    Why is the MMM-WeatherOrNot module no longer in the list of modules?
    11 Posts 3 Posters 2.6k Views 2 Watching
      RIKKO14
      This post is deleted!
      • BKeyportB Offline
        BKeyport Module Developer
        Clearly there was an error and @Mykle1 had to remove it. If he’s able to fix it, it will be back.
        De toute évidence, il y avait une erreur et @Mykle1 a dû la supprimer. S’il est capable de le réparer, ce sera de retour.
        Traduit en utilisant Google, veuillez essayer d’utiliser l’anglais.
          Mykle1 Project Sponsor Module Developer @RIKKO14
          @RIKKO14
          Uhhhhh, What list of modules? 3rd party? It’s there.
          Your link is incorrect. This will bring you to the repo.
          https://github.com/mykle1/MMM-WeatherOrNot
            Mykle1 Project Sponsor Module Developer @BKeyport
            @BKeyport said in Why is the MMM-WeatherOrNot module no longer in the list of modules?:
            Nope.
              RIKKO14
              Elle est revenue dans la liste mais plus bas…, on peux cloturer ce post.
              Merci de vos retours.
                RIKKO14
                it still doesn’t work …
                  @RIKKO14 said in Why is the MMM-WeatherOrNot module no longer in the list of modules?:
                  What doesn’t work? The link? The module?
                    RIKKO14
                    everything is ok and works well. Thank you for your feedback.
                      So, what was the issue?
                      Mark the topic as solved if you corrected the issue.
                        RIKKO14
                        the problem came from my google translate.
                        How Mark the topic as solved ?
                          Click the 3 vertical dots at the right of your first post
