                  Will continue checking
                                  could it be this: https://github.com/raspberrypi/firmware/issues/1243
                                  Edit: Nope - vlc outputs sound
                                  IMPORTANT:
                                  The Install script for the audio output was succesfull just the first time.
                                  on second install I skipped the output part as I could not get through indeed.
                                  However the input was working just fine. recorded my voice and could hear it.
                                  Posting here my asoundrc file
                                  pcm.!default {
                                    type asym
                                    playback.pcm {
                                      type plug
                                      slave.pcm "output"
                                    capture.pcm {
                                      type plug
                                      slave.pcm "input"
                                  pcm.output {
                                    type hw
                                    card 0
                                  ctl.!default {
                                    type hw
                                    card 0
                                  Input is : kinect microphones
                                  Output : TV speakers (directly through TV speakers)
                                    sdetweil @Guest
                                    @Bugsounet it also has sandbox…
                                    we just moved up to V6 from V3 on 2.10, some things newer don’t work on pi…
                                      A Former User @Guest
                                      @Bugsounet said in mmm assistant mk2:
                                      total 107516
                                      @dvbit: can you give me your result please ?
                                      • D
                                        dvbit @Guest
                                        pi@MagicMirror:~/MagicMirror $ ~/MagicMirror/node_modules/electron/dist $ ls -la
                                        bash: /home/pi/MagicMirror/node_modules/electron/dist: Is a directory
                                        pi@MagicMirror:~/MagicMirror $ cd ~/MagicMirror/node_modules/electron/dist
                                        pi@MagicMirror:~/MagicMirror/node_modules/electron/dist $ ls -la
                                        total 107496
                                        drwxr-xr-x 4 pi pi     4096 May 30 12:38 .
                                        drwxr-xr-x 4 pi pi     4096 May 30 12:38 ..
                                        -rw-r--r-- 1 pi pi   145945 May 30 12:38 chrome_100_percent.pak
                                        -rw-r--r-- 1 pi pi   209147 May 30 12:38 chrome_200_percent.pak
                                        -rwxr-xr-x 1 pi pi  4202140 May 30 12:38 chrome-sandbox
                                        -rwxr-xr-x 1 pi pi 74664904 May 30 12:38 electron
                                        -rw-r--r-- 1 pi pi 10410272 May 30 12:38 icudtl.dat
                                        -rwxr-xr-x 1 pi pi   157372 May 30 12:38 libEGL.so
                                        -rwxr-xr-x 1 pi pi  1949660 May 30 12:38 libffmpeg.so
                                        -rwxr-xr-x 1 pi pi  4883208 May 30 12:38 libGLESv2.so
                                        -rw-r--r-- 1 pi pi     1060 May 30 12:38 LICENSE
                                        -rw-r--r-- 1 pi pi  3961766 May 30 12:38 LICENSES.chromium.html
                                        drwxr-xr-x 2 pi pi     4096 May 30 12:38 locales
                                        -rw-r--r-- 1 pi pi    83237 May 30 12:38 natives_blob.bin
                                        drwxr-xr-x 2 pi pi     4096 May 30 12:38 resources
                                        -rw-r--r-- 1 pi pi  8471329 May 30 12:38 resources.pak
                                        -rw-r--r-- 1 pi pi   275792 May 30 12:38 snapshot_blob.bin
                                        -rw-r--r-- 1 pi pi   608820 May 30 12:38 v8_context_snapshot.bin
                                        -rw-r--r-- 1 pi pi        5 May 30 12:38 version
                                        Please look also post above: I realize my asoundrc file may be screwed since I did not complete on second install the sound output wizard successfully
                                          sdetweil @dvbit
                                          @dvbit run
                                          bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixsandbox)"
                                            A Former User
                                            sam : you have right
                                            permission is not set
                                            After 6 month … maybe it will be solved !
                                            • 6
                                            • 3 / 6
