    MMM-GoogleAssistant note here
    22 Posts 4 Posters 7.1k Views 4 Watching
    • W Offline
      wirdman
      hello my MMM-Google assistant in loaded correctly but no google assistant :crying_face:
      i@raspberrypi:~/MagicMirror $ npm start
      > magicmirror@2.12.0 start /home/pi/MagicMirror
      [2020-07-15 01:13:03.427] [LOG]    Starting MagicMirror: v2.12.0
      [2020-07-15 01:13:03.441] [LOG]    Loading config ...
      [2020-07-15 01:13:03.450] [LOG]    Loading module helpers ...
      [2020-07-15 01:13:03.455] [LOG]    No helper found for module: alert.
      [2020-07-15 01:13:03.545] [LOG]    Initializing new module helper ...
      [2020-07-15 01:13:03.547] [LOG]    Module helper loaded: updatenotification
      [2020-07-15 01:13:03.548] [LOG]    No helper found for module: clock.
      [2020-07-15 01:13:04.978] [LOG]    Initializing new module helper ...
      [2020-07-15 01:13:04.980] [LOG]    Module helper loaded: calendar
      [2020-07-15 01:13:04.983] [LOG]    No helper found for module: compliments.
      [2020-07-15 01:13:04.985] [LOG]    No helper found for module: currentweather.
      [2020-07-15 01:13:04.987] [LOG]    No helper found for module: weatherforecast.
      [2020-07-15 01:13:08.874] [LOG]    Initializing new module helper ...
      [2020-07-15 01:13:08.876] [LOG]    Module helper loaded: MMM-GoogleAssistant
      [2020-07-15 01:13:08.879] [LOG]    No helper found for module: MMM-SwissCommute.
      [2020-07-15 01:13:10.039] [LOG]    Initializing new module helper ...
      [2020-07-15 01:13:10.040] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
      [2020-07-15 01:13:10.090] [LOG]    Initializing new module helper ...
      [2020-07-15 01:13:10.091] [LOG]    Module helper loaded: newsfeed
      [2020-07-15 01:13:10.092] [LOG]    All module helpers loaded.
      [2020-07-15 01:13:10.394] [LOG]    Starting server on port 8080 ...
      [2020-07-15 01:13:10.443] [INFO]   You're using a full whitelist configuration to allow for all IPs
      [2020-07-15 01:13:10.474] [LOG]    Server started ...
      [2020-07-15 01:13:10.477] [LOG]    Connecting socket for: updatenotification
      [2020-07-15 01:13:10.482] [LOG]    Connecting socket for: calendar
      [2020-07-15 01:13:10.485] [LOG]    Starting node helper for: calendar
      [2020-07-15 01:13:10.489] [LOG]    Connecting socket for: MMM-GoogleAssistant
      [2020-07-15 01:13:10.492] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
      [2020-07-15 01:13:10.495] [LOG]    Connecting socket for: newsfeed
      [2020-07-15 01:13:10.497] [LOG]    Starting node helper for: newsfeed
      [2020-07-15 01:13:10.499] [LOG]    Sockets connected & modules started ...
      [2020-07-15 01:13:10.826] [LOG]    Launching application.
      [2020-07-15 01:13:16.935] [LOG]    Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/maxart3.3%40gmail.com/private-b5e26bc2232a38edcb73772a3242221e/basic.ics - Interval: 300000
      [2020-07-15 01:13:17.444] [LOG]    Create new news fetcher for url: https://www.lemonde.fr/international/rss_full.xml - Interval: 300000
      [2020-07-15 01:13:17.566] [INFO]   Checking git for module: MMM-GoogleAssistant
      [2020-07-15 01:13:17.609] [INFO]   Checking git for module: MMM-SwissCommute
      [2020-07-15 01:13:17.644] [INFO]   Checking git for module: MMM-NowPlayingOnSpotify
      [2020-07-15 01:13:17.706] [LOG]    [ASSISTANT] MMM-GoogleAssistant Version: 2.2.1
      [2020-07-15 01:13:17.723] [ERROR]  (node:24880) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [2020-07-15 01:13:17.726] [ERROR]  (node:24880) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [2020-07-15 01:13:19.013] [LOG]    Refreshed access token because it has expired. Expired at: 01:13:17 now is: 01:13:19
      [2020-07-15 01:13:19.096] [LOG]    Refreshed access token because it has expired. Expired at: 02:13:19 now is: 01:13:19
      [2020-07-15 01:13:19.233] [LOG]    Refreshed access token because it has expired. Expired at: 02:13:19 now is: 01:13:19
      [2020-07-15 01:13:20.148] [INFO]   Newsfeed-Fetcher: Broadcasting 20 items.
      [2020-07-15 01:13:21.741] [LOG]    [SNOWBOY] Model selected: jarvis
      [2020-07-15 01:13:21.756] [LOG]    [SNOWBOY] snowboy v1.5.0 Initialized...
      [2020-07-15 01:13:21.768] [LOG]    [ASSISTANT] RECIPE_LOADED: with-MMM-TelegramBot.js
      [2020-07-15 01:13:21.772] [LOG]    [ASSISTANT] Use native program (mpg321) for audio response
      [2020-07-15 01:13:21.780] [LOG]    [SOUND] mpg321 Initialized
      [2020-07-15 01:13:21.785] [LOG]    [ASSISTANT] Google Assistant is initialized.
      [2020-07-15 01:13:22.926] [INFO]   Calendar-Fetcher: Broadcasting 4 events.
        sdetweil @wirdman
        @wirdman did u speak the hotword, and ask a question?
        • K Offline
          killerjoe34
          Ton micro fonctionne ? Tu appelles bien “jarvis” et non “ok Google” ?
          • ? Offline
            [[global:former-user]]
            Hi, there is no ui on screen, only when you activate it (it’s write on the wiki …)
            so i don’t know what do you search on the screen ?
            • ? Offline
              @killerjoe34 : maybe @wirdman don’t try… just because it don’t found the GA ui on stand-by mode
              • W Offline
                wirdman @sdetweil
                @sdetweil oui j essai d appeler jarvis ou google mais pas de réponse
                peut etre il ne prend pas en compte mon micro usb
                • K Offline
                  killerjoe34
                  Does it appear with
                  arecord -l
                  And if it is, the card number should be reported in your config.js
                   micConfig: { // put there configuration generated by $
                                              recorder: "arecord",
                                              device: "plughw:2",
                  • ? Offline
                    pense également a vérifier le volume du micro ;)
                    va dans le bureau du RPI > icone volume > (clique droit) > output device > device setting
                    vérifie egalement qu’il est pas sur mute !
                    • W Offline
                      wirdman
                      voici ma config.js et le
                      arecord -l
                      Merci encore pour votre aide
                      • K Offline
                        killerjoe34
                        avec MM arrêté, essaie
                        arecord --format=S16_LE --duration=5 --rate=48000 --file-type=raw out.raw
                        et
                        aplay --format=S16_LE --rate=48000 out.raw
                        pour voir s’il est configuré correctement
                        • W Offline
                          wirdman
                          @killerjoe34 said in MMM-GoogleAssistant note here:
                          i think no ^^
                          pipi@raspberrypi:~ $ arecord --format=S16_LE --duration=5 --rate=48000 --file-type=raw out.raw
                          ALSA lib pcm.c:2565:(snd_pcm_open_noupdate) Unknown PCM input
                          arecord: main:828: erreur à l'ouverture audio: Aucun fichier ou dossier de ce type
                          • ? Offline
                            arecord -D plughw:2 -q -r 16000 -c 1 -t wav -f S16_LE -d 3 test.wav
                            aplay test.wav
                            • W Offline
                              wirdman @Guest
                              @Bugsounet
                              pi@raspberrypi:~ $ arecord -D plughw:2 -q -r 16000 -c 1 -t wav -f S16_LE -d 3 test.wav
                              arecord: main:828: erreur à l'ouverture audio: Périphérique ou ressource occupé
                              • ? Offline
                                cela veux simplement dire que tu enregistre deja quelque chose
                                suremement Magicmirror est lancer ;)
                                • W Offline
                                  wirdman @Guest
                                  @Bugsounet
                                  haa d’accord merci beaucoup
                                  pi@raspberrypi:~ $ aplay test.wav
                                  Lecture WAVE 'test.wav' : Signed 16 bit Little Endian, Fréquence 16000 Hz, Mono
                                  • ? Offline
                                    So: It’s meens, if you hear your voice plughw:2 is the good configuration for micConfig: {} part
                                    [donc , si vous entendez votre voix, cela signifie que plughw:2 est la bonne configuration a mettre dans micConfig: {}]
                                    • W Offline
                                      wirdman @Guest
                                      @Bugsounet
                                      Tout fonctionne merci énormément 😁😁😁
                                      merci pour votre aide et votre patience pour le noob que je suis
                                      • ? Offline
                                        no problem, it’s logical i help you … just because i code it ;)
                                        [pas de souci, vu que je créé ce module, il me parait logique d’aider (surtout les français … comme moi)]
                                        now let’s try Assistant2Display extension, for displaying all jobs
                                        [essayez maintenant Assistant2Display, l’extension de GA pour afficher plein de chose…]
                                        W 2 Replies Last reply Reply Quote 0
                                        • W Offline
                                          wirdman @Guest
                                          @Bugsounet
                                          i going right night to see that 😃
                                          • W Offline
                                            wirdman @Guest
                                            @Bugsounet said in MMM-GoogleAssistant note here:
                                            Assistant2Display
                                            je suis un peut perdu je pense a cause du
                                            var config = {
                                              address: "localhost",
                                              electronOptions: {
                                                webPreferences: {
                                                  webviewTag: true
                                              port: 8080,
                                            voici l’erreur sinon tout ce lance correctement
                                            [2020-07-16 20:03:31.883] [LOG]    [A2D] MMM-Assistant2Display Version: 2.2.1
                                            [2020-07-16 20:03:31.910] [ERROR]  (node:9433) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                            [2020-07-16 20:03:31.916] [ERROR]  (node:9433) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
                                            [2020-07-16 20:03:34.067] [LOG]    Refreshed access token because it has expired. Expired at: 20:03:31 now is: 20:03:34
                                            [2020-07-16 20:03:34.126] [LOG]    Refreshed access token because it has expired. Expired at: 21:03:34 now is: 20:03:34
                                            [2020-07-16 20:03:35.013] [INFO]   Newsfeed-Fetcher: Broadcasting 20 items.
                                            [2020-07-16 20:03:36.759] [LOG]    [A2D] Assistant2Display is disabled.
